Identifying THT resistor value + other Qs. [Electric blanket controller repair]
  • Sirgu
    • Nov 2013
    • 24
    • Estonia
    I hope this fits well into "weird devices" category.
    Please... anyone that knows better the science of resistors. Everything is on pictures.
    Stuff written in green boxes are official values accordingly the packages and datasheets. The rest is the rest.
    All I can add is that the subject`s background colour behind stripes is blueish light gray. As resistor #2 in the row is rather beige and physically smaller, I think it`s not right replacement for the main issue.
    As I didn`t had resistors #1 to #4 on hand reach at first place, I quickly learned hard way that 500mW or either carbon film type resistor is not a way to go there.
    I have a slight hunch that the subject might be 2W and metal oxide film due to similarities of this:
    https://projectpoint.in/index.php?ro...d=501648635957
    ... yet again some 3W variants look the same as well:
    https://www.amazon.com/uxcell-50pcs-.../dp/B07GMZDBNJ
    So I`m puzzled.
    IF 3W would be right way to go - could I use my #4 for replacement even though its wirewound type of resistor.
    Is there`s any significant difference between resistor materials type in this context?
    Secondly.
    What would you do with the burn mark on PC board? Luckly the tracks are on the other side and not damaged. I applied some kapton tape on the spot before new resistor replacement.
    Yes, the electrolytic capacitor is replaced as well. And atm I`m troubleshooting those yellow MPX X2 polypropylene capacitors as well, although it`s not shown on that second picture collage. Just to be sure of everything.
    Thanks in advance!
  • R_J
    • Jun 2012
    • 9609
    Re: Identifying THT resistor value + other Qs. [Electric blanket controller repair]
    The resistor is likely a 1 watt, Some manufacturers resistors are smaller in size for the same wattage. Mount the resistor above the board so it is no longer touching and it will have better heat dissipation. Did you find the cause of the open resistor or was the original not open? The one you are asking about is likely a 1 watt metal film flame proof, I would use #1,2 or 3, You can use #4 if you have room,
      • 31262
      it's a 1w FLAME-PROOF resistor.
      it's big because the oxide track is not continuous - it's a spiral so it can go open-circuit with minimal heat.
      that's also why it is dipped in gray cement instead of paint.
      • redwire
        • Dec 2010
        • 3912
        I think there is another bad part that cooks this resistor? Is it for a snubber or capacitive-power? Where is the triac I would check it.
        There is a wide variance in the size of power resistors, a big game to make the smallest power resistor with the highest power rating. I compared dozens of different ones and realized it will drive you crazy.
        A resistor manufacturer will offer a "mini size" for the same power rating, but they operate much hotter.
        The larger the resistor is, the greater the heat dissipation. The better the materials (cement verses epoxy, wirewound verses film, copper leads verses FeCu) the hotter it can go.
        I don't think you can judge power resistors on size nowadays.
        • Sirgu
          • Nov 2013
          • 24
          • Estonia
          Thanks everyone! It broadens my knowledge a lot.
          R_J - Yes, this original main issue resistor is open. And the burn mark is seemingly a long-term result. Not a sudden cause of resistor failure.
          And there`s plenty of space to solder any of them there.
          stj - #2, #3 and #4 also have this kind of hard matt coating while #1 is glossy paint (or epoxy for that matter). I never knew the considerations for materials used for finishing. Likewise I don`t know much of a difference of resistor type technologies.
          redwire - Oh my, thanks for the input! There`s so much to discover. Snubber vs capacitive-power - How can I find out?
          So... putting this all together my #2 seems almost like a replacement but probably it will heat up faster and will eventually fail later.
          I am assuming that:
          1.) Wattage value can be exact OR bigger (if it physically fits) but never smaller than original.
          2.) Whereas `flame proof` type is a must accordingly the context.
          3.) Plus physical size should be at least the same up to its values for better cooling.
          [Correct me if I am wrong in any aspects.]
          As follow-up question:
          -This polypropylene capacitor needs to be replaced, right? As it`s capacitance (exactly -20% of 1.0uF) is lower than stated capacitance tolerance (±10%). Also resistance slightly out of range.
          • Sirgu
            • Nov 2013
            • 24
            • Estonia
            Originally posted by redwire
            ... Is it for a snubber or capacitive-power? Where is the triac I would check it. ...
            There are four triacs / transistors in this pcb design.
            Two of them read:
            MAC
            97A6
            13H
            One is:
            13001
            98T
            And the last one:
            A1015
            GR011
            Make and model of thing itself (if it helps anyhow):
            Rubicson KDA6-FT electric blanket
            [some pictures here]
            Controller looks as following:
            https://www.youtube.com/watch?v=5K5p...arH.%C3%85gren
            Someone has done curious teardown whereas those triacs and the rest is pretty clearly seen as well. The misbehaviour of controller LED`s in the video are the same as my unit (stating that smth is wrong) but seemingly his big grey resistor next to "S" marking on top of black wire is not burnt and the stripes colour code is totally smth else than mine.
              • 31262
              some data
              • R_J
                • Jun 2012
                • 9609
                Here is the MAC97A6
                  • 31262
                  where does that microcontroller get 5v??
                  a zener diode??
