Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
  • Jumme
    • May 2015
    • 11
    • Denmark
    So. Had my Boston Acoustics subwoofer for 4 years and it had a terrible coil whine squeal from day one.
    I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
    Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module. Company now bankrupt and I cant stand the noise:
    Its a high pitch coil whine tone -it's terrible agonizing, when worst, I hear it clearly 4-5 m from the Sub (because sits in corner).
    It wines without RCA input. It whines in both active mode and stand by (inactive) mode, though changes a bit in frequency and often gets noticeably higher when in stand by!
    It whines if I move it to a completely different room/power source. Whine makes a weird "squeak squeak squeaaiik" and then dies, when power is pulled.
    I opened the sub, not being able to exactly pin point the source. I also didnt see any bulged caps, everything looks normal and smells new.
    Fun fact; Im pretty sure the sound dropped dramatically for a period when sub was upside down, being opened up.
    I have basic knowledge and repair skills like changing dead caps.
    Question is: Will I be fine with "drowning" the coils (I see at least 2) with eg. hot glue as a start?
    Or what to do? Thanks!!
    Diagram (Im pretty sure. Or very similar).
    • 31139
    Re: Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
    it's a coil or ceramic capacitor i suspect.
    if you take a plastic rod - like a bic pen, and prod any coils or big ceramic disk caps you should find the cause.
    if it's a coil you can use the old russian trick of coating it in wax,
    or you could smear epoxy or silicone on it.
    • Jumme
      • May 2015
      • 11
      • Denmark
      Thanks a lot, much appreciated. 'Prod any coils', how exactly?
      Sorry, English is not my first language.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5008
        • New Zealand
        Just poke/touch them with the insulated stick and see if the sound changes / stops when you press on it (gently).
        The noise is caused by the coil or other component vibrating at an audible frequency. If you poke it with a stick, it should dampen the vibrations and thus change/stop the noise.
        -David VanHorn
        • Jumme
          • May 2015
          • 11
          • Denmark
          Thanks, that makes good sense!
          Q: I read somewhere a long time ago that noise could be due to design fault; not being induced from the noisy component itself but rather somewhere else in the circuit. Thus tampering whit the component would not help, but changing eg a diode somewhere else would. Whats your opinion on this?
          Is that explanation only related to speaker humm (which my problem is definitely not)?
            • 31139
            without a schematic you cant really get into design aspects.
            • Jumme
              • May 2015
              • 11
              • Denmark
              I understand.
              The culprit is the coil wrapped in yellow paper or tape.
              This is to already reduce noise, correct? Its also covered in some guey but hard compound, I think that's called conformal coating. Even so its making an audible squeaky whine.
              Im pretty sure this is 230V in, and also the board that relays the sub in standby mode after a few minutes with no input. I have a suspicion whine is getting higher under load/after some time/warm, and worst when the unit then goes into stand by mode.
              When I press point A the sound wanishes or at least lowers a lot. When I press or poke points B the sound changes a bit but not as much as point A.
              Would it be enough to cover the ferrit with nail polish?
              I don't really have any RTV silikone or conformal coating. Just regular house hold stuff.
                • 31139
                oh, a transformer.
                it could be the ferite frame vibrating against the plastic inner part.
                do you have any discount stores near you?
                the type that sells all kinds of shit for a € ??
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5008
                  • New Zealand
                  Phenolic/SRPB circuit board?
                  Awful tan glue on everything?
                  I think the power supply is a victim of "cost optimisation"
                  Could be noisy from cheaply made & loose transformer, or a cheap circuit design that runs noisy anyway (?) But as mentioned, you'd need a schematic to begin trying to figure that out.
                  I'd go with putting some kind of epoxy etc in the transformer to hopefully stop it vibrating - I'm sure stj has some good ideas about that.
                  I'd personally also get rid of all that factory glue if you want the thing to last any appreciable time. (It goes corrosive/conductive over time and destroys electronics, God knows why they still use it. Oh right, planned obsolescence.)
                  -David VanHorn
                  • Jumme
                    • May 2015
                    • 11
                    • Denmark
                    oh, a transformer.
