Electric piano distorted notes (Roland RD100)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Today, I came across something kinda special, which I haven't worked on before: a Roland RD100 electric piano. It was just sitting there in the shop covered in dust, no doubt having been ravaged and then abandoned by my oh-so-skilled co-worker. I actually remember seeing him struggling with this thing and I recall briefly witnessing the problem too: some of the notes play distorted. I'll try plugging it myself and maybe do some captures for you to hear for yourselves, but let's just say it sounds....bad.
    I haven't actually dug into it myself yet, so this is mostly a generic discussion to kill some time and maybe learn something in the process, especially since I lack the most important tool to diagnose audio stuff: a scope !
    I managed to grab the service manual - it's as simple as I expected: a PSU and some chips communicating back and forth. The block diagram on page 7 comes in handy to hopefully work out where the distortion may be happening. Unfortunately, most of these chips are dedicated and impossible to find, so I doubt this is fixable in the long run, but still...worth giving it a shot. If not, it could still be used as a MIDI controller I guess.....
    I'd say the amp section on the "jack board" to the right is fine, since most notes play OK - if there was something wrong here, ALL notes would sound off. My money is on that "XP" chip (IC2) on the main board to be honest.
    Wattevah...
    • 31138
    Re: Electric piano distorted notes (Roland RD100)
    page15
    run the self test in the ram and roms
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Originally posted by stj
      page15
      I will - just have to dig it out of there and power it up myself. Still, if it's any of that, I don't think it's fixable, since even if I somehow found the chips, they would still need to be programmed...
      Wattevah...
        • 31138
        i can program them - smd will fit in an easter card
        the ram is standard stuff too.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Yes, but I reckon you must also have the necessary file to upload TO the chip. I'm not sure they can be sourced anyway...
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Ok, just in case someone is still watching this thread, I finally got a go on this piano, to see for myself what is up with it: EVERY sound it makes sounds distorted - any key you play and even the sample songs stored on it. The distortion is present on both the line outputs and the headphone outputs, so it can be anything really: looking at the block diagram, it may be caused by IC15 (the DAC), IC7, IC16, or IC1 itself, since the path seems to loop back through it somehow after the "vol" and "brilliance" pots at the top...
            Can a DAC cause a distorted output because of the input it receives ? In this case, the signal for the DAC (IC15) seems to come from IC2 (the XP chip), so if that's feeding garbage to IC15, it will reproduce garbage on its output....a scope would be a handy tool to have right about now
            Wattevah...
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              It can (missing/stuck bits), but check the supply(ies) for the DAC first. Especially the caps for the analog rails for the DAC- can make it sound harsh, "chirpy" or extremely "aliased."
              Are they SMT caps?
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • petehall347
                • Jan 2015
                • 4429
                • United Kingdom
                try a clean signal direct to main amp . . that should rule out the analogue bit .
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Originally posted by kaboom
                  Are they SMT caps?
                  I haven't opened the thing up myself yet to know for sure. If they're thru-hole caps, then this old dude who had his way it it before me is sure to have replaced them, since that's basically the only thing he does to electronics: replaces caps and hopes for the best, without even thinking if they have anything to do with the problem in the first place
                  I was thinking of the same thing, but in reverse so to say: in-lieu of a scope, I was thinking of "probing" the sound output at different points after the DAC (IC15) to see where the distortion enters the signal path. I was going to use something like the line input of a small battery powered speaker, it this is at all possible with the rest of the components in-circuit not interacting in some weird way and possibly destroying something.
                  If I was to do what you suggested and try to inject my own external audio source into the pre-amp part, then I guess I'd solder my signal wires for L and R to the output of IC7A and IC7B on page 9 and hope for the best (before R19 and R27)
                  Wattevah...
                  • petehall347
                    • Jan 2015
                    • 4429
                    • United Kingdom
                    just be sure there is capacitive coupling to block any dc .
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      So I should put a ceramic cap in series with my audio source/output ?
                      Wattevah...
                      • petehall347
                        • Jan 2015
                        • 4429
                        • United Kingdom
                        or electrolytic low uf like 2.2uf . or film cap ..its just to block dc
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          Ok guys, after a ridiculous amount of time, today I decided to crack open the piano to have a look inside. As you can see, the damage done by my "skilled" co-worker (who thankfully retired in the meantime) is quite extensive: there's almost no component that hasn't been touched with the iron and he broke some traces and had to repair them using jumpers...the list goes on. I mean I was expecting it to look bad, because it IS this guy we're talking about, but not like this !
                          Upon seeing this, I was just about ready to stop and put it all back together, but I decided to at least do what I suggested in the discussion and that is to try and "listen" to the signal at various points to try and close in on the component that's causing it to sound rough, if at all possible: I tried it right after IC7A and IC7B (page 9 of the manual) and sadly the same thing happens: the audio is an absolute mess of pops, which tells me the problem is likely somewhere in IC15 or before it and unfortunately this is where my knowledge of audio electronics and test equipment at my disposal also stops. Even if I DID find the culprit, it all proprietary parts with no way of sourcing them, so this piano is only good as MIDI controller or spare parts ATM. Cheers.
                          Wattevah...
                          • i_am_patch
                            Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                            by i_am_patch
                            Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                            04-30-2024, 08:20 PM
                          • KeyResults
                            Roland SPA-120 Amplifier Tech Notes / SM / Schematic Source?
                            by KeyResults
                            Repairing a Roland SPA-120 amplifier, a solid-state early-mid 80's part of the Roland Rack. The PCB is Labled AP-124B. Was thinking lytics would resolve the nasty output on scope but all tested 100% for values, ESR, and leakage (very surprised!). Symptom is nasty wave form on both channels in Stereo mode, but clean in single channel mono (BTL) mode. The Output transistors test ok at room temp, but still could be faulty once heated up. Anyway, a schematic and some test point voltages would sure save some time. Thx!
                            11-09-2024, 03:21 PM
                          • ksotoszx
                            Electric Keyboard Piano No Sound
                            by ksotoszx
                            Hi all, this is my first post on this forum, i will need the help of someone who knows in order to repair the old Electric Keyboard Piano that was given to me.
                            It is a gold star brand, model gek s350. It lights up normally, everything seems to work but it has no sound. Neither from the keys nor from the ready melodies.
                            -I haven't forgotten a plug in the headphones.
                            -The capacitor that I touch with my finger (in the picture) has no resistance, as I measured with the multimeter, but I don't know if that's the reason.
                            Before i attempt something on my own and possibly destroy...
                            09-25-2024, 07:53 AM
                          • maleksa
                            Yamaha MOX8 boot freeze and distorted sound
                            by maleksa
                            My Yamaha MOX8 synthesizer recently developed two issues.
                            Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
                            Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
                            11-07-2024, 03:28 AM
                          • Dusko75
                            Need Help with Roland SC-88 Pro distorted sound!
                            by Dusko75
                            Hello All,
                            I know what I'm asking here is not easy to answer but, here I go anyway. A couple of years ago I got a Roland (Sound Canvas) SC-88 Pro, 120v version, it was like new, manual, original box, everything was great, not a scratch. Played with it for a couple of months and it worked as expected. A few days ago I wanted to use it again and now the sound it's completely distorted, it's like a big crackly sound (I'm attaching a sample using the sound preview button: one short press, one long and another short at the end) .
                            So, I opened it up and noticed that in...
                            09-15-2020, 02:04 PM
