z85 b3x8 mini pc bios
  • emaghanim
    • Dec 2014
    • 129
    • egypt
    need clean me
    this is a 100% working bios
    just want a clean me
    thanks
  • peste
    • Dec 2016
    • 13176
    • ROMANIA
    Re: z85 mini pc
    Originally posted by emaghanim
    need clean me
    thanks
    try..
    • emaghanim
      • Dec 2014
      • 129
      • egypt
      Re: z85 mini pc
      Originally posted by peste
      try..
      Thanks work 100%
      • Z85Help
        • May 2023
        • 1
        Re: z85 b3x8 mini pc bios
        I have an AZW Z85 board and keep getting ACPI BIOS ERROR when trying to install Windows 10. I have disabled ACPI in BIOS completely still an error.
        Would this firmware fix that ? Z85_D302
        • emaghanim
          • Dec 2014
          • 129
          • egypt
          for backup only
          this is t8u 8350 2032 mini pc bios
          work 100%
          board no. t8u_v3.0b
          bios id t8u007
          for backup
          work 100%
          • zPwN!
            ENOVA NE14I310 XU133t rev 1.3 working BIOS
            by zPwN!
            Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
            Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
            System SKU NE14I310
            BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
            Motherboard XU133T rev 1.3
            Serial Number IPNBI3X240SM2A01095
            Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
            RAM 8.00 GB
            NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
            01-03-2025, 01:03 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
          • joven016
            Lenovo Ideapad S145 need working bios HELP!!
            by joven016
            Problem is blinking power led only
            i don't know exactly if it's s145-15igm or s145-14igm
            have a backup bios file but i dont know the serial.. coz text already erased at the back of the cover
            Mother board : fs440fs541 nm-c111 rev 1.0 2019-01-08
            Already tested some of posted bios here
            S145-14igm - success but invalid serial and not booting on OS
            S145-15igm - success with serial and some other info in bios but still not booting on OS
            already tried installing new windows but always booting on bios setup
            windows installer flash drive detected on...
            08-21-2025, 10:55 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • Sparklingx
            CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
            by Sparklingx
            So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
            So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
            now all...
            08-29-2024, 01:53 PM
