Question on AC grounding - found an old device that has me confused
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    So I needed to find something that I don't use so I could cut the power cord off of it and use it in a project.
    So I found this ... Radio Shack looking device that apparently takes an external TV antenna as an input as well as RCA connections as inputs Then on the front you can choose to have it send out to the TV on channel 3 or 4 - though I have no idea what it does with the two different inputs...
    But anyway, I figured before I cut the cord and toss the device in the trash, I should bust it open and see if there's anything useful inside to add to the spare parts bins... and when I pulled the cover, I saw something that seemed really odd to me.
    It has a two-wire electrical cord on it, yet one of the wires, it connects to the metal portion of the chassis.
    Now I'm aware that the third lead on an electrical outlet is earth ground, and that it's common to use that third prong in an appliance so that if somehow the unit malfunctions and one of the other two leads gets loose or something, that it will divert current to earth ground so that if a person touches it, it won't prefer channeling current through the person.
    But to connect the return line from an AC outlet to the chassis ... isn't that potentially dangerous? I mean if someone was barefoot, standing on wet carpet and just picked up the unit, couldn't it electrocute them?
    Here are some pics.
    sigpic
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Question on AC grounding - found an old device that has me confused
    That's a death trap: if you reverse the AC plug the chassis will be live.
    Sure in the US & UK the plug it is polarized, but it is very common to have the live and neutral reversed in the outlet.
    The only thing I can think is that this is not original:
    If it is the company should be brought to justice for it, this is just crazy!
      • 31258
      nothing unusual back in the old days.
      they did the same shit with radio's and tv's in the u.s.
      does it have any datecodes on it?
      to answer the first question,
      it's a modulator, you put it between your antenna and tv set.
      then you feed composite video and line level audio into it from a vcr, camera or computer and it mixes it in with the other rf channels.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        OH I get it ... so then it broadcasts the VCR on channel 3 or 4 (based on the switch) but you can continue to go to other channels and they will just feed off the antenna. Is that right? Like the antenna is just passed through the device with an injected carrier on channel 3 or 4 which is the VCR.??
        sigpic
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          No, in the old days they used a wooden box, and plastic knobs.
          You could never touch the metal parts which had a 50% chance of being at mains potential.
          Today in modern designs this is called double insulated, it is signified with a mark with two squares inside each other.
          What these all have in common is that they are non-conductive, i.e. wood or plastic enclosures.
          It is completely forbidden to do this with a metal enclosure that the user can come in contact with!
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            I ripped the whole thing apart including taking out the circuit board and I don't see any numbers printed anywhere. That pic that I posted of the bottom of it is the only information about it given on the device itself.
            Here's a picture of the front of it.... but no relevant information there either.
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Apparently sometime between the early 80's and probably the late 90's it was not forbidden! Just no idea when they finally deemed the practice a big NO NO.
              sigpic
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                I can not imagine this would have ever been up to code in any country in the world at any point in time.
                EDIT: If you remove the heatshrink tubing from the wire that goes to the chassis is there at least a resistor in there?
                If it is then it will only give you some mild tingles when you touch it if it's connected with "wrong polarity"
                If not: then you will die if you touch it with "wrong polarity"
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  That's so funny ... I just cut the wire at the solder point and tossed it in the trash then I read your question and thought .... I dunno, that's a good question ... so I went and dug it out of the wastebasket and removed the heat shrink protector and sure enough, it's got a resistor in there. Value is 1.5 Megaohm according to my Fluke.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    OK so I was looking for ink type numbering on it somewhere and didn't see any, but then I removed the shielding cover and saw some numbering that would have part of the PCB silkscreen.
                    And as I was looking at the circuit board, all I saw was just analog components and thought ... how in the heck could they build something like this as small as it is without any ICs in it then when I took the bottom shield cover off of it, I saw the IC which I'm assuming is what sets up the channel injection frequency? There are definitely no crystals anywhere and it's lead-free which means it's probably newer than the '80s.
                    sigpic
                      • 31258
                      2010??