                    • Jul 2011
                    • 6070
                    Originally posted by Sirgu
                    ***-This polypropylene capacitor needs to be replaced, right? As it`s capacitance (exactly -20% of 1.0uF) is lower than stated capacitance tolerance (±10%). Also resistance slightly out of range.
                    I would recommend replacing capacitor scenes you have one on hand
                    I would also recommend when you put the new resistor on the board do not mount it flush to the board leave a space between the board and the resistor so does not keep burning the board
                      Can you attach good clear high res straight shots of the whole top and bottom side of the board?
                      • Sirgu
                        • Nov 2013
                        • 24
                        • Estonia
                        Sure!
                        • Sirgu
                          • Nov 2013
                          • 24
                          • Estonia
                          a zener diode??
                          This little fellow?
                          • R_J
                            • Jun 2012
                            • 9609
                            I suspect there is a problem with the blanket or wiring to the blanket that caused the controller to fail. If the led's are flashing the same way as the video, it indicates there is no blanket connected, no load and no feedback/temp control. The ic is likely a PIC microcontroller
                              • Jul 2011
                              • 6070
                              I wonder if you could not test the blanket controller by using a 100 watt incandescent light bulb but you would probably need to light bulbs the terminal marked “S” that this might either common or temperature sensor but unless you reverse engineer it you would not know for sure
                              • Sirgu
                                • Nov 2013
                                • 24
                                • Estonia
                                Originally posted by R_J
                                I suspect there is a problem with the blanket or wiring to the blanket that caused the controller to fail. If the led's are flashing the same way as the video, it indicates there is no blanket connected, no load and no feedback/temp control. ...
                                Well that`s a yes and no.
                                -Yes, undoubtly I cannot be sure at this point that balnket is totally okay. All I know that its wiring is continuous circuit without any drawbacks while moving, bending blanket anyhow. But still suspicious about its wiring resistance change over time when material temperature rises or drops.
                                -On the other hand - No! Those LEDs flasing like that are not indicating the absence of blanket. I remember when the controller was still in working condition you could set the power and timer even though when blanket was not connected in socket with it. So I assume the turbulence of LEDs is a sign of ANY kind of issue on component basis - the situation were customary end-user should stop searching the cause of wrong use and trash the unit to avoid further dangers.
                                Unfortunately I`m not the one.
                                • Sirgu
                                  • Nov 2013
                                  • 24
                                  • Estonia
                                  Some notes:
                                  The printings on PCB in video read
                                  E199273
                                  PCEM-1
                                  94V-O
                                  ROHS
                                  which are the same as mine,
                                  then on the other edge
                                  KDA6-2015
                                  wheras mine reads
                                  KDA6-2012-04
                                  2013-06-03
                                  Then pause video at 5:20 and the colour code for the "S" big resistor seems like red-red-gold-silver = 2.2Ω ±10% ?
                                  (The rest set of big components look the same as far as eye can tell.)
                                  Could it funnily be like few years later they found out that 2.2Ω ±10% is suitable there instead of 10Ω ±5% ??
                                  • cliffpage
                                    Electric blanket resistor
                                    by cliffpage
                                    Electric blanket, can't find name on it anywhere, think label came off years ago. Double size, some years ago one side stopped working, I found a resistor had failed in the controller. As I don't use my side of the electric blanket I turned it round so my wife could use the good side. Now the resistor has gone in that side too. Well I think it is a resistor. The mains live wire goes on one end of this component and then the other end goes to the workings of the controller. pic of the component att'd . stamped in the metal is F400H250V . I don't know what F400H means. 250V presumably means 250...
                                    01-28-2023, 11:24 AM
                                  • ugamazing
                                    Assistance with identifying resistor value on 820-02918 A2992 board?
                                    by ugamazing
                                    Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                                    I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                                    09-06-2024, 08:33 AM
                                  • dutchgaucho
                                    Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
                                    by dutchgaucho
                                    Hi colleagues,
                                    Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
                                    Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
                                    On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
                                    11-09-2023, 11:27 AM
                                  • mrkmpn
                                    Help identifying resistor?
                                    by mrkmpn
                                    This resistor is on a small board the fan connects to in a Brother MFC L5900DW. The fan does not work, and when testing this resistor it shows no reading all the way from 4M ohms, down the a continuity test, so appears to have failed open.
                                    I've tried using a coupld of resistor calculators online, but I'm not sure which end is which on the resistor, and going both directions on the calculators I run into a value that doesn't have the correct color as an option.
                                    I, believe the colors are black gold violet black orange, but maybe I'm mistaken on one of th...
                                    01-19-2023, 11:09 AM
                                  • jinu_j
                                    Dell 2209WA - power supply - Fusible Resistor replacement
                                    by jinu_j
                                    Hi
                                    I am trying to repair an ancient Dell 2209WA Monitor which suddenly shut off with a pop sound. On investigation found that one of the fusible resistors had blown. Further investigation identified multiple components as faulty because of which the fusible resistor blew. Please refer the attached circuit diagram showing the components that were found to be damaged.
                                    1. FR950 - blown fusible resistor - 0.2 Ohm 1W
                                    2. Q950 - shorted Q950 MOSFET - 650V 10A N Channel Mosfet
                                    3. R835 - Blown Resistor - 20KOhm SMD resistor
                                    4. D930 - Shorted Schottkey Diode...
                                    05-03-2025, 10:51 PM
