LG 50ps60 Plasma Grainy/Fuzzy Horizontal
  • starmaxpc
    • Oct 2009
    • 117
    hi fellas. i picked a freebie locally it is a lg 50 inch plasma with display issue. tv turns on i can navigate thru the side button controls volume is good channel up down etc. looking thru the other postings on this system there seems to be a variance of different issues with this model. any direction as what would cause this display issue. sorry my pics are sideways as i don't have the stand and the darn thing weighs a ton. Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50ps60 Plasma Grainy/Fuzzy Horizontal
    Looks like and older one, I’ve had mainboard failures countless amounts of times with this model-BGA solder fails on the CPU due to poor cooling, disconnect the main LVDS cable and on the control board P6 or Auto Gen you need to jumper pins 1 and 2 and the display will show a series of different colours. Let us know what happens.
    • R_J
      • Jun 2012
      • 9578
      I would try re-seating the flex cables between the panel and the buffer boards, I would inspect them for damage incase the last person was not careful with them. That might clear up some of the lines, If not I would check the buffer ic's for shorts.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Buffers I’ve seen mainly cause no image at all when they fail on these I’ve had a few but wouldn’t rule it out, doubt the set would run with both cards that bad.
        • starmaxpc
          • Oct 2009
          • 117
          tried a re-seat on the flex cables. no change.
          • starmaxpc
            • Oct 2009
            • 117
            Originally posted by ReeceyBurger123
            Looks like and older one, I've had mainboard failures countless amounts of times with this model-BGA solder fails on the CPU due to poor cooling, disconnect the main LVDS cable and on the control board P6 or Auto Gen you need to jumper pins 1 and 2 and the display will show a series of different colours. Let us know what happens.
            just to confirm.... if i have marked the right components..
            main cable circled blue
            pins 1 and 2 marked in red.
            thanks.
            • chrismurphy
              • May 2014
              • 251
              • australia
              z sus failure
              • CyberNinja
                Samsung plasma 50" TV, model PN50C540G3F, has black horizontal lines
                by CyberNinja
                First, the black horizontal lines even overlay the TV's menu. Does this behavior indicate that it's the plasma panel that's defective? If not for the black lines, the TV works just fine. I've cleaned the 6 connectors between the panel and the Y-buffer board, causing no change in the black lines. Visually, the 12 ICs on the Y-buffer look brand new (no holes, etc.). I put my fluke meter in continuity mode and tried to perform the "short" test on the 6 panel ports and found many shorts. But I don't think I'm doing the "short" test correctly and I'm hoping someone can provide guidance....
                01-10-2021, 09:38 PM
              • Ihandyrepair
                Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                by Ihandyrepair
                Hi guys
                I just started fixing 4k TV few months ago. so I am still learning a lot
                I got this tv from friend complaint is ghosting or horizontal lines on image.
                never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                then it started to show the ghosting white image.
                I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                it has 3 thin small boards at the bottom of the...
                12-05-2022, 04:18 PM
              • jmandawg
                Insignia plasma n2-42p650a11 black horizontal lines
                by jmandawg
                Hi I picked this up on the side of the road. It has black horizontal lines on the display. It's it repairable?
                I looked for bulging caps but didn't see any.
                Thanks...
                04-23-2021, 04:42 AM
              • kotel studios
                Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                by kotel studios
                Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                08-06-2025, 02:07 AM
              • busted&disgusted
                Panasonic Plasma TC-P50ST30 Horizontal Black Lines
                by busted&disgusted
                I have a 2011 Panasonic Plasma HD 3D Viera model notorious for the SC board failure. As per a Google for the dreaded 14 blink code I discovered from info on this forum about isolating suspect boards by disconnecting the power cables and using an ohmmeter on the power terminals and this led me to the SC board. I had it repaired by a nearby technician who replaced the shorted transistors and before I got the board back I wondered if any of the buffer boards are damaged and a YouTube showed how to test these by using the ohmmeter and removing the copper colored ribbon cables to the display and use...
                10-05-2019, 09:51 AM
