Packet loss on LAN...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Yeah network looks sick...
    1065 packets transmitted, 975 received, 8.4507% packet loss, time 1070433ms
    rtt min/avg/max/mdev = 0.704/0.839/1.838/0.088 ms
    Swapped out the network switch... happy again
    179 packets transmitted, 179 received, 0% packet loss, time 179176ms
    rtt min/avg/max/mdev = 0.714/0.832/0.980/0.085 ms
    Now whether to just pitch this 8-port 10/100 switch or figure out why it's losing packets... Using the 24-port in its place is kind of overkill but it's also only 10/100...
    • 31137
    Re: Packet loss on LAN...
    probably bad caps in it.
      • Jul 2011
      • 6057
      Is the device running real warm because if it is it been my experience with them it time for a new one because the newer ones really do not have many or none electric type of capacitors anymore and found a micro controller running very very warm to almost hot
      It is not worth my time fool with them
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        • Bulgaria
        Most likely the IC on the switch is overheating and about to fail.
        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Well this isn't exactly a new network switch behavior when they fail, seems to be a fairly common way to die. Quick cap check looks good.
          Oh well, nothing lost, just time gained (was a trash pick and got a few years of service from it, at least!). I should replace with a Gbit switch but this segment of my network I quarantined all the 10/100 machines and printers and a slow 10/100 was a perfect fit!
          10Mbit should not have been as slow as it was, I wonder how many people would have just dismissed the packet loss as typical behavior of 10Mbit when they're used to Gbit or 10Gbit Ethernet!
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            • Bulgaria
            I think that it is needless to say that you can buy 1Gbps 8 port switch for 20$ or less.
            And 100mbps are even cheaper. As cheap as 7$
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Or I can keep using the 24 port 10/100 I had as a spare, no additional cost!
              • retiredcaps
                • Apr 2010
                • 9271
                It's possible that a power outage, change in the end devices (reboot, software upgrade), etc changed something so that duplex negotiation is not working properly. This was a common problem early on with poor drivers, reboots, etc, etc.
                One side thinks it is 10/half and other thinks 10/full. Same for 100.
                --- begin sig file ---
                --- end sig file ---
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I think I tried power cycling the switch and it still behaved improperly, but just swapping in that 24-port switch made the lost packets go away. I guess I should try sticking it in cold to see how that afflicted switch behaves.
                  I think I'm only using like 5 ports on this 8 port switch, using that 24-port is way overkill, at least it's not also a Gbit switch...
                  Plugged in switch cold after it being out of service for 20 hours or so...
                  448 packets transmitted, 448 received, 0% packet loss, time 89799ms
                  rtt min/avg/max/mdev = 2.376/2.619/3.316/0.125 ms
                  Well, not exactly the same target or same rate, but looks OK. This is to my printer instead of the K6-233, but I had been having poor performance to the printer as well.
                  This switch has a K6-233 (10M), a printer (10M), a DECstation (10M), a test station (100M), and uplink connected(100M).
                  Hmm...will run this a few days to see if it degrades again, if it degrades again I'll have to figure out how to shoehorn a 24-port switch where an 8-port switch fit... else I'll need to find a smaller switch...
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    • Bulgaria
                    10Mbps is 1.25MB/sec. It's not fast at all, but I would not dismiss any network problems. Losses in any network are because of some problem, not the nature of the network, unless they are accounted for and the network is meant to function using lossy medium, like WLAN, where losses are imminent and can't be avoided, because of interference.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      If you only need 4 ethernet/fast ethernet ports, old wifi routers are usually given away for free. Just turn off the wifi and use the 4 port ethernet switch built in. Lot's of old 802.11b only Linksys/Cisco routers available.
                      • redwire
                        • Dec 2010
                        • 3912
                        I've had either the 12V wall-wart caps or the switch's internal electrolytic caps go bad. I'd take a look at them.
                        A new one is cheap but these things run hot they don't last more than a couple years.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Still seems to be working... strange.
                          Another weirdness is that the 9v wall wart won't power a 12v 1a lamp... completely dark, yet it still powers the switch just fine. Hmm.
                          Found another 10/100 ... hub? switch? Says switching hub, whatever that means. It has a 7.5V wall wart to test...except it's a linear. Would just use it, except it has a ... fan
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Hmm Flood Ping testing... From: Gbit Ethernet machine To: 10Mbit Ethernet machine:
                            25265 packets transmitted, 25060 received, 0.811399% packet loss, time 18423ms
                            rtt min/avg/max/mdev = 0.545/0.575/0.997/0.022 ms, ipg/ewma 0.729/0.586 ms
                            I suspect the faster machine could generate another ping faster than the 10Mbit machine to generate a response and the two packets collide causing a lost packet... 1% isn't too bad I guess, better than that 8% earlier.