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        • Bulgaria
                        Only the ground terminal of an outlet can be connected to the chassis of a device, if it is not ClassII - Double insulated. This is wrong. Perhaps it relies on a plug with a 3rd dummy pin, so you cant reverse the plug. But it's still wrong. Replacing the plug or improperly wired outlet could lead to you being electrocuted. If these were our unpolarized sockets, there would be dead people.
                        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
                        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Here's the end of the cord that was on it
                          sigpic
                            • 31258
                            polarised - sort-of
                            • R_J
                              • Jun 2012
                              • 9607
                              I bet there is a resistor (1~5meg?) in that heat shrink between ground and the line neutral wire, and it is NOT directly connected. There is usually a capacitor (0.01µf) across the resistor as well but not always.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                No cap, but yes, there was a 1.5 Megaohm resistor in there.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  I think it's been determined that the inline 1.5 MΩ resistor would be sufficient at keeping people from dropping dead... if I had not ripped the thing completely apart, I might have run some tests on it... but under the assumption that it was just a straight connection, I wanted nothing to do with it ... other than harvest the cord for a different device and the transformer for an unknown future project.
                                  sigpic
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Yep, the high value resistor (see posts #8 and on) makes it "sorta ok" in the old days.
                                    It is still retarded though: because if there is a failure in the 20 cent Chinesium transformer that puts the primary across on the secondary and it finds a way over to the ground:
                                    Well then there is no low impedance return path to the breaker, so the fuse wont trip, and you will be dead if you touch the chassis.
                                    There can be other failures too that cause this, like a wire coming loose from that 0.01 cent crimp connector for example.
                                    All this stupid shit is to reduce interference in sensitive equipment that require a ground to work properly to begin with.
                                    Well here is an idea: use a fucking cord with aground then you numbwit manufacturers!
                                    -But ohh, what if the customer don't have a grounded outlet?
                                    Well that's his fucking problem then, isn't it?
                                      • 31258
                                      unlikely in a country that doesnt have *real* mans voltage.
                                      (yes, i spelt "mains" wrong! )
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8703
                                        They still make 2-prong extension cords and three conductor cords are less physically flexible and heavier than two conductor cords.
                                        The device also marks UL - so it theoretically is UL listed and thus tested for electrocution hazards. I didn't think RatShak was so bad to sell (under their name) things that could kill people, so I would have suspected the resistor or capacitor. As a device that actually creates radio frequencies they had to make it so that it doesn't generate too much RF, and the hope that the FCC symbol printed indicates it also passed part 15 rules...
                                        • vestaviascott
                                          Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                                          by vestaviascott
                                          I'm looking for the dial cord winding settings for this radio!
                                          I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                                          The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                                          06-07-2020, 08:36 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                          Using a 5 volt @ 12 amp switching power supply and two USB doctor volt / amp meter to three IPads on one power supply
                                          by sam_sam_sam
                                          I have been wanting to do this project for some time using a Mean-well switching power supply that I bought at least ten of them that were originally in a device that was abandoned for some reason they were listed new but removed from equipment that was never used
                                          I do not understand Mean-well the capacitor next to the voltage reference ic chip was a brand that is known for failure over time the other capacitors are brand name needless to say it got replaced before I even powered it on for the first time
                                          I used a four USB outlet and electrical plate that is made for...
                                          08-03-2024, 07:54 PM
                                        • zzpkcq@gmail.com
                                          Confused - I don’t want to order wrong thing
                                          by zzpkcq@gmail.com
                                          Going to replace op-amps in a guitar amp jcr072d
                                          so TI versions have suffix D IP etc. There didn’t seem to be an explanation of these anywhere. I think they indicate the physical pin characteristics but what do they represent- anyone have a list....
                                          05-29-2024, 03:06 PM
                                        • chth96
                                          Can I replace KME cap with Samxon GF cap?
                                          by chth96
                                          Hello.
                                          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                                          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                                          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                                          04-17-2024, 07:11 AM
