DSLR canon sl2 flash error 50
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. I repaired a canon sl2 for personal use, it had a bad sd card slot, bad battery connector, plus a little bit of water residue on the motherboard. The water damage seems to not have caused any damage, just salt deposits that have been cleaned. After repairing everything works except for the flash.
    When shooting with the flash turned on, i get a "wait" message once, then on the second try I get an error: e50. I have disassembled the front to get a look at the flash board, and everything seems good, the flash board also controls the shutter, which works, so it does have communication with the motherboard.
    I have probed the transistor that switches the transformer (that goes to the flash capacitor), it has battery voltage, but never gets switched. No voltage change was detected on the gate pin with an oscilloscope. It seems this gate pin is connected directly to the motherboard via a flex, I can trace it al the way to the motherboard connector, then I cant seem to find where it goes.
    Does anyone know what I should check? I don't have pictures, I have closed the camera and I am using it daily, so I don't want to open it again until I have some new ideas. But I can´t find schematics.
    What has to be working for the flash capacitor to charge up? Does it do any check before so? Maybe check the flash bulb somehow. Sorry, I have absolutely no experience with flashes.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: DSLR canon sl2 flash error 50
    error 50 = An electric control malfunction has been detected. maybe a corroded trace?
    • R_J
      • Jun 2012
      • 9624
      There are new flash charge boards available, did it look like this?
      • liquidzorch
        • Oct 2016
        • 135
        • mexico
        I would think that is the issue, since it had white spot from the water, but it was very little localized spotting. I cleaned it up and there seems to be no damage to any traces or components, but the key word is "seems". I wish I knew where to be looking.
        • liquidzorch
          • Oct 2016
          • 135
          • mexico
          That seems to be it. But I don't want to spend much on ordering one just to have it not be the issue. I would like to diagnose first, then if needed, order one.
            • 31288
            flash capacitors have limited life.
            but even if it's bad you should hear the invertor trying to charge it with a few hundred volts.
            be very carefull around those caps/boards - they hold a lot of energy for a long time!!
            • liquidzorch
              • Oct 2016
              • 135
              • mexico
              Yeah, it's not even trying to charge it. Thanks for the warning, I work on switching power supplies so I take my precautions. The camera also does not want to focus using the autofocus points (not live), I didn't notice this until now since I use it for videos, video uses live autofocus, a different system. I can still focus for photos with live view, just not normal shooting point mode (dont know the name). This could be something I connected wrong, but I'll check it next time I get a chance to open it up. For now it's working for what I need, videos.
              • liquidzorch
                • Oct 2016
                • 135
                • mexico
                I have opened it and made sure all connections are okay. I definitely has lost it's autofocus capability. I can still autofocus and take pictures in live view mode. But while using it's mirror, the autofocus just drives the lens in then out, then it won't take the picture.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  maybe there is something wrong with the af/mf switch? or something is off with the af sensor.
                  • liquidzorch
                    • Oct 2016
                    • 135
                    • mexico
                    There seems to be no damage to the phase detection auto focus flex cable. It is just the phase detection system. If I disconnect the phase detector flex, the lens will focus in our out but not both. If I connect it, it will focus in then out with one pulse of the button, but never actually focus.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8352
                      Check the second mirror that reflects to (and) the AF senor. Maybe their position changed?
                      watch this: https://www.youtube.com/watch?v=Tk-Y34nMkeY&t=174s
                      https://www.youtube.com/watch?v=MV7DizzkiiE&t=83s
                      • liquidzorch
                        • Oct 2016
                        • 135
                        • mexico
                        Thank you, great info. I have removed the phase detector, just to clean the outer glass. Mine is separated into 3 divisions, unlike that nikon in the video. But it did not fix the issue. The mirror that reflects on the to sensor is clean and does not seem to have any movement as to where it could have been vs where it is now, so I don't think it has moved. I'm guessing the processor that is under the SD slot (which my SD slot was very damaged) might be to blame. It sucks since I know the autofocus was working after fixing the SD slot, but after the first time I used it for photos, when getting home, I realized it no longer focused.
                        If there is a way to confirm that this processor is to blame (since I have both a missing flash signal and missing phase detect focus) I seem to be able to order from aliexpress. It is the F74966A, located underneath the SD slot, where someone seemed to have forced something in it since the slot was completely destroyed. I just don't know if this processor controls both things.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8352
                          I did check the error 50 thing and and everything I came across, they were changing a capacitor. Just Youtube "canon error 50". However that doesn't help your focus issue. Did you try a known good lens?
                          The F74966A is a system control processor (MCU). I would guess there should be another IC between it, the flash and AF... besides the MCU needs programming?
                          https://www.magiclantern.fm/forum/in...?topic=17596.0
                          • liquidzorch
                            • Oct 2016
                            • 135
                            • mexico
                            I own a t3i, and both lenses focus perfectly with the t3i. So I can rule out it being the lens. The MCU might need programming, so I guess that's out of the question. I can't seem to find what controls the flash switching transistor, I swept the whole board with a copper wire, and found no continuity to anything, so definitely it's one of the bga ic's. I have given up on the flash, I don't even plan on needing it, but the af was working and it is a must for photography.
                            • raider988
                              • Jul 2015
                              • 49
                              • Eu
                              If the base trace is disconnected, you won't go anywhere with continuity. Try to follow the trace visually.
                              • liquidzorch
                                • Oct 2016
                                • 135
                                • mexico
                                I can't. The trace goes from the flash board to the flex connector on the motherboard, then the trace from the motherboard goes into the second layer of the board. I does not come out the other side. I have continuity up until it goes unto the mid layer. Then no other component has continuity. It must go to a bga (guessing).
                                • zoltor
                                  Canon G3430 has a lightning flash after the firmware
                                  by zoltor
                                  Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
                                  09-17-2025, 12:40 AM
                                • abajor
                                  Canon VIXIA HF S10 A read data from inernal flash memory.
                                  by abajor
                                  Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                  Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                  The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                  I think my best shot is to figure out a way to read the internal flash memory outside...
                                  07-20-2024, 12:04 AM
                                • bamdad61
                                  Canon DR-1210C flash dump request
                                  by bamdad61
                                  Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
                                  04-15-2025, 02:43 PM
                                • ekozeko333
                                  [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                  by ekozeko333
                                  I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                  🔥 The Problem Started After Suspected ESD/PD Fault
                                  I experienced a power issue or ESD event through a USB-C charger
                                  After that, the NX20P5090 power switch was visibly burned and was replaced
                                  Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                  🧠 What I’ve Done So Far
                                  Flashed...
                                  06-21-2025, 02:48 AM
                                • corrize
                                  Nikon D800 camera - flash don’t work and capacitor don’t charge
                                  by corrize
                                  Hello, I'm stuck in troubleshooting…
                                  The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                  In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                  When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                  10-01-2022, 10:02 AM
