Help With EZP2019+ Programmer
  • grimacelord
    • Jan 2017
    • 383
    Hello. I Have an EZP2019+ Programmer with an assortment of adapters that I am trying to use to dump the original BIOS firmware from a MICRON 25Q128A IC (Datasheet here) and then flash the newest BIOS firmware.
    I have the chip de-soldered from the motherboard and have the chip fitted securely into the "200-209mil SOP8 Socket" adapter. This adapter is placed into the top portion of the 1.8V adapter and that] adapter is connected to the top portion of the programmer.
    It doesn't seem like the software is able to read the chip:
    Since the datasheet says this is a 1.8V chip, I have it connected in the 1.8V adapter socket. Here is my setup:
    Am I doing this right? Why can't it read the chip?
  • megaraider
    • Jul 2015
    • 307
    • Portugal
    Re: Help With EZP2019+ Programmer
    That's the N25Q512A ID, not the N25Q128A ID.
    The NOR Flash was probably wrongly marked.
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • mr.Data
      Add chip to EZP2019 programmer for Lenovo ThinkPad X1 Yoga
      by mr.Data
      I have a ThinkPad X1 Yoga 4th gen with a BIOS password.
      It seems that the password is stored on the chip GD25B256D which I found and desoldered.
      Now my EZP2019 cannot read it but I can add new chips to the database. There is however some data needed that I cannot seem to find anywhere in the datasheet of the chip itself:
      Type: SPI_FLAH
      Manufacturer: GigaDevice
      Delay: I think it's 30 but not 100% sure
      class: 25 flash??
      Flash: 256B
      Flash page: I don't know
      Voltage: 3.3V
      Algorithm: No idea
      10-28-2022, 05:52 AM
      How to add chip support to NeoProgrammer software for the CH341A Programmer
      by SMDFlea
      Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
      and once you do find them there`s a few crucial steps missing.
      Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
      Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
      After adding the chip save the xml file and copy it to the root directory of the...
      05-26-2024, 07:15 AM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
