repairing traces...on a fine pitch board?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well I need to repair a trace... ... on a DIMM.
    These tracks are tiny! What, hair line traces?
    Fortunately the track is fairly long, maybe 1cm, and fortunately 1mm away from the next trace. Now I need to remove the soldermask. However this trace must be thin from top to substrate as well, how could I guarantee mechanical scraping wont abrade the track? What would one use to scrape off the soldermask for these hairline traces?
    I guess the next thing after removing the solder mask is that the track needs to be jumpered. 30AWG Kynar wire is huge compared to this track...
  • diif
    • Feb 2014
    • 6978
    • England
    Re: repairing traces...on a fine pitch board?
    I use a scalpel blade, 0.1mm jumper wire and a stereo microscope.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Scalpel blade... no check
      $1 CCC Xacto knife... check
      0.1mm jumper wire... no check
      30 AWG wire... check
      Stereo microscope... no check
      1.4x magnifier light... check
      All ready to fail! *sigh*
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        Consider another approach:
        don´t fix the trace... just wire end to end.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Unfortunately the ends are pads under BGA components...
            • 31142
            rossman has fixed that a few times on video - he uses very fine wire and puts a loop on the end to hold the bga ball
            • gabiz_ro
              • Mar 2011
              • 167
              • Romania
              You may find some thin wire to use in some like phone earpiece, vibramotor.
              As for visual,you may try some camera on phone or tablets with some attached lens.Need to experiment a little.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Well, I guess the BGA doesn't matter, the break is nowhere near the BGA...
                Need to think of a better source of wire that's not coated with varnish...or oxidation for that matter.
                  • 31142
                  i just strip some stranded copper wire for such work
                  usually from an old pc psu!
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    And vias are another option...
                    Also my favorite solution
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Triumphant(for now!) Used 30AWG wire and cheap crap orange flux that I had lying around...
                      DDR2-5333 DIMM module seems to work once more at least at DDR2-3200 speeds...
                      Now whether or not I dab some CA or epoxy over it to protect it...
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        It sticks!
                        That's a 30AWG underneath that blob, and a 10¢ piece under the board.
                        Fortunately the tracks were relatively far apart, and only one track.
                        • megaraider
                          • Jul 2015
                          • 307
                          • Portugal
                          It sticks!
                          Great
                          (although i would have gone with a thinner wire)
                          • ChaosLegionnaire
                            HC Overclocker
                            • Jul 2012
                            • 3264
                            • Singapore
                            what a nice pointless repair! momaka will be proud! do post the link to this thread in the pointless repairs thread!
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Don't worry I have another one i need to fix.
                                • 31142
                                pointless?
                                do you know how expensive used dimms are becoming?
                                new stuff costs far less than used ddr or ddr2.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  Current dilemma : cannot get debug information from a dead 512M DDR2 module.
                                  Need parts for a 2G DDR2 module that I rootcaused a failure.
                                  Sacrifice pointless 512M module to fix a much more useful 2G module?
                                  Should add why I even want to repair this 512M module: because without it, I'd have an odd number of 512M modules... there's this machine that has three working 512M modules in it right now...
                                  • megaraider
                                    • Jul 2015
                                    • 307
                                    • Portugal
                                    pointless?
                                    IMO this is an excellent example of forum member misbehaviour
                                    [Most forum moderators would have block you @ChaosLegionnaire without any warning]
                                    • megaraider
                                      • Jul 2015
                                      • 307
                                      • Portugal
                                      Better to have an odd 2GB than an odd 512MB module
                                      (Providing motherboard RAM size is not limited to less)
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Yeah, definitely, though repairing this module would go with the above module and the number of 2G modules would be even once more...
                                        Anyway, this machine with three 512M modules will not get 3.5GB (3200MB ... chipset limitation)... 3GB maybe, when I pull the 1G modules out of the other machines to stuff these repaired 2G modules in.
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                          by mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                          11-25-2024, 05:22 PM
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
