Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 04-24-2021, 04:42 PM   #1
ChairmanJones
City & State: Fenton
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Default Apple G4 AcBel PSU - blink failure mode
I have an AcBel PSU that was exhibiting the typical failure mode with the single blink light then no power on.
I started the rebuild with the shotgun 12, same issue. Fuse has continuity. My question is, has anyone narrowed down the cause to specific caps or is it a case of replace them until it works? What caps should I be replacing next?
ChairmanJones is offline   Reply With Quote
Old 04-26-2021, 11:12 AM   #2
PeteS in CA
PeteS in CA's Avatar
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
Default Re: Apple G4 AcBel PSU - blink failure mode
Some generic questions:
* Does this P/S have active PFC? If it does, what is the voltage across the big electrolytic capacitor? If it does and that voltage is ~165V, the PFC is not working and that is where to start your troubleshooting.
* If it does not have active PFC or the voltage across the big electrolytic capacitor is something like 390V, do you have good 5V Standby? If not that is where to start your troubleshooting. If 5V Standby is also OK, then the problem is in the main inverter or output circuits.
I'm not familiar with the specific power supply, but these are quick ways to localize where to look for problems.
PeteS in CA
All that is gold does not glitter,
Not all those who wander are lost;
- J.R.R. Tolkien, The Fellowship of the Ring
Laughable prediction, https://principia-scientific.com/doc...l-most-people/ ; Fully Vaxxed May 2021; Viva CallSJ "5K" (actually 3.26 miles), 9/19/21, 51:19; Belmont Water Dog 10K, 10/9/21, 1:52:45; 11.8 miles, 3:50:16, 9/4/21
PeteS in CA is offline   Reply With Quote
Badcaps.net Technical Forums 2003 - 2021
