Nintendo Switch chip id or datasheet
  • m3g4tr0n
    • Aug 2011
    • 88
    if anyone can id this chip.
    seen this marking codes from different boards.
    SD
    SA
    RY
    case:
    DFN1006-3
    SOT883
    • 31286
    Re: Nintendo Switch chip id or datasheet
    could be a voltage regulator
    • R_J
      • Jun 2012
      • 9625
      They seem to be mosfet's:
      ROHM RV2C002UN marking code RY
      nexperia PMZ600UNE marking code SA
      • m3g4tr0n
        • Aug 2011
        • 88
        Thanks a lot. i will order those.
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • fab13
          Nintendo Switch lite charging chip heats up and does not short circuit
          by fab13
          Hello everyone
          Small technical problem on a Nintendo Switch lite
          Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
          After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
          When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
          Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
          09-16-2023, 04:59 AM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • Troystain
          Help EZP2023+ updated chip database for w25q256jveq?
          by Troystain
          Hello, anyone here have updated ezp2023+ chip database in .dat file format.
          I need to add w25q256jveq chip but I do not know what data should I type.
          I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
          The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
          11-25-2024, 12:53 AM
