Please help with identify SOT23 transistor / diode
  • CornholioGSM
    • Feb 2014
    • 265
    • CZECH
    Hello
    i need to help with identify this sot-23 part.
    It is on lenovo laptop mainboard LV315KB - no schematics
    Qxxx marking on mobo - i mean that it will be transistor
  • petehall347
    • Jan 2015
    • 4445
    • United Kingdom
    Re: Please help with identify SOT23 transistor / diode
    maybe MMBD1505A
    • CornholioGSM
      • Feb 2014
      • 265
      • CZECH
      hmmm i have find this too but it is diode...confusing is "Q" on mainboard
      • R_J
        • Jun 2012
        • 9607
        It might be a AIC1747-15GJ3, SC70-3 package 1.5v output
          • 21960
          It might be a Panjit PPJA3415
          • CornholioGSM
            • Feb 2014
            • 265
            • CZECH
            Yesss...i have found another same on this mobo and it is really fet. Thank you
            • R_J
              • Jun 2012
              • 9607
              I agree it is a PJA3415, here is a picture of one
              • CornholioGSM
                • Feb 2014
                • 265
                • CZECH
                Superrr
                • InsertCoin
                  Relay Satronic MMI 810.1 bad diode & Transistor
                  by InsertCoin
                  Hello and happy new year ,
                  my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
                  There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
                  The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
                  I have made a diagram of the PCB and some measurements along some...
                  01-16-2024, 05:47 AM
                • elsomer
                  help to identify transistor msi ms-15ck1
                  by elsomer
                  hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
                  02-17-2025, 05:30 PM
                • harp
                  what is function of diode over power transistor?
                  by harp
                  I see on some schematic a diode over power transistor, and dont know is in it some trick to carry current, or what is the point?...
                  08-13-2025, 06:18 PM
                • hobostove
                  Corsair RM1000e - Help identify 5VSB Zener diode
                  by hobostove
                  Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                  Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                  There's a 22ohm resistor that's melted and open, but it still has the bands.
                  The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                  It looks like the diode connects the source and drain of a TNY284...
                  03-27-2025, 02:25 PM
                • jjne
                  AUO M270QAN01 - identify diode?
                  by jjne
                  I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
                  Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
                  ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
                  01-24-2024, 08:39 PM
