Philips 42" TV 42PFL3603D/F7 clicks but No LCD Backlight
  • jason123
    • Oct 2015
    • 1154
    Hi folks,
    I'm suspecting the actual CCFL or EFL being bad, just not sure how to test, but would like to confirm.
    TV clicks upon plugging in AC. When I press the PWR ON button, clicks again.
    LED on the Main board comes on green (Assuming some diagnostics), Blue LED on the TCON comes on also when I turn the TV on, but turns off about 30 seconds later.
    3V3 ST is on (3.26 V)
    Standy 3.3 V (off) when I press power button goes to 0.16 V
    12Vssb is 11.75 V (on), 0.18 V (0ff)
    +12Voud is 13.8V (on) ~ 0V off
    -12Voud is -12.4 V (On) ~0V off
    INV-on is 3.00 V (on), 0.115 (off)
    Seems that it's in order from voltages standpoint. No bulging caps
    I don't have a high voltage source to test the CCFL / EFL
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Philips 42" TV 42PFL3603D/F7 clicks but No LCD Backlight
    Can you check the value and ESR of C700
    • jason123
      • Oct 2015
      • 1154
      ~40 miliOhm
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you got the 24V supply?
        • jason123
          • Oct 2015
          • 1154
          Yes 23.4v. Though nothing (connector) connects to it
            If you turn on the TV in the dark room, do you see the backlights even flash on for seconds?
            Not all lamps will be all bad at the same time, the good lamps should still come on then if the circuit detects any bad lamp/lamps the inverter circuit will shutdown.
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              Look under the inverter transformer for bad solder joints, these are notorious for them.
              Touch them all up while you have the power supply out.
              • jason123
                • Oct 2015
                • 1154
                No light at all from the panel.
                • jason123
                  • Oct 2015
                  • 1154
                  Looks fairly clean. Touched up the solder.. no change
                  • R_J
                    • Jun 2012
                    • 9624
                    Have you checked the inverter distribution board, I don't see it in your picture, follow the high voltage cables from the power supply inverter to the inverter boards
                    • jason123
                      • Oct 2015
                      • 1154
                      I am assuming these distribution boards are inside the panel...haven't opened it yet
                      • jason123
                        • Oct 2015
                        • 1154
                        One ccfl completely disconnected. Let's see if that does it
                        • jason123
                          • Oct 2015
                          • 1154
                          Not it!
                          • R_J
                            • Jun 2012
                            • 9624
                            Do they try to light? How are all the other connections to the lamps?
                            • jason123
                              • Oct 2015
                              • 1154
                              I went through all and solder them all. They don't try to light up at all
                              • jason123
                                • Oct 2015
                                • 1154
                                I guess it's got to be power supply.. though I can't verify.. Time for the dump
                                • R_J
                                  • Jun 2012
                                  • 9624
                                  Do you have the BL_ON_OFF voltage on CN7, pin-5? Check the voltages for U401, pin 20 should be +12v; pin 21/22 +5v
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    I'd give it a good try at fixing, Philips usually has a very good picture quality.
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      Did you check the fuse on the inverter board?
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        I’ve had cold solder joints on the inverter and bad CCFL connections on this model and the 47” UK version.
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • chestercc
                                          Philips TV Backlight Repair
                                          by chestercc
                                          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                                          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                                          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                                          11-18-2022, 01:15 PM
                                        • ohren
                                          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                                          by ohren
                                          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                                          The setup is basically:
                                          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                                          Transistor is switching the 3.5 V supply on the power board....
                                          12-05-2024, 11:10 AM
                                        • Patrick501
                                          Philips 55PUS6704 no picture, backlight ok
                                          by Patrick501
                                          I'd like to repair a Philips 55PUS6704.
                                          It turns on and you can see the backlight, hear the sound but no picture.
                                          When I disconnect one of the T-con cables, half of the screen turns white.
                                          right cable disconnected= right side white
                                          left cable disconnected= left side white
                                          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
                                          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
                                          Also you can notice one single...
                                          11-12-2025, 08:46 AM
                                          Design of CCFL Backlight Inverters with Frame & Bar Cores
                                          Summary
                                          Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
                                          The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
                                          The frame and bar ferrite cores, described in this brochure, are especially designed...
                                          10-07-2024, 04:26 AM
