Harbor Freight car battery chargers any good?
  • caphair
    • Nov 2011
    • 1249
    I was gifted a $50 HF gift card and could use a battery charger. Just not sure if the HF brands are any good.
    Anyone bought/use any they can recommend?
    Out of their selection and reviews was contemplating this one:
    https://www.harborfreight.com/automo...ner-63350.html
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    Re: Harbor Freight car battery chargers any good?
    This is generic charger, sold under many different names. Many stores sell them under different brands, including Lidl, Praktiker and etc. They are SMPS based chargers with control electronics.
    I have similar one. Their disadvantage is that if the battery is heavily discharged, the charger will refuse to charge it. Because of the automatic 6/12V sense. This means that if you have 12v battery, which was drained because of leakage currents in your car to 5-6-7V, the charger will refuse to charge it, because it doesn't know whether it is heavily discharged 12V battery of fully charged 6V battery. Not to mention that this is also done in order for the end users not to try to charge damaged batteries, which can lead to even explosion of the battery,
    There is way around this. Just use 12V PSU from some device. Connect the charger, then connect the PSU to the terminals of the battery/while observing the correct polarity/ and then you can trick the charger to start charging. After it has started charging, it will not perform the start charging check again and will charge even completely depleted battery. Use this way around only if you are sure that you have a known good, but depleted battery. Charging damaged, deformed or leaking batteries is not a good idea.
    Also, if your battery is worn out and just cant get to the maximum cell voltage, the charger WILL try to charge it to the maximum voltage no matter what. This can lead to acid inside the cells starting to boil, which means that hydrogen is released, which is bad. Also, the battery will heat up. As with all chargers that have shut off when the battery is fully charged, you can't rely on this feature and charge the battery without any supervision whatsoever.
    If you hear intensive electrolyte "boiling" or "bubbling" inside the battery or the battery starts to heat up to unacceptable levels, disconnect the charger immediately.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • caphair
      • Nov 2011
      • 1249
      So other than that you think it’s a good enough charger? Would other cheaper ones from HF be just as good? I mainly need one to maintain a charge as sometimes the car isn’t driven for over a week or more
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        • Bulgaria
        I don't know. I have two. What do you think?
        They work. And here, the cheapest versions of this charger are about 15EUR.
        It is waaay better than red metal ones with amp meter, which are mostly trash.
        It is small, compact charger, that doesn't heat up too much when charging and is even somewhat water spash resistant. There is a rubber seal between the two parts of the case. Although this is usually not advertised feature and I wouldn't recommend charging your battery outside in the rain.
        The version with the voltmeter is even better. I have one from the older revisions, without led display and voltmeter and one from the newer revisions with led display, which shows battery voltage and charge level.
        They work fine and can charge my 72Ah car battery to an acceptable level and charging 6V batteries is a bonus.
        It is ideal charger if you occasionally need charger, to charge your car battery or to help a friend or to charge 6V batteries.
        If you have a garage and charge batteries on a daily basis, I wouldn't recommend it. It's not that fast and cant charge 24V truck batteries.
        Google Lidl battery charger and you will see that these are generic chargers.
        Just know that if your 12V battery goes below 10V, you will have to trick the charger with another 12V power supply connected to the battery, so the charger detects more than 10V and then starts to charge the battery. Most of these chargers have this glitch.
        • caphair
          • Nov 2011
          • 1249
          Thanks for the info. Does it auto turn off when full charge is reached? I know some don’t and can cause an issue
          • petehall347
            • Jan 2015
            • 4429
            • United Kingdom
            people tend to think there is something wrong with these chargers because if battery low they don't seem to work .this is not the case . just leave it connected and let it do its thing . they automatically pulse charge for a while . if that doesn't work its worth try jumping it with another charged battery or a regular charger to bring the voltage up ..i find if it doesn't start charging most times its because the battery is knackered.
            a car battery low voltage should come back up in little time if the battery is any use .
