Logitech harmony 900 old remote control help.
  • ivtec
    • Dec 2008
    • 1967
    Hi guys hope you all are all ok and over come covid19 in good heath,
    i was given an Logitech harmony 900 old remote control that belonged to a already deceased person, you guys do you know what can i do with it ,if i can do factory default and start knew to use it to program tvs ,i have the manual but i'm confused, it asks me for blasters that i don't have,i only have the remote and charger dock , any help would be appreciated
    https://cdn.badcaps-static.com/pdfs/...30eef8baa4.pdf
  • ivtec
    • Dec 2008
    • 1967
    Re: Logitech harmony 900 old remote control help.
    Do i really need this blaster in order to use this remote?
    https://www.amazon.com/Original-Logi.../dp/B00F22Q82U
    • R_J
      • Jun 2012
      • 9594
      It does look like it will work as just a IR remote (the blasters are for R.F.) But you will likely need to program it via the Logitech software which can be downloaded.
      • ivtec
        • Dec 2008
        • 1967
        Thanks R_J ,it looks like it for what i read in this blaster;
        Harmony 900 RF Receiver ('Blaster')
        Harmony 900's RF-to-IR Blaster which is used to extend the ability of your Harmony 900 to control devices that are not in line-of-sight. The Harmony 900 can support up to six of these 'Blasters', though three is probably the most we have seen in any setup. You can select either a new or used Blaster. The used Blasters have been pulled from working setups and generally have some cosmetic wear, but function perfectly.
        i downloaded software and it was installed on the remote successful, but it doesn't show me anything that i can use to program anything , and the remote only tells me that blaster not responding
        • R_J
          • Jun 2012
          • 9594
          I am only familiar with the H628 which I don't use anymore. I would think the remote should work without the (R.F.) blasters. Can't you pick your device (ie:TV) in the software and the have it configure the remote?
          Point the remote at a camera, push some buttons and see if you see any IR emitting from the remote. It could be that the 900 does not have IR capability.
          I can't find information regarding IR only operation, It could be that the 900 only communicates via rf with the blasters that then outputs
          the IR signal.
          • ivtec
            • Dec 2008
            • 1967
            the IR signal.
            Yes i think so ,it only communicates with Rf, i tried to download software without the hub bluster but it doesn't have this module only shows till 700 series and doesn't connect to it always asking me to connect usb connection. well unless i buy a blaster and an IR ,this is not really a direct universal remote control which is shame . Thanks
            • R_J
              • Jun 2012
              • 9594
              Is there a usb connection on the remote? Does the PC recognize the remote when you connect it via usb?
              • ivtec
                • Dec 2008
                • 1967
                Yes there is a USB port on the Remote ,i was able to download software and it installed on remote ,but no way to set up anything else besides to work with baster,.
                • ivtec
                  • Dec 2008
                  • 1967
                  Yes there is a USB port on the Remote , i try to download software without blaster and RF but it doesn;t have software for the 900 series as you see in the pic ,i was only able to download software to work with blaster and it installed on remote ,but no way to set up anything else besides to work without baster,.[/QUOTE]
                  • petehall347
                    • Jan 2015
                    • 4440
                    • United Kingdom
                    this might help ..https://support.myharmony.com/en-gb/...armonyRemote7x
                    • ivtec
                      • Dec 2008
                      • 1967
                      I installed that software in the win desktop and installed to remote but i see nothing in the remote control to set up it to contr0l tv ,only see set up to contrl through the blaster.
                      Yes there is a USB port on the Remote ,i was able to download software and it installed on remote ,but no way to set up anything else besides to work with baster,.[/QUOTE]
                      • R_J
                        • Jun 2012
                        • 9594
                        I can't see that the blasters or the hub are bi-directional I would think that the remote only transmitted TO the blasters, so there should be no way for the remote to know if the blasters are there or not.
                        But I could be totally wrong.
                        avsforum has a thread on the 900
                        • ivtec
                          • Dec 2008
                          • 1967
                          Thanks R_J ; i gave up on it already, it seems it only works with blasters with RI, when you turn it on first thing it asks for are can't detect blasters, I'm not going to buy blasters,not worth it,thanks
                          • madan1
                            • Nov 2016
                            • 719
                            • Bulgaria
                            It can work as a standalone remote.. just don't ask me how... I have one ( currently for parts due to dead touchscreen ) which I was able to configure to work without the blasters, but that was long time ago and I only remember that it was hard - had to use the correct software version, the right settings etc... pain in the ass, but once you configure it, then you forget about it.
                            • brethin
                              • Dec 2008
                              • 1907
                              Logitech has ended all Harmony remotes.
                              • madan1
                                • Nov 2016
                                • 719
                                • Bulgaria
                                I do not know what that means, but right now I have in front of me several "harmony one" remotes which are working just fine.
                                I even just reprogammed one of those remotes using the myHarmony software and my logitech account.
                                By the way, if anyone finds his harmony remote useless, I'll happily take it
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  It means Logitech no longer sales or supports harmony remotes, they all all end of life, there may be files etc to download but they no longer sell or support them.
                                  • madan1
                                    • Nov 2016
                                    • 719
                                    • Bulgaria
                                    well, this does not make them obsolete or useless. Still, in my opinion, one of the best solutions to control lot's of home equipment.
                                    • tmhobadcap
                                      Pioneer VSX-522-K remote control not working???
                                      by tmhobadcap
                                      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                      12-24-2020, 01:44 AM
                                    • hemant_2222
                                      Schematic for Denon Remote Control RC1156
                                      by hemant_2222
                                      Hello Everyone,
                                      Hope everyone is enjoying their repairs at hand!.
                                      I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                                      I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                                      Please refer to the attached picture, i think the voltage divider is missing...
                                      10-06-2023, 02:05 AM
                                    • dfear
                                      hitachi 75hl16t64u - not responding to remote control
                                      by dfear
                                      I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                                      It came in for a power issue which I have finally resolved by replacing the power supply.
                                      The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                                      Anyone have a clue how to fix TV?
                                      FYI: I have checked the remote work s by pointing it at my camera on my phone....
                                      09-02-2024, 12:15 PM
                                    • wolf1976
                                      wireless receiver for 6 speeds fan control with remote control
                                      by wolf1976
                                      hi i have a receiver that is destroyed from the overvoltage i guess
                                      my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                      the motor fan has not label
                                      i have an other receiver operational
                                      In your opinion can i measure the voltage at the output ?
                                      what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                      thanks in advance...
                                      07-23-2025, 03:12 PM
                                    • t4796
                                      Fujitsu Aircon remote control
                                      by t4796
                                      I managed to drop this recently. It fell flat and square onto the floor from about 1.8m. Can't remember if face up or face down.
                                      The remote still kinda works but the display is blank and only shows up if I repeatedly flick the little silver crystal/oscillator looking thing on the board.
                                      Not sure if this part is the culprit or if flicking it is moving something else, but it seems localised to that component as far as I can tell.
                                      Having trouble working out the value of it since it doesn't seem to have anything other than a brand name printed on the side of it....
                                      01-03-2025, 11:24 PM
