UTİ 260B Thermal Imager
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    I need UNI-T 260b firmware
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    Re: UNI-T 260B Thermal Imager
    it stays like this
      • Jul 2011
      • 6057
      Re: UTİ 260B Thermal Imager
      uni-t 260b firmware download <—(Google this )
      https://www.uni-trend.com/html/produ...s/UTi260B.html
      This is in the manual for this device
      Is there a reset button on this device
      “ To restore factory settings:
      1) Press the up/down button to select the Factory Reset option in the System Settings
      submenu.
      2) Press the SET button to enter.
      3) Press the up/down button to select Yes.
      4) Press the SET button to confirm.
      5) Press the back button to exit.
      Note: During the factory reset process, please do not force other operation to avoid program errors.”
      • ay_bulut
        • Feb 2016
        • 114
        • turkey
        no reset button.
        • ay_bulut
          • Feb 2016
          • 114
          • turkey
          I tried it because the menus are not visible
            • Jul 2011
            • 6057
            Do the buttons do anything at all
            The software is some type zip file type that is unknown I can not unzip it
            • ay_bulut
              • Feb 2016
              • 114
              • turkey
              link below has video
              https://youtube.com/shorts/mCEEwUoOahk
                • 31139
                post the file
                  • Jul 2011
                  • 6057
                  Originally posted by stj
                  post the file
                  The file is on there website link
                    • Jul 2011
                    • 6057
                    How much of a charge does this unit have it could be that if it below a certain point it might not let finish booting but this is just a guess
                    But I have seen some devices do this where either it will not boot at all or it will only partially boot
                    Or there is something wrong with firmware installation or setup
                    If you can not figure out what going on then if this device is new get with the seller and find what can be done to resolve this issue
                      • 31139
                      it's a RAR file, not a zip file.
                      install this for archive opening:
                      https://peazip.github.io/
                      no need for any stupid shit like patches or serials - it's open-source.
                      • vitaliik
                        • Jun 2022
                        • 1
                        • UA
                        Hey Buddy! Did you found a Solution for your Problem? I have the same Problem. My UTI260b can't finish booting. With 100% he stops and that*s all. With completely low Battery i can start him somehow but not always. I have really no Idea what i can do and serching for new Firmware wasn*t succesfull. Thanks for Answer.
                        • Алекс
                          • Aug 2022
                          • 1
                          • Ru
                          Also such a problem. Did you manage to solve it?
                          • ay_bulut
                            • Feb 2016
                            • 114
                            • turkey
                            I talked to the authorized dealer and they exchanged it for a new one.
                              • Jul 2011
                              • 6057
                              That what I figured that you would have to have it replaced
                                Would anyone recommend this “ UNI-T 260B Thermal Imager” feedback wanted
                                by sam_sam_sam
                                I saw a review for this UNI-T 260B Thermal Imager and his review was positive but I would like to know if anyone on this forum has used and what they think about its quality and how easy it is to use
                                Or this model
                                UNI-T UTi85H Infrared Thermal Imaging Camera 30℃ - 45℃ Infrared Thermometer
                                03-21-2021, 08:47 AM
                              • Woodsworth
                                PS3 CECHC03 60GB YLOD Troubleshooting
                                by Woodsworth
                                I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                START
                                Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                03-19-2024, 07:58 AM
                              • Francesc V.
                                Infrared thermal imager HT-02A
                                by Francesc V.
                                Hi:
                                I have this thermal imager that stopped working. It....
                                - Switches on
                                - Displays "normal" image
                                - It doesn't show any thermal image
                                Not sure where to start looking at.....any idea/suggestion?
                                The asset has 3 different PCBs.
                                Regards,
                                Francesc....
                                11-28-2022, 06:06 AM
                              • Gcnewbie
                                Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                by Gcnewbie
                                Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                I opened the...
                                03-29-2024, 06:55 AM
                              • Veyron7887
                                Laptop overheating after replacement thermal paste
                                by Veyron7887
                                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                11-24-2024, 05:08 AM
