Heres a fun one. 630w dual bulb Ceramic Metal Halide Transformer
  • loki3xb
    • Feb 2021
    • 3
    • US
    Hey guys!! Im new here and found you just though lots of google searching.
    I found out this is a transformer but I was hoping someone here could give more information. I think its the part thats bad, the fixture is only lighting 1 lamp and youll see from the pictures there is some black on the glue.
    Speaking of glue... Any best practices for how to remove it?
    https://ibb.co/qJYF3zC
    https://ibb.co/DVc4nKf
    https://ibb.co/MfpPCmx
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Heres a fun one. 630w dual bulb Ceramic Metal Halide Transformer
    Please, use the attachments of the board.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • loki3xb
      • Feb 2021
      • 3
      • US
      Im not sure what that means. Can you please explain?
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Go to advanced mode, then click on "Manage Attachments".
        Arc A770 16 GB
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          I attached your photo to the OP.
          It looks to me like a component near the transformer has exploded.
          Maybe that resistor but it is not really visible in your picture.
          • R_J
            • Jun 2012
            • 9638
            I would also check that green component, it might be a mov that exploded. The transformer is likely ok.
            • Wolf1977
              dead transformer on ceramic oven
              by Wolf1977
              hi in ceramic oven the transformer is damaged
              and writes
              2x115v/2x12v/6VA 50-60hz ta105/f
              can you suggest me a compatible transformer ;
              i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
              09-02-2023, 03:43 PM
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
            • learnmore
              Help choosing replacement transformer for Levoit 600S SMPS
              by learnmore
              Hello Community,
              I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
              Peace
              LM...
              11-04-2025, 09:35 AM
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
