kemet
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    kemet
    what about kemet caps guys? i have to change few amps swichmode primary capacitors and my supplier found for me that brand high temp and low esr and its gonna be expensive.thanks for any info .
    • 31296
    Re: kemet
    if you mean the black ones with gold print - they are good.
    but only on the inputs to switching supplies - i dont know about the outputs.
    unless you have the part number/series so i can look them up.
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      Re: kemet
      Kemet has low impedance electrolytics?
      PeteS in CA
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        Re: kemet
        thanks for answer.no i dont have number i only have offer from my supplier for kemet caps.anyway i use only on primary filter i see on net that gold black ones they are good.the old caps i have to replace is daewoo FHT series 2200mf 200v 85c 3000hrs so nothing special .only i like to instal some more decend low impedance quality caps.for secondary i have all ready order panasonic and vishay.
        • spiros.p
          • Dec 2020
          • 89
          • Greece
          Re: kemet
          my supplier says that series he offer me is low impedance.today i ask for series number just to be sure what i by.
          • clearchris
            • Dec 2013
            • 687
            Re: kemet
            I use kemet low impedence when I can't get nichicon or if the shape is more suitable. Haven't had any problems. I consider them pretty much on par with the top tier brands, but I'm not a pro.
            • mockingbird
              • Dec 2008
              • 5488
              Re: kemet
              Kemet electrolytics and polymers are low-tier Chinese products and should be avoided.
              Their polymer caps are priced very competitively - but there's a reason for that. They are not on par with Japanese parts.
              If you want Chinese/Taiwanese polymers, save your money and buy Apaq from LCSC.
                • 31296
                Re: kemet
                i think we are talking about the big snap-in / threaded caps
                • PeteS in CA
                  • Aug 2005
                  • 3586
                  Re: kemet
                  Kemet's lytics, https://ec.kemet.com/aluminum/ , seem to be made in the EU, and the part numbers are reminiscent of Rifa's part numbering system for lytics. They don't have the low impedance low voltage parts I mistakenly had in mind.
                  PeteS in CA
                  • clearchris
                    • Dec 2013
                    • 687
                    Re: kemet
                    They seem to have plants all over EU, mexico and asia.
                    https://www.kemet.com/en/us/quality-...tificates.html
                      • 31296
                      Re: kemet
                      i have used these - the life and ripple handling is impressive!
                      • spiros.p
                        • Dec 2020
                        • 89
                        • Greece
                        Re: kemet
                        yes
                        • spiros.p
                          • Dec 2020
                          • 89
                          • Greece
                          Re: kemet
                          the order is done guys.i ask for part number but he told me dont remember excactly and he said is equal liga like nichicon and nippon.and its expensive.anyway i trust my supplier always they send me good quality and excactly what i have ordered.thanks all here.
                          • @udiophile99
                            • Mar 2021
                            • 14
                            Re: kemet
                            The real problem with these types of issues (changing the amps) is not only the fact that it tend to be a little bit tricky to solve but also that the solution is always quite expensive.
                            • @udiophile99
                              • Mar 2021
                              • 14
                              Re: kemet
                              I'm not an expert whatsoever, but I think that Kemet's impedance electrolytics is not exactly small. Far from it.
                              • spiros.p
                                • Dec 2020
                                • 89
                                • Greece
                                Re: kemet
                                OK guys the caps is all ready instaled 22 pieces KEMET PEH532.i think from specs its better than the old ones from daewoo FHT series.
                                • Cartel
                                  • Feb 2006
                                  • 112
                                  I'm running these right on the edge. Hopefully they dont grenade. So far so good. floats around 3900 some days a bit less some a bit more this november 3 years
                                  • Stephen
                                    A2991 Logic Board issue, 20volts 0 amps help!
                                    by Stephen
                                    Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                                    09-10-2025, 03:16 PM
                                  • Stephen
                                    A2991 logic board issue, 20volts 0 amps help!
                                    by Stephen
                                    09-10-2025, 03:15 PM
                                  • Fisher8865
                                    MacBook Pro A1990 stuck at 5v .592 amps
                                    by Fisher8865
                                    Hi guys
                                    I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                                    05-30-2024, 07:36 PM
                                  • tmcw
                                    Drying Oven - Preset Temp Fail
                                    by tmcw
                                    Here's an unusual one...
                                    This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
                                    It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
                                    However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
                                    01-21-2021, 03:11 AM
                                  • foshland
                                    MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
                                    by foshland
                                    Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
                                    Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
                                    External temperature (motherboard temp) is working OK, 27ºC more or less
                                    In windows, all the software I have tested shows correct the Core temps
                                    12-16-2023, 09:08 PM
