Vizio VO42L, white logo, no backlight, no picture
  • Daveleone
    • Apr 2016
    • 267
    Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
    From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
    I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
    Main board:
    Continuity across F1 & F2 = GOOD
    F1 = 5.12v
    F2 = 11.57v
    PSU Connector 1 (J21?):
    24V = 24v
    SGND = 0v
    A = 0v
    B = 0v
    C = 0v
    PSU Connector 2 (J22?):
    PSON= 3.27v
    12V = 11.57v
    SGND = 0v
    5VSB = 5.16v
    A = 0v
    B = 0v
    C = 0v
    Inverter:
    Continuity across F1 = GOOD
    Left leg @ Q7 & Q9 = cycles between 0v-1.2v
    Middle leg @ Q7 & Q9 = 24.96v
    Right leg @ Q7 & Q9 = cycles between 0v-1.2v
    Top leg @ Q8 & Q10 = 0v
    Middle leg @ Q8 & Q10 = cycles between 0v-1.2v
    Bottom leg @ Q8 & Q10 = 0v
    Voltages @ connectors to CFLs = 0v
    Do you think I got a second bad inverter? Or do I have a bad main board? What should I try next?
    Thanks in advance for your help!
    --Dave
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio VO42L, white logo, no backlight, no picture
    What voltages do you have on the Inverter Board connector
    1, 2, 3, 4 & 5 =
    6, 7, 8, 9 & 10 =
    11 =
    12 =
    13 =
    14 =
    Is the white fuse F1 showing continuity?
    • Daveleone
      • Apr 2016
      • 267
      1, 2, 3, 4 & 5 =
      6, 7, 8, 9 & 10 =
      11 =
      12 =
      13 =
      14 =
      That connector is directly connected to PSU Connector 1 (J21?), so:
      1-5 = 24v
      6-14 = 0v
      I double checked the voltages just to be sure the cable was good.
      F1 does have continuity.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Can you provide a close up of what's given in the red box please.
        The Inverter On signal appears to be missing.
        • Daveleone
          • Apr 2016
          • 267
          Yes, I think you're right.
          12: VOnOff is 0V
          What should that voltage be? Should I jumper it to some other pin to see if the backlight will come on?
          Thanks!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            You need to check where the VonOff signal comes from. I would expect it to be around 3V when VonOff = On
            Have you checked the two fuses shown in photo 6 of 11 in your first post.
            • Daveleone
              • Apr 2016
              • 267
              That wire is connected to "B" on the PSU Connector 1 (J21?) (photo 3 of 11 in my first post)
              Main board:
              F1 = 5.12v
              F2 = 11.57v
              • Daveleone
                • Apr 2016
                • 267
                I jumpered PSU Connector 2 (J22?) 5VSB to PSU Connector 2 "B" (which connects to Inverter Connector VOnOff). The backlight comes on with both inverters that I have. So, the main board appears to be the problem.
                Anything else I should check on the main board? Or should I just order a replacement?
                  I would start checking LDO Voltage Regulator IC's on the main board.
                  There is Main board repair kit and EEPROM also.
                  https://www.shopjimmy.com/search.php...ery=Vizio+VO42
                  • Daveleone
                    • Apr 2016
                    • 267
                    Just to close this out, I was able to get a replacement main board for $20 from ElectroParts, so I decided to order it and save my time (instead of working on the defective board). The replacement main board worked.
                    • nomoresonys
                      • 12284
                      • U.S.
                      Thanks for the feedback Dave.
                      • Super360
                        Vizio E701i-A3 Vizio logo flashing then turns off
                        by Super360
                        Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                        07-25-2024, 07:06 PM
                      • x_orange90_x
                        Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                        by x_orange90_x
                        I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                        12-28-2023, 06:26 AM
                      • JaquesPratt
                        Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                        by JaquesPratt
                        I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                        This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                        07-16-2024, 01:04 AM
                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 07:46 AM
                        MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                        This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-06-2024, 07:29 AM
