Samsung UN55JU7500F
  • anupkg1985
    • Sep 2020
    • 180
    Samsung UN55JU7500F
    I have got a 55 inch Samsung curved tv, it doesn't power on. There is no backlight, audio or video. I could see backlight on if mainboard is disconnected from smps board. I suspect the main board is culprit. Below are the readings I get on board -
    Stand by voltage 13V
    PS ON 4.5V
    BLU ON 3V
    OD ON/OFF 3.6V
    ANA DIM 3.3V
    OD Level 3.6V
    Also the voltage on main caps is jumping from 391V to 168V continuously.
    Re: Samsung UN55JU7500F
    1) So if you run the power supply board by itself, does the PFC Boosted Voltage stay at 390VDC?
    2) If all boards are connected. When TV is turned on, does the PSON stay at 4.5V or it jumps up and down?
    3) Can we see the pictures of the whole backside of the TV showing all boards?
    • anupkg1985
      • Sep 2020
      • 180
      Hi Budm,
      Thanks for reply. Pfc voltage stays 391v if main board is disconnected. PS on is jumping between 3.3V to 0.09V when are boards are in place. I'll attach photo of the entire back of the tv.
      • anupkg1985
        • Sep 2020
        • 180
        Back side of the tv with all boards connected. I have removed the heat sink on main board. It also has a one connect box separately.
        • anupkg1985
          • Sep 2020
          • 180
          Also noticed that 12.82V jumping to 9.2V and back may due to pfc on and off. Also there 3.2V present on FAIL_COUNT pin of the smps board. If I disconnect the main board then FAIL_COUNT voltage drops to 0.7v
          • anupkg1985
            • Sep 2020
            • 180
            Anyone to help on this?
            • neilc6
              • Nov 2015
              • 1550
              If the standby voltages are stable and PS-ON signal is stable, main board is suspect if TV doesn't turn on.
              • anupkg1985
                • Sep 2020
                • 180
                While main board is disconnected, shorting PS_ON pin with GND makes the backlight to turn off and pfc voltage goes down to 168V also other voltages drops. Does that indicates something wrong with PS?
                • neilc6
                  • Nov 2015
                  • 1550
                  PS_ON is active high with a pull up resistor. Shorting it turns it off.
                  • anupkg1985
                    • Sep 2020
                    • 180
                    So if it turns off then I should be getting 0v on 13v pin however it just drops to 9.2V. Also there would be some buzzing noise when I short PS-ON pin. Not sure if its really mainboard or ps itself. Could someone help to diagnose mainboard as well.
                    • neilc6
                      • Nov 2015
                      • 1550
                      I believe 9.2V is the standby voltage and gets boosted to 13V when turned on. Power supply is behaving as expected.
                      • anupkg1985
                        • Sep 2020
                        • 180
                        Posting more findings -
                        1. Getting fluctuating voltage from 0.6V to 3.6V on SW_POWER test point near IC 301 which I believe is an eeprom (part number S24C51) hence the VCC of IC is also fluctuating. However if I remove PS_ON pin on the connector keeping other pins connected, voltage is stable 3.6V to eeprom vcc.
                        2. Also found the PIN#10 of IC1505_RS (part number MP221EC) connected to PS_ON pin on the connector, which is also fluctuating.
                        Can someone help to figure out or isolate the issue on the main board? I'm not able to find the mainboard replacement on shopjimmy or ebay, also whatever is available is very costly above 100 bucks.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          It looks like two of those IC legs (5 & 6) are soldered together. (S24C51.jpg (1 of 2))
                          • anupkg1985
                            • Sep 2020
                            • 180
                            No its not, I was trying to reset it using shorting sda pin to GND however no luck. But those two pins are not shorted together.
                            • anupkg1985
                              • Sep 2020
                              • 180
                              Could someone provide the schematics or troubleshooting guide for Samsung BN94-10098A Main Board?
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                              • ohren
                                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                by ohren
                                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                The models launched in 2018 and 2019 respectively....
                                09-08-2023, 05:24 PM
                              • C152Heavy
                                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                by C152Heavy
                                Summary for TL-DR readers:
                                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                • Have read ALL applicable threads
                                • C1818 and CP820 replaced as low hanging fruit
                                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                • VCC pin (18) of PFC...
                                01-11-2023, 02:53 PM
                                09-07-2024, 05:50 AM
