CH341A Unable to Read BIOS Chip on DA0R53MB6E1 Motherboard
  • Zentech
    • Feb 2021
    • 94
    • Usa
    Ok, I have a laptop motherboard who does not want to turn on. So I isolated the problem to either a BIOS or KBC problem. So I'm trying to read the software from the BIOS chip, and I get a wierd file. (all F's) I'm going to attached the file to this post. I'm using CH341A miniprogrammer usb board. And for the software, I'm using AsProgrammer v1.4.1. So I'm worried that BIOS software might have come corrupted, or it also could be that it is not reading from BIOS properly due to driver issues.
    Power led is on and when I press read on software, the communication led comes on. However, when I try to read, is telling me to unprotect the chip first. This is first time doing this.
    Motherboard: DA0R53MB6E1 Rev E R53
    board schematic: https://cdn.badcaps-static.com/pdfs/...3fee8687da.pdf
    BIOS Chip: EN25Q32B
    AsProgrammer https://github.com/nofeletru/UsbAsp-flash/releases
    CH341A usb board: https://rb.gy/6hj9ey
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Unable to Read BIOS Chip on Motherboard
    Are you reading the chip off the board or in circuit ?
    • ACS-Repair
      • Feb 2021
      • 204
      A BIOS chip that has all "FF" means it's either erased or the programmer is not detecting the chip properly. The default memory buffer is all "FF" as well so it's not always easy to tell which it is. The error message you are getting might be telling you that the chip selection is not right. Double check or try the "Detect my chip" option.
      • Zentech
        • Feb 2021
        • 94
        • Usa
        I tried both with same result... but now I soldered to a small board that came with usb board
        • Zentech
          • Feb 2021
          • 94
          • Usa
          I have "verify ic" button? is that the one you're talking about?
          I click on that button and it seems to be reading the ic and then it gives me all F's
          • Zentech
            • Feb 2021
            • 94
            • Usa
            I tried "read ic" button the one with "?" mark and it is not detecting... this is what I get
            Code:
            Current programmer: CH341
            ID(9F): FFFFFF(Unknown)
            ID(90): FFFF(Unknown)
            ID(AB): FF(Unknown)
            ID(15): FFFF(Unknown)
            if I select the chip model EN25Q32B and then I select "read ic" the one with an arrow -> then the button progress bar seems to be reading the ic, and I get all F's
            • Stevedb
              Stevedb
              • Feb 2018
              • 624
              • Belgium
              Did you use the programmer before. Did you put the jumper at the right place.?
              You can use this programma also Colibri and Neoprogrammer.
              Can you sent picture of your programmer how you set it up and you must use auto detect the chip.
              Good luck
              Best regards
              Steve
              • Zentech
                • Feb 2021
                • 94
                • Usa
                I watched a few videos on youtube that addressed the jumper issue and I believe is on the right place... I will attached pic
                I will give those a try next
                I don't see an auto detect button on AsProgrammer
                • Zentech
                  • Feb 2021
                  • 94
                  • Usa
                  wouldn't be better to buy it already programmed.. I have not found anyone who offer the service. This has proven to be something that it doesn't work very stable.
                  • Zentech
                    • Feb 2021
                    • 94
                    • Usa
                    ok, I'm giving NeoProgrammer a go and I'm getting this message
                    Code:
                    Programmer for MCU, AVR, SPI FLASH/EEPROM, I2C, Microwire, v2.1.0.19
                    IC not responding
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Hi
                      Yes the jumper is on the right place. It is very strange that he didn't see your chip. Do light the lights on your usb programmer. Did you try also read another bioschip? Maybe this chip is faulty.
                      I got never had problems wit not reading the chip.
                      • ACS-Repair
                        • Feb 2021
                        • 204
                        I haven't used the programmer you are using. I bought another inexpensive one on ebay called EZP2019. It's really more for hobby use but it has worked well for me.
                        • Guilty_2121
                          • Jan 2021
                          • 43
                          • Türkiye
                          if you are using cable between ch341a and chip, use it less than 3cm, check connections good. Don't let any weak pin connetions. when connections good you have to try other programs like neoprogrammer, asprogrammer or ch341 but different versions.
                            • 21968
                            Code:
                            IC not responding
                            Have you checked if the board needs the 3.3V mod . https://www.chucknemeth.com/usb-devi.../3v-ch341a-mod
                            • Zentech
                              • Feb 2021
                              • 94
                              • Usa
                              I solder the chip onto the board that comes with the usb board, instead of using the cable. I tested continuity with the meter and is good, but it is not recognized by the program...
                              • j.bisous
                                • Apr 2021
                                • 23
                                • France
                                Did you checked the continuity between your board and the CH431A socket too? It can happen that there is a bad connection at this point. Try not to push it completely into the socket so it can fit properly when you close it.
                                Good luck.
                                • Zentech
                                  • Feb 2021
                                  • 94
                                  • Usa
                                  I did the modification but still not reading/detecting the chip... any other ideas
                                  • Zentech
                                    • Feb 2021
                                    • 94
                                    • Usa
                                    is there any way to verify on the programmer board that it is working?... does anyone has the schematic for ch341a
                                    • Zentech
                                      • Feb 2021
                                      • 94
                                      • Usa
                                      I double checked the voltages of the chip while connected to ch341a and it has 3.3V in ping 8,7,3.. as specified on schematic... from there I don't know what else to check
                                      • Zentech
                                        • Feb 2021
                                        • 94
                                        • Usa
                                        Finally got it working... thank all
