Nichicon PC(M) replacement
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Hello, Iam working on my dads EEC-IV computer from his 94 Lightning Pickup, it has bad nichicon PC(M) 2x47uf 16v and 1 10uf 63v what would be a decent replacement? I noticed Panasonic makes the General purpose NHG series any they are rated to 105c whould those be okay?
    also on the bottom left of the board capacitor I see I guess a diode or something, it has no markings and had electrolite under it which i cleaned, did that cap possibly short it out?
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: Nichicon PC(M) replacement
    Heres a picture of the bad cap next to what I think is a diode? I see a black pool under it but is that electrolyte from the cap or the diode?
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      It could be glue but then you would expect the same under other components so I guess not.
      It looks like the board is conformally coated, maybe the electrolyte somehow dissolved that and created that mess...
      As for the cap choice I don't know because I did not find a datasheet for the Nichicon PC.
      • mockingbird
        • Dec 2008
        • 5484
        Here is a datasheet for Nichicon PC...
        If you want to be strict about it, you could use an automotive-grade cap like RX30 or similar.
        https://www.badcaps.net/forum/attach...1&d=1614021069
        • BigTroll
          • Sep 2010
          • 1317
          • LAMBDA SOND
          I found these but 50v vs 16v for the original capacitance is the same.
          https://www.mouser.com/ProductDetail...ysgx62ww%3D%3D
          I also found some guy trying the WURTH alluminum polymer caps, would those be a better choice since they wont ever leak again or would you go with the rubycons? Thank you for the help!
            • 31122
            i would try to see what the caps do.
            are they just smoothing dc, or on a dc/dc convertor output? or signal blocking?
            • DaveHarry
              Seeking replacement for EOL Nichicon PLV1J220MCL1TD. Found APAQ and ELITE (CHINSAN)
              by DaveHarry
              Hi group,
              I am looking for a replacement for Nichicon PLV1J220MCL1TD (22uF, 63V, Conductive Poymer Aluminum Solid Electrolytic, 8x9 but we can go up to 8x11).
              While searching, I found some APAQ and ELITE replacements that would fit on our products (APAQ ARHA series and ELITE UGT and UPD series).
              How good are these brand/series and what other alternative would you recommend? I've searched the big name already and didn't find an equivalent.
              Thanks!
              05-27-2024, 08:08 AM
            • reformatt
              Macbook Air M2 A2681 Kernel panics after screen replacement
              by reformatt
              Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
              It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
              07-31-2025, 08:37 PM
            • nick3092
              Mid/late 80's Nichicon Yellow Caps
              by nick3092
              I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
              08-28-2022, 03:56 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
            • ezenia
              PS4 controller left stick potentiometer replacement issue
              by ezenia
              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
              09-30-2023, 02:19 PM