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              • Bulgaria
              Yes, all SMPS chargers I know turn off when the battery is charged. And they try to maintain the voltage. This means if that the battery self discharges after some time, they will charge it back to full capacity/voltage and then turn off again. Those cheap pesky red metal box chargers with amp meter don't have such function. Most of then are trash, barely work, heat up and will charge the battery until they blow up or the battery starts to leak/melts/explodes.
              The problem is that the charger can't know that your battery is bad and can't be charged to full capacity. In this case they will stubbornly try to charge a battery, which cannot be fully charged. This can lead to electrolyte bubbling/boiling and battery heating up. So, you have to supervise the charging process and check every several hours what's happening. And charge the battery on non flammable surface/chemical resistant surface. You don't want electrolyte stains or leaks on your carpet.
              p.s The charger from your link comes with 90 days of warranty. Mine came with 2 years of warranty each. EU legislation.
              Most of these chargers can't be even switched to charging mode if the battery is below threshold voltage, unless you trick them. Mine don't provide any voltage if they can't recognize the type of battery, unless you trick them. Zero volts on the clamps. Nada.
              But usually you will notice that something is wrong and the car starter is cranking the engine more slowly than usual and the lights on the dashboard flicker seriously and you need to check and charge the battery, before the battery goes below the threshold voltage of this kind of chargers.
              • caphair
                • Nov 2011
                • 1249
                I’ll probably pick one up. My car’s battery is at 12.3v currently and want to prevent it further discharging
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I still have/use one of those ancient large transformer chargers...sigh. Wonder if it's worth to mod it to regulate it or stop it from charging once it reaches full voltage...
                  I still wonder what the "50 amp start" mode is however. Seem some bad juju is being done to get the 50 amp mode on my charger. If only it had screws in the case and not rivets, it'd be open by now to be inspected and/or modded...
                  • ron350
                    • Feb 2014
                    • 296
                    The HF 63350 charger/maintainer seams to be hit or miss on quality control.
                    Purchased one on sale in 2019 that was an open box (returned ) charger and it would not stop charging. After 48 hours it was charging with 15 volts so I returned it.
                    This year they put them on sale again and I picked up a sealed new box and this charger has worked fine.
                      • 31139
                      dont forget your free multimeter!
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        • Bulgaria
                        Originally posted by ron350
                        Purchased one on sale in 2019 that was an open box (returned ) charger and it would not stop charging. After 48 hours it was charging with 15 volts so I returned it..
                        If the box was already opened and the charger was returned, don't you think that there might be a reason for this?
                        You complain that opened and used item was faulty.
                        Of course, it is worth to add circuit which turns off the charging when the battery is already full.
                        This can be done with thyristor and some other components. And the old transformer chargers do the job, but are heavy and bulky.
                        Not to mention that they aren't that efficient as SMPS.
                        Not to mention that they usually don't have any type of protection whatsoever, except some fuses.
                        • redwire
                          • Dec 2010
                          • 3912
                          I just returned an Energizer 2A car battery 6V/12V maintainer charger - 5 yr warranty and the electronics were good quality but the firmware is crap.
                          It would look for several volts before turning on the output relay. So a really discharged battery esp. 6V it would not do anything. So I used a lab power supply to fool that.
                          Then, it would send a full current pulse and if the voltage went high i.e. 14.4V it would go into ERROR thinking the battery had an open cell or something. Instead of restoration.
                          Problem is these microprocessor chargers are too complicated to actually work properly. Pic is an 8 stage charger!
                          Example, it's charged your car battery and it's sitting at 13.8VDC float and life is good. Then the parked car does a canister purge, draws a few amps for 30 seconds so the voltage sags. Or the RV fridge runs etc. The case of a load appearing for a short time.
                          "Smart" chargers get confused and either restart the bulk charge/top up/equalize routine again, while other chargers do nothing and just stay in the float state.
                          Both are wrong - the first will overcharge and the battery uses water, the second method the battery sulfates.
                          I haven't tried the Harbor Freight chargers, but just know these things can have low quality hardware or firmware. Some Schlumacher chargers are crap and way overcharge, youtube vids about them. They are just cheap chinese builds.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            The HFT float charger killed one of my batteries, so one strike against hft chargers. Not the same item however. Really need to get a better charger or mod an existing one... Couldn't crack open the float charger without destroying it unfortunately.
