Fatman iTube (aka Dared MP-5) tube-buffered gainclone upgrades
  • linuxguru
    • Apr 2005
    • 1564
    The Fatman iTube (OEM Dared, which also sold its own-branded version, the Dared MP-5) is a tube-buffered gainclone first introduced c.2005, to target the iPod market with a bookshelf tube setup. It became a huge success over the next ~15 years, selling over ~100k units worldwide to a market where it was often their first introduction to vacuum-tube audio on a budget.
    http://www.enjoythemusic.com/magazin.../dared_mp5.htm
    One of the Fatman versions landed up for auditioning a few days ago, and I must say that I was impressed with its form-factor, pricing, build quality, finish and durability. However, there were some minor drawbacks in its audio quality - very bass-shy (like a lot of tube gear) and with a fair amount of glare/brightness in the upper-mids (not uncommon in chipamps/gainclones). In other words, it had some of the faults of both vacuum-tubes and chipamps.
    I tried to address the glare issue first, since I don't really need a thumping bass response (I don't listen much to heavy-metal, disco, hip-hop and similar genres anyway). I generally prefer neutrality, with full-bodied mids for vocals and so on, and the MP-5 seemed to be a great candidate for upgrades.
    Opened it up, and noticed that almost all resistors were generic 0.5W CFR, and all electrolytics were generic Chinese 105c TL brand. I swapped out the electrolytics first:
    3x 2200uF/35V TL -> 3x 2200uF/35V Elna RKD (chipamp rail bypass, heater/aux DC bypass)
    1x 100uF/250V TL -> 1x 100uF/400V Rubycon AXW (cathode-follower B+)
    1x 47uF/400V TL -> 1x 33uF/350V Rubycon YK (B+ for magic-eye VU meter, value not critical)
    2x interstage coupling capacitors were 1uF/200V, possibly MKT polyesters, and I had excellent MKP substitutes from Asahi Kasei, so that was the next upgrade:
    2x 1uF/200V/10% generic MKT ->2x 1uF/250V/5% Asahi Kasei MKP
    Finally, a couple of resistor upgrades. The input series resistor was a generic 10k/0.5W CFR, which I replaced with a non-magnetic PRP 10k/0.25W/25 ppm thermal-coefficient. This is in the signal path, so it's critical that it's non-magnetic to reduce EMI/RFI pickup.
    The second was in the chipamp voltage-series feedback network - a 560E/0.5W generic CFR in the lower leg of an 18K/560E voltage divider. It's critical for sonics to have an extremely linear resistor here, with very low 2nd- and higher-order voltage coefficient of resistance. Only wire-wounds make the cut, so I swapped in a Vishay 510E/1W wire-wound here - the slightly lower value alters the default chipamp gain by about 10%, which doesn't matter.
    2x 10k/0.5W generic CFR -> 2x 10k/0.25W/25ppm non-magnetic PRP
    2x 560E/0.5W generic CFR -> 2x 510E/1W Vishay wirewound.
    Checked everything, and there was a generic A100k carbon-track pot as the volume control. I left that alone, since I didn't have a quality pot like an Alps for a direct upgrade, and 100k wirewound pots are a rare item - it's a future to-do upgrade.
    For now, these upgrades were sufficient to completely eliminate the glare and make it more neutral, but still warm, transparent, detailed and full-bodied,
    Here's a pic of the circuit board after the upgrades:
  • void_ptr
    Bought a bricked 15" generic LCD TV and need firmware
    by void_ptr
    Hi, folks. Thanks for all the work on this site. I am looking for help with a TV. I have a secondhand 15" LCD TV that won't turn on. The board is listed as CV3553M_B24_10 and the panel is a MG1561B01-1. I just want to use it as a portable gamer display and maybe a media player. The branding is "Emerson ETC-1500N" but I know it is a generic Chinese TV. Searching on the internet for compatible files turns up zilch and the ai bots aren't much help. Can someone please help me locate the fw for this TV?
    10-03-2025, 05:23 PM
  • BleedCap
    OLD Socket 478 custom bracket + NEW generic cooler
    by BleedCap
    I already posted this on vogons.
    Its a 3d printed custom bracket for socket 478.
    I used this AM4 bracket as a base design.
    Its to be use with cheap generic clip based cpu cooler.
    Reason for doing this is:
    - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
    - New generic cooler is cheaper and can use bigger fan (less noise)
    I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
    The processor that I was using is P4 2.4Ghz prescott....
    11-05-2023, 08:09 PM
  • linuxrunner
    generic diffuser?
    by linuxrunner
    i have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
    i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
    i checked Samsung parts site but they don't...
    08-26-2022, 10:52 AM
  • Dannyx
    Using car key fob as generic remote control
    by Dannyx
    Good day folks. It's been a while since I've DIY-d anything, so the other day I was thinking if it's possible to use the key fob of my car as a remote for other automation stuff. I have quite a few generic 433Mhz remotes and modules I picked up on Ali for various projects, but instead of having another remote dangling off the key chain, I thought I could use the car's own fob for more than unlocking my car when I'm near it. Say I come home and wish to switch on a light at my front door.
    I already tried putting one of my generic receivers in pairing mode and hitting one of the 2...
    04-18-2022, 02:17 PM
  • itsthatidiotagain
    CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
    by itsthatidiotagain
    CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
    There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
    I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
    A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
    06-23-2025, 03:22 AM
