Solar Controller MPPT 100A
  • samtron786
    • Aug 2016
    • 157
    • germany
    I have ordered such a solar controller MPPT 100A
    my problem that goes off every now and then
    At the beginning it worked very well and now the battery is 12.8 V sometime will be switched off
    many thanks
    https://de.aliexpress.com/item/10050...8%2315607%2390
  • redwire
    • Dec 2010
    • 3906
    Re: Solar Controller MPPT 100A
    I would check the programming and see if it did not get scrambled or corrupted. Check that the correct battery type is programmed - lead-acid, lithium, LiPO4, and 12/24V.
    If the programming is good, then look for a bad connection in your wiring, or inside there could be a cracked/bad solder joint. If you are too rough screwing in the terminal blocks, you can break the connection on the PCB.
    I could not find a good manual for the charger controller. It seems to shut off if it is overheating, over or under-current. Than might be causing it to stop.
    Or you just have too small a solar panel, cloudy days and the battery is going low.
    • samtron786
      • Aug 2016
      • 157
      • germany
      OK thank you
      I'll test it
