General question about oscilliscopes
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    What is it about scopes, that make them unique from multimeters? I ask that for two reasons based on my own experience with the last scope I had.
    1) I learned that getting a scope to read current is apparently not a trivial thing and you need some fairly expensive probes to be able to do it.
    2) When I tried to use the ground clip on the scope probe to read the signal over a single resistor by putting the ground lead on one side then the probe on the other side of the resistor, it immediately gave me some kind of a warning about over voltage I think ... I didn't leave the message up long enough I just saw the red and disconnected immediately... but I figured that the problem was that the ground lead has to be connected to a point on the circuit where there is no voltage at all and if you don't then it's all bad, but I don't understand why?
    sigpic
    • 31289
    Re: General question about oscilliscopes
    the scope is grounded,
    if what your testing is also grounded then you will get a voltage difference.
    a questionable trick is to forget the ground clips and put one probe on each side of the resistor.
    then use the math function to display A-B
    btw, always keep the probes on the x10 setting.
    to answer the first question, a meter just shows voltage or current.
    a scope shows it over time - like going from 2d to 3d
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I'm assuming you mean that you leave the ground clips connected to ground, then use two channels of the scope, one on each side of the resistor, then let the math function tell you the difference between the two nodes?
      Why is this trick "questionable"? is it somehow potentially unsafe?
      Right, but it seems that getting a scope to inject itself into a circuit as you can do with a multimeter .. is not something that scopes are really designed to do where as with a multimeter, you switch the hot lead over to the current port and then the meter is inserted into the circuit ... not something you can do - apparently - with a scope ... for some reason ...
      sigpic
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        No you don't connect the ground leads at all, it is not really questionable.
        But there are still voltage ratings that must be respected in this case too.
        A good primer on this is the following EEVBlog video:
        EEVblog #279 - How NOT To Blow Up Your Oscilloscope!
        Yes this is true, it is due to the way a scope works, it is very very different to a multimeter, they have different uses.
        The following video might give you an idea about the probes of a scope and what they really are:
        EEVblog #453 - Mysteries of x1 Oscilloscope Probes Revealed
          • 31289
          some usefull shit is here:
          https://www.youtube.com/user/Keysigh...loscope/videos
          https://www.youtube.com/user/RigolTech/videos
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Well that's 30 minutes of my life I'll never get back...
            I normally love that guy's videos but he really drug this one out.
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              YES, that video explained it perfectly. I had no idea that the ground lead on a scope was connected to earth ground. Of course in the case of a USB based software use only scope, it would be connected to the DC ground of the computer and not the earth but that being the case, connecting it anywhere else in the circuit that has voltage means you're shorting the computers ground with that voltage ... bad juju
              sigpic
                • 31289
                wrong.
                unless your using a laptop with no charger or other connection to a seperate mains powered device.
                laptop chargers capacitivly couple the output earth to the neutral input and ground - if it has one.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  OK, so if you were going to use a scope to look at the AC signal coming from an outlet, would you just leave the ground clip floating?
                  sigpic
                    • 31289
                    yes,
                    the scope is already connected to mains ground.
                    that's dangerous btw incase of a surge.
                    if you want to monitor mains you can use an old transformer to drop the voltage and still see the waveform.
                    infact to see how to use a scope on risky voltages - go watch some electroboom video's
                    you can also watch AC current without an electrical connection by wraping the ground clip around a wire a couple of turns and then clipping it to the probe tip - to create and inductive coupling.
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      ... sounds kind-a Mc Guiverie .... ish ....
                      sigpic
                        • 31289
                        it works
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Agreed, but this one and the other is very useful to keep in the back of your mind when you work with a scope.
                          Both of these can otherwise make you come-a-gutsa
                          • repair-it
                            Need advice testing a samsung power supply board with scope
                            by repair-it
                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                            07-12-2025, 11:00 AM
                          • budwich
                            ESD Diode on HDMI output of Yamaha a1050 RCVR
                            by budwich
                            I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                            I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                            09-11-2023, 12:21 PM
                          • howardc64
                            Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                            by howardc64
                            Samsung have been using this style LED connector for few years now
                            Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                            The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                            10-12-2025, 08:13 PM
                          • perfm2
                            Wson8 spring pin probe WORKS
                            by perfm2
                            I couldn't find anywhere on the internet where someone had discussed actually using one of these newer wson8 probes for flashing your Wson8 BIOS chip without removing it from the MB.
                            I recently ordered one to give it a shot and it actually worked quite well.
                            The tricky part is obviously keeping the probe pins in place on the exposed Wson8 pads of the MB while reading/writing.
                            I used a larger binder clip attached to the top of the probe to create a large flat surface, then added about 1lb of weight to it.
                            This aided greatly in allowing the probe to stay in place...
                            03-30-2023, 11:19 AM
                          • thinkcentre
                            Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
                            by thinkcentre
                            this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
                            What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
                            I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
                            11-09-2025, 12:39 PM
