LC-52D64U (Sharp Aquos) component ID
  • Plane Nuts
    • May 2019
    • 52
    I picked up a Sony LC-52D64U (Sharp Aquos 52 in) TV that will not turn on, while testing Main P/S board DPS-304BP-1 I accidently shorted out a resistor and unfortunately it does not have the lines on it so I don't know its resistance. it is R7641 in the attached drawing and have attached pictures of what is left in case someone familiar with these resistors can identify it or has one of these boards and can check what is it. would like to know resistance and what type it is if it is special, and will a regular resistor work.
    After looking at the pictures on the computer and not my phone looks like 0.1 ohms does everyone agree?
  • R_J
    • Jun 2012
    • 9579
    Re: LC-52D64U (Sharp Aquos) component ID
    Looks like 0.1Ω, .5 watt fusible flame proof, If the resistor is open, I suspect Q7601, Q7602 are also shorted
    • Plane Nuts
      • May 2019
      • 52
      Thank-you R_J,
      I Replaced the part, and luckily it did not blow anything else. I tracked the main issue with the TV not turning on to a shorted mofset P/N K3706, I put in a P/N 13N50CF, and at that point the TV would try to turn on but would shut down after about 5 seconds. After a few tries it shorted out again. I am wondering if it is because the MOSFET specs was too far off what is supposed to be there or there is something else loading it to the point of shorting out. The only K3706 I have found are from china and would take weeks to get here, any common equivalent available? or what to look for to find a good equivalent? What can I look for while I am waiting for parts to help identify on why it shorts out. NOte that I also found Q7505 (P/N J655) next to it also shorted out.
      I have attached pictures of the board, note the problem mofset is removed
      • R_J
        • Jun 2012
        • 9579
        I thought you were still repairing the power supply, I see you are now repairing the backlight inverter.
        If the mosfet was shorted D or S to Gate, then the drive components or drive ic is likely bad as well.
        Q7505 might have been damaged when Q7506 shorted.
        • Plane Nuts
          • May 2019
          • 52
          Yes both Q7506A and Q7505A were both shorted out between the three Pins (S, D and Gate) so what would cause it to short out like that?
          • scubacamper
            Sharp Aquos LC-70C6400U Half Screen Dark
            by scubacamper
            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
            05-03-2025, 12:19 PM
          • sefoster
            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
            by sefoster
            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
            11-20-2022, 09:29 AM
          • jonah1024
            Sharp Aquos LC-40UG7252E LCD TV burn in?
            by jonah1024
            Hello!
            I'm a few days old into this TV screens repair universe so please bear with me.
            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
            - I did a factory reset as well...
            07-16-2024, 04:23 AM
          • reessi
            Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
            by reessi
            Hello:
            I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
            I started on the ACER:
            Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
            All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
            I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
            10-29-2024, 11:31 AM
          • socketa
            A Shorted wirewound resistor?
            by socketa
            This resistor is from an ATX APFC PSU that connects bridge rectifier negative to primary capacitor negative
            I think that it's a current sensing resistor for the APFC
            Is it correct that it's color code indicates that it should be 0.47 ohms?
            I measured it to be around 0.08 oms
            The PSU blew up (visible arc flash) after problems with a powerstrip, but i got it working now after replacing the 10A fuse, rectifier, etc and removing/shorting the APFC diode locations and using a jumper in place of this PFC current sensing resistor
            I don't think that APFC likes being connected...
            05-15-2022, 04:50 PM