                            That 10Mbit machine flood pinging my 10Mbit printer however... 0 packet loss.
                            So now it seems to be working once more, maybe it did somehow switch into the wrong mode somehow. Still unsure how, power has been fairly stable...
                            • televizora
                              ghettomodmaster
                              • Nov 2016
                              • 957
                              • Bulgaria
                              A standard ICMP packet is 74 bytes or 592 bits. If you send 1 packet per second, this is 592 bits/sec.
                              How many pings simultaneously do you think you need to bottleneck even a 10Mbps network connection with a speed about 10*485*760bits/sec? I will answer you. You need to send about 17*712,43 pings per second. Ping is not a measure of network losses. And having losses when you send only 592bits/sec means that you have a problem.
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Yes, you can set the size with the -l parameter in Windows, like so:
                                ping -l 60000
                                Should be around a megabit or so.
                                There are better ways, like copying a file over the network of course
                                But when a switch is really bad I find that this test works quite well...
                                • televizora
                                  ghettomodmaster
                                  • Nov 2016
                                  • 957
                                  • Bulgaria
                                  Better copying a file over the network, while simultaneously pinging the other computer. Losses in a bad network tend to appear, when the consumed bandwidth increases. It is not very sophisticated test, although...
                                  Yes, you can set the size with the -l parameter in Windows, like so:ping -l 60000
                                  This is not very reliable. Considering that MTU of Ethernet is 1500, this means that it will be fragmented. If fragmentation is not allowed or the device handles it poorly, this can lead to timeouts, even if there isn't any actual problem with the network.
                                    • 31137
                                    does that figure include start-bit, stop-bit, parity etc.??
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Yeah, seems like that poster ignored a lot of stuff when assuming that windows ping is the only ping in town, and would be mindblown with the mere options Un*x ping offers... and even more so with a version that does away with the limits even it offers to prevent people from taking down networks, DoS-like...
                                      • televizora
                                        ghettomodmaster
                                        • Nov 2016
                                        • 957
                                        • Bulgaria
                                        I ignored nothing.
                                        1. Ping DDOS works by sending ICMP packets using to the broadcast address of a network, using spoofed IP - the IP of the attacked host.
                                        This is amplification attack.
                                        2. Far more useful is TCP SYN DDOS.
                                        Sending SYN, never returning ACK, keeping the server waiting, clogging up all the ports.
                                        3. SYN ACK reflection. Spoofed IP, sending SYN to hosts in the network, pretending to be other host. The hosts send ACK. If the attacked host does not confirm, they continue sending ACK and attempting to establish a 3 way handshake. Because if SYN is received, but SYN-ACK is never received, the nature of the TCP makes the host assume that the the packet is lost, thus retransmits it. This is again amplification attack.
                                        Unless you intentionally target and attack a host, ping consumes insignificant bandwidth and a single computer sending pings will have a hard time clogging up a network.
                                        Unless you:
                                        1. Have a network with low RTT
                                        2. Use ping with -A parameter, so frequency of requests is matched to RTT.
                                        3. You use a packet size way higher than the MTU, which is 1500 bytes for Ethernet.
                                        4. If you do this and receive losses, the network might not be the problem. But fragmentation and poor handling of packets with size higher than Ethernet frame size/1500/
                                        If we suppose that we have a perfect network with low RTT(1ms) and we use the maximum size of IP packet(64K) and use ping with -A parameter, then
                                        (64k x 1000ms(1sec)/1024)x8=~62MB/sec or 500Mbps. RTT even for a local network is rarely 1ms. Only this way you can clog up a network.
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                        • EasyGoing1
                                          UPNP, "Standards" and hardware that implements it
                                          by EasyGoing1
                                          I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                          One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                          So I decided to implement UPNP...
                                          07-16-2022, 07:12 PM
                                        • mscottdoran@gmail.com
                                          Can anyone identify the classification of this data signal?
                                          by mscottdoran@gmail.com
                                          Hi, I'm an elevator technician. The attached oscilloscope display picture is from a digital elevator hall arrival lantern data signal. We have been having problems with “ghost signals” causing intermittent hall arrival lanterns to illuminate randomly when the elevator is not actually due to arrive at the floor.
                                          The tech support of the hall arrival board manufacturer (CE Electronics) is blaming the elevator controller manufacturer (MCE), and the tech support of the elevator controller blames the hall arrival board manufacturer.
                                          The boards are powered by a ground referenced...
                                          02-08-2025, 11:31 AM