                            • televizora
                              ghettomodmaster
                              • Nov 2016
                              • 957
                              • Bulgaria
                              Originally posted by redwire
                              "Smart" chargers get confused and either restart the bulk charge/top up/equalize routine again, while other chargers do nothing and just stay in the float state. Both are wrong - the first will overcharge and the battery uses water, the second method the battery sulfates.
                              You can't expect 15EUR charger to be very smart. They fulfil they function, but have some shortcomings or flaws. The situations you mentioned are complex and lets be honest, most of the people need charger to occasionally charge their batteries, not use them in complex scenarios.
                              You want 15EUR charger to fulfil the function of device which is at least several magnitudes more expensive.
                              The MCU inside the charger gets confused because the device was never meant to be used in such environments and scenarios.
                              No screws? Usually the two parts of the case are joined together using snake head screws. If you don't have such screwdriver, you can make one from a flat screwdriver by cutting a slot in it. Using angle grinder or hack saw.
                              • redwire
                                • Dec 2010
                                • 3912
                                The super cheap Harbor Freight/Cen-Tech 12V battery float charger #42292/022-0192/61911/63161/62813 is almost always a piece of junk. It's a LM7805 jacked up to 13.5V linear regulator, with parts from the bowels of guangdong.
                                OP's Harbor Freight Viking 63350 I haven't seen a full teardown, reviews are just by dough heads. Many are complaints about them failing.
                                It looks wrong going to a (12.5V standard) 13.0V float with AGM? https://www.youtube.com/watch?v=ygG1cwYfj7U&t=337s so I am not optimistic. Seems to be some problems with it entering maintenance mode.
                                I'm going to make yet another car battery charger on my own because of the junk out there. In the pandemic lockdowns, need proper float charging at least a 2-stage (bulk/float). I have a 15V 4A PSU coming and just have to write some firmware.
                                My old $7 Aliexpress 12V 2A unit runs so hot but it works nice has a 14.6V then drops to 13.8V setpoint.
                                • petehall347
                                  • Jan 2015
                                  • 4429
                                  • United Kingdom
                                  i have a few of these sort of chargers and 2 are in constant use .never had a problem with any of them . only ones i had a problem with are the 3 that i was given to fix and i made them worse . and it cost me nearly the price of a new charger in parts .yes my own fault but my heart isnt in fixing things for more than they cost for a new one .
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    One review had blown capacitors, another said it's actually 12V 2A and 6V 4A so around 25W. The "4A" label is misleading.
                                    That's the problem - a low battery will overload any charger and chinese stuff is already pushing parts too hard and poof.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Are people using AGM car batteries or flooded? Seems these chargers need to know what type else they will over/undercharge them?
                                      hmm... the battery that got destroyed, I added about 600mL (!!!) water into it and it started taking a charge. I wonder what it's self discharge, CCA, and RC are now. Probably still needs to be replaced.
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        How long would it generally take to fully charge a 12.3v battery at 2/4amps? The listing this charger claims? I picked one up and it’s been sitting at 13.8v now for about 4 hours
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                          Another project idea for a battery bought from Battery Hookup with a good BMS board
                                          by sam_sam_sam
                                          https://batteryhookup.com/products/n...-2900mah-cells
                                          One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
                                          The price of this offer has gone up sense I bought these two boxes
                                          I bought two boxes of these batteries but there is a catch to the these battery packs
                                          The BMS protection board does work but it...
                                          07-31-2022, 04:07 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                          ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
                                          The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
                                          configurable for operating as either a Hybrid Power Boost (HPB)
                                          charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
                                          4-cell batteries. Both configurations allow the battery to work with
                                          the adapter together to supply the system load when it exceeds
                                          the adapter capability, referred to as system Turbo mode. HPB
                                          charger configuration reverse-boosts battery energy to the system
                                          bus to help the adapter provide the system power in Turbo mode.
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • huzo
                                          HP ELITE X2 1013 G3 weird battery issue
                                          by huzo
                                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                          01-31-2025, 12:09 AM
