philips 55 oled 745 /12 3 blinks
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Hi this tv was fine until the owner moved to another address,
    it comes on in sby with 3 blinks and psu wont start up .
    tried a power on reset by holding down power on button on rear of tv and applying mains no luck
    first inspected for damage dry joints or loose foils no joy
    checked psu volts ,the 12v and 24v supplies should be switched on by the main board no volts
    i read on the net that the micro on some later philips may need a reflow ,removed psu checked all caps with esr meter all ok
    removed main board
    and heatsink on micro
    heated to 300 deg for 2 mins with solder station ,
    let it cool and no change
    anyone had experience on these oled philips ?
  • Diah
    • Feb 2013
    • 6460
    Re: philips 55 oled 745 /12 3 blinks
    from what you wrote.. it sounds the issue caused by transport.
    1- check the LEDs Ambilight if one broken ( damage )
    2- check if there visible damage on the panel module corners
    3- need to run the OLED Module as stand alone to clear there are no damage caused by transport.
    post please focused picture of the powerboards print label near to the Yellow sockets or listed over here what do you have at standby and when u turn on.
    • jimbofz
      • Apr 2013
      • 539
      • uk
      i didnt see any damage to casing or pcb boards
      this is the first oled philips i have looked at,when i removed the rear cover,i unplugged the amberlight to gain access ,should the tv work with amberlight unplugged?
      • Diah
        • Feb 2013
        • 6460
        YES & NO depend on Operating System ( Android or native Linux ) & the Amerlight Setting if they was set to start at TV booting or not ( at service menu )
        • jimbofz
          • Apr 2013
          • 539
          • uk
          heres the pics
          • Diah
            • Feb 2013
            • 6460
            remove the 24V socket between the PSU & T-con by unplug it from the T-CON side then test to turn on. give attention to the display if there will be horizontal line move from top to down
            • jimbofz
              • Apr 2013
              • 539
              • uk
              tried that sadly fault still same.
              i checked with the owner they only have the amerlight on when they choose ,so it wouldnt be on all the time.
              one thing i dont understand is where is the feed for the main backlights ?
              theres no sign of cables running through to feed the backlights
              surely these oled designs must still have a feed for backlights ,
              or am i missing something?
              • Diah
                • Feb 2013
                • 6460
                OLED doesn't have any backlight.. the color cells are LED which driven by the 24V from T-CON driver section.
                if you had the 24V disconnected and same error.. then you have issue at the Mainboards.
                • jimbofz
                  • Apr 2013
                  • 539
                  • uk
                  thankyou .
                  as i mentioned in my first post someone posted main board problem
                  that for him it was fixed with a reflow using solder station .
                  i will remove main board and check all caps with esr meter
                  then i will try a reflow again
                  • Diah
                    • Feb 2013
                    • 6460
                    thankyou .
                    but before go to mainboards .. you need first to test the PSU first to turn it on with out mainboards ( stand alone ) to see if all 12 & 24V stable and remain stable
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      thanks normally i would find the sby 3.3v supply
                      and link it to p/s on off
                      and panel on/off
                      via 100 ohm resistor
                      but theres only voltage in sby on 12v pin
                      can you advise best way to test psu (stand alone)
                      • Diah
                        • Feb 2013
                        • 6460
                        and panel on/off
                        hold on. i am little confused with yours V reading
                        9.5V STB goes High to 12V when the mainboards send 3.1V to PSU (on pin PS/ON) this is Okay.
                        24V = 12V after PSU ON as you write its 12V at STB !!!!!??? some things wrong.
                        Panel ON =5V .. did you check the other socket which it goes to T-CON if there 24V ????
                        T-CON ON = 0 so no signal from MB to turn on the 12V to T-CON ( at same socket of 24V to panel )
                        i think there are error at measurements.. or Typo
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          i know its confusing
                          but there are two plugs on psu
                          on one plug should be 24v and 12v supplies ,
                          now when in sby theres no volts at all on these pins so no 12v or 24v on this plug
                          now the top plug has two rows of 8 connections
                          six (which are marked on board as 12v )they provide 9.5v in sby mode
                          the two pins marked 24v on board produce 12v when in sby
                          Now when using remote ,you get 3 blinks ,when its blinking these voltages change
                          as shown in pic .
                          the panel on/off pin only produces volts when its blinking
                          this is what i dont understand,as normally the sby volts is present in sby
                          • Diah
                            • Feb 2013
                            • 6460
                            as shown in pic .
                            my question still with out answer... this pin i remarked with bold did the 24 line provide 24V when power on?? if not then you have issue on PSU
                            • Diah
                              • Feb 2013
                              • 6460
                              to clear it for you in simple words
                              9.5V are STB V. when main boards turn on this 9.5V will boost high to 12V and the 24V line on same socket will boost 24V-
                              then mainboards will send T-con ON ( now the 12V on the other socket ) you have no signal as 0 now
                              then main boards will send signal to panel on ( this will boost 24V on the other sockets.
                              you can slide out the 2 cable t-con/ON and panel/ ON from the socket at the PSU. and make 2 jumper between PS/ON ( 3.1V) to pins t-con/on and panel/on. turn on and see if you have 24V & 12V on the other socket.
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                thank you ,you are a very patient man
                                i now understand how it should opperate .i will give it a try
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  well the 12v and 24v supplies came up thats the good news
                                  the bad news
                                  is it looks to me to be a damaged panel
                                  ,i get a vertical white stripe with coloured lines on left side of screen approx 4cm wide and about 6cm from edge of panel,
                                  the rest of panel stays dark
                                  ive posted pics
                                  i only have a few seconds to focus camera before tv shuts down
                                  but its the coloured lines that make me think its the panel
                                  • Diah
                                    • Feb 2013
                                    • 6460
                                    put back the cable you slide out in place .. just disconnect the 2 sockets on the T-CON 12V & 24V then turn on.. see the mainboards remain on
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      i removed links and refitted the 2 connections to the plug
                                      then removed as you advised
                                      back to just 3 blinks
                                      • Diah
                                        • Feb 2013
                                        • 6460
                                        when you did the first test with jumpers, did you have on the same socket 24V?
                                        remember you wrote before it read 12 !!!
                                        the pins on the sockets labeled +24V_A
                                        • Diah
                                          Guide : Philips OLED TVs how to remove the protection mode NVM.EED
                                          by Diah
                                          OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
                                          not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
                                          Philips OLED TVs. we can switch the protection code to off via binary.
                                          - ropy it on empty usb stick and insert it while the tv off at USB 1
                                          -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the...
                                          04-21-2024, 03:21 PM
                                        • djordje
                                          Philips 55 oled 804/12 red light blink
                                          by djordje
                                          Hello all,
                                          I have Philips Oled 55 (804/12) with black screen and red light blink.
                                          I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                          Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                          When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                          My questions is what should i do next...
                                          01-03-2025, 04:00 PM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
