here we go... pad restoration now easy
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    ok so i tried sometimes to get a ripped of bga pad back in a working condition by using different jumper wire, but i could not be able to get a perfect job. once was the wire not good, once the tweezer, , but now ive just ordered this:
    https://vimeo.com/538003330
    from the video they looks really easy to use. ill get them in the next weeks as express shipping price increased a bit and went to normal postage ship from china.
    anyone here already tried them ?
    • 31305
    Re: here we go... pad restoration now easy
    they sell some interesting stuff!
    https://www.unionrepair.com/
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      yes i saw that thing on their site and i already made a list of something i would buy from them like this one...https://www.unionrepair.com/oss-t12-...g-station.html that looks cheap but good on paper
      however i needed lattice usb programmer so i made that wylie order from goldenchipset. they all should be the same
      ps: any thouth about that soldering iron ?
        • 31305
        it looks like a KSGER clone - but it's very cheap so propably an older version with STC cpu.
        https://www.aliexpress.com/store/gro...517011084.html
        the stand wont work btw - it's for a bigger iron
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          https://www.youtube.com/watch?v=66lPlTkoQZkyes in another thread we were talking about ksger, but it costs much more.... someone said that it can broke easy the dc-in circuit ( work fine with battery), but this oss t12d+ looks promising...
          im wondering if someone here has already tried it
          umh ... look here... new model too, ship from cz
          https://www.banggood.com/KSGER-T12-S...e=CZ&ID=514179
          • megaraider
            • Jul 2015
            • 307
            • Portugal
            Seems to good to be true...
            Don't know how well they will hand the heat when soldering the bga chip.
            (The ultimate test would be after reworking see how it would stand an ic removal.
            But hey... if it delivers what that video shows it will be good enough )
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              i think that solder mask will keep it in place, but the only problem i can imagine is pad dimention... maybe they are just suitable for mobile phone and not notebook bga....
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                Yes, from a glance they seem to be all about mobile phones, but didn't even went thru the product catalog to check if it's available in different sizes.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  There are 6 different sized dots on the page. https://www.aliexpress.com/item/1005002500015812.html
                  • clearchris
                    • Dec 2013
                    • 687
                    What is that fluid they put on?
                    I checked for some legit reviews, but all the videos are by the seller. Would be really nice if it actually worked...
                    • megaraider
                      • Jul 2015
                      • 307
                      • Portugal
                      (...)Would be really nice if it actually worked...
                      It must be some type of glue sensitive to UV light but... who knows.
                      Didn't check but as i recall they didn't even mention it.
                      @dellxps15 might have some more info.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        The green stuff is UV solder mask.
                        I don't see why it shouldn't work, I've been using copper foil for these type of repairs , this is just precut.
                        • clearchris
                          • Dec 2013
                          • 687
                          Hmm. If they use UV curing mask, is the UV able to get through/under the copper foil? Or is the idea to attach the thin trace, which holds the bigger pad in place?
                          • dellxps15
                            • Feb 2014
                            • 1598
                            • italy
                            all things need practice.... maybe as shown in videos solder the pad, then put some solder mask that will go under the pad too, remove estra mask then solder bga.
                            dot repairing arrived today.
                            • myth77
                              • Feb 2017
                              • 380
                              • Croatia
                              any update on this? Does it really work in practice?
                              • wnlewis
                                New wire for my RDE3340 Whirlpool electric range
                                by wnlewis
                                OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                This is a Whirlpool RDE3340 electric range.
                                The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                Where may I find parts...
                                01-08-2025, 11:21 PM
                              • technicalspecialist
                                Vintage fan repair, copper wire question
                                by technicalspecialist
                                I currently have a customer's vintage fan on the work bench to repair.
                                It uses an induction motor with 4 poles. One of the poles is open.
                                I couldn't find the break so i cut off the original wire.
                                I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                The enamelled copper...
                                03-16-2023, 12:54 PM
                                Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                by sam_sam_sam
                                I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                12-16-2023, 08:39 PM
                              • kalemaroni
                                Dell DC Brown wire
                                by kalemaroni
                                There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                                08-26-2025, 10:10 AM
                              • GlenBrim
                                1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                                by GlenBrim
                                I got this recently as-is. Gigabyte 1070 video card.
                                DVI port is removed. I don't know why.
                                A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                                I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                                The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                                02-14-2024, 02:08 AM
