Philips HTL2160 Soundbar bad audio crossover fix
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Bought this for my folks as a Christmas present what felt like recently but it's actually been 6 years already!
    The audio quality has successively become worse to the point that even my mom said it was unusable now, and I had to agree!
    I have had it open before to add a secondary coax to optical converter for an unrelated issue with audio dropouts when hooked up to a Dreambox that it had since it was new.
    Back then I noticed the craptastic choice of capacitors, and I was not really keen on replacing them all if it would not fix the issue, which I was doubting would be capacitor related.
    So I desoldered all the caps around the audio out connectors looking for a bad one but they all measured fine on my ESR meter.
    However I did find two bad bipolar electrolytic caps, they have the text: ZHN® (M)105°C CD71H 3.3uF 50v NP
    They are at positions C133 & C134 and are part of the audio crossover circuit. I think Nantung might be the manufacturer.
    Member DjKrish actually posted the service manual for it in his thread here.
    I cropped out the relevant section of the schematic as a picture below.
    I didn't think I had any bipolar caps but looking through my bins I actually found a couple WIMA MKS2 polyester film capacitors in an old Elfa bag with article number: 65-227-67
    They should be much more appropriate for the job except they where a bit small.
    Well not in size as you can judge from the photos but in capacitance: only 0.47uF.
    But since I had nothing to loose I put them in after some careful leg-bending wizardry and tried it out: to my surprise the set seemed to sound just fine again!
    Of course I can't remember fully well how it used to sound so it's not an apples to apples comparison.
    But maybe someone with experience on audio crossover circuits can chime in on how the loss of capacitance might effect the audio?
    P.S: I also replaced CE9 & CE3 as they measured a little high in ESR too, but nothing like C133 & C134.
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: Philips HTL2160 Soundbar bad audio crossover fix
    Hello.. may i ask if you have the service manual of this phillips soundbar? Can you share it with us? Check the speaker if it's still good, check the rubber suspension 6 years is a bit long for rubber suspensions..
    Never stop LEARNING because life never stops TEACHING!
    • R_J
      • Jun 2012
      • 9625
      Click on the link "service manual" in the post.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        By the looks of it they had to be sounding quite shitty with these values.
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • myavocation
          Pioneer SP-SB23W soundbar: no audio-out fix
          by myavocation
          This post is specific to the Pioneer SP-SB23W, also known as the "Andrew Jones Edition" soundbar. Andrew Jones being well known in the audiophile engineering industry for superb audio designs. My reason for stating this is if you are looking for an inexpensive 2.1 channel TV soundbar, this one rivals many 5.1 systems -- and without littering a room with speakers (sub-woofer is wireless, can be hidden anywhere). As a 9 year old device, they should be pretty cheap on the used market -- perhaps dirt cheap if no audio-out. Bought mine off of Craigslist cheap.
          So here's the...
          01-29-2022, 07:42 PM
        • zyklop
          Philips Soundbar TAB8507B/10 stopped working
          by zyklop
          Helllo everybody....
          i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
          Inbetween it has one time started, but no more yet.
          Is anybody who has schetatic or service maual ?!
          Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
          No thermal hotspots or something else controlled with thermal imaging cam.
          No reaction on remote control (function ok, can see it while glow into mobile-camera)
          No shorts to detect.
          ALso tested all reset procederes...
          07-07-2025, 05:08 AM
        • Domenicoo
          Boss Audio Crossover BX-45
          by Domenicoo
          Good morning, can anyone send me the "Boss audio BX-45" diagram or check the acronym of the Q3 and Q4 transistors. Because from the previous repair I find myself (Q3 2N5551) while (Q4 SS8050) and it doesn't seem correct to me. Can anyone help me thanks.
          05-29-2024, 04:12 AM
        • StasNep
          Philips HTL6140B/12 SoundBar no power
          by StasNep
          Hello
          I have got a defective Philips HTL6140B/12 SoundBar, no power from button or remote.
          The power supply is external and working correctly, even tried another one.
          Checked caps with esr meter and all seems ok.
          Checked various resistors and smd capacitors and they seems ok.
          Please help to diagnose this SoundBar.
          Thanks ...
          02-20-2022, 10:37 AM