                    That depends on if you have something specific in mind??
                    I live in Denmark. Nothin is cheap here, not even in the cheap shops..
                    I think you're right, and that's exactly what Im hoping to do.
                    I'm not gonna spend a minute more than necessary, not knowing what Im doing. Im lucky if the unit survives this repair attempt.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      The ferrite on that transformer is not aligned well, that might be the issue.
                      But I would be really careful about realigning it as it could crack, and then it is game over.
                      Easiest might be to try to poke something under it, like a straw (sugrör) maybe that could work?
                      • Jumme
                        • May 2015
                        • 11
                        • Denmark
                        You mean, completely under the transformer? Between component and board?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Yup, if there is enough room to squeeze it under...
                          • Jumme
                            • May 2015
                            • 11
                            • Denmark
                            Thanks for your kind reply. There wasn't enough space around the transformer to get a straw in, so I choose another route:
                            I took some red varnish made specifically for coloring light bulbs, and gave the transformer a thick coating. After letting it drip and harden 24 hours, I also covered the transformer and the whole area in hot glue.
                            (SO FAR) the high pitched squeaking is completely gone and I am VERY happy!
                            Though it was probably not the correct coating solution, Its my opinion that you sometimes have to work with what ever you've got at hand. Thanks for all the help.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5008
                              • New Zealand
                              Great! The varnish should be all you need though, so you probably don't need the hot glue, and in fact it may be better not to have too much stuff covering everything, otherwise things could overheat.
                              -David VanHorn
                              • Jumme
                                • May 2015
                                • 11
                                • Denmark
                                I celebrated too soon. After only 6 hours of use the squeaky tone is back. Less than before but still noticeable.
                                Im probably gonna swap the unit for another 2. hand sub, but the repair was worth a shot.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5008
                                  • New Zealand
                                  I wonder if the varnish/glue melted from heat and loosened up.
                                  Can you try something that has a higher melting point than hot glue?
                                  Perhaps desolder the transformer and dip it in a high temperature varnish or epoxy.
                                  https://groupdiy.com/index.php?topic=70265.0 is interesting...
                                  -David VanHorn
                                  • staze
                                    Old Boston Acoustics subwoofer repair, BJT alternatives
                                    by staze
                                    Working on an older Boston Acoustics HPS10SE, and while verifying voltages, I noticed one of the PSU BJTs is getting excessively hot and the voltage is dropping out on the 15V rail. Not sure that's actually an issue (I don't have everything plugged in, so maybe something is saturating on the positive end and dragging that rail down and the BJT overheating is cutting out).
                                    But, figure I need to buy some NP capacitors from mouser anyway, so might as well replace these. They're a H669A and H649A. Pretty "meh". They test fine out of circuit, but I can't really put a load on...
                                    06-11-2024, 09:57 AM
                                    Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                                    by momaka
                                    Boston Acoustics fans, this thread might not be for you.
                                    A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                                    01-30-2022, 11:57 PM
                                  • jinu_j
                                    Boston Acoustics Soudware Subwoofer PowerSupply
                                    by jinu_j
                                    Hi Folks
                                    I am looking for help to trouble shoot my Boston Acoustics Soundware X subwoofer power PCB. The Circuit diagram is attached. I have checked the voltage across C3 (there is no capacitor as this is 240V board). The voltage i get is about 318V so i am assuming that the circuit behind that is working properly. But now I am not sure how to proceed. The circuit on the Left-hand side of the circuit is on a separate PCB that's soldered onto the board using the connector CN4 shown in the circuit diagram. So its difficult to trouble shoot components on that.
                                    There...
                                    08-20-2023, 02:08 AM
                                  • jinu_j
                                    How to test Subwoofer Amplifier with only a multimeter
                                    by jinu_j
                                    Hi Folks
                                    Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                    Problem
                                    I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                    Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                    Any advice would be appreciated...
                                    08-29-2024, 02:05 AM
                                  • Gjackson
                                    ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                                    by Gjackson
                                    Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                                    01-13-2024, 10:34 AM
