Extech EX330 multimeter current range offset fault
  • PanicMechanic
    • May 2017
    • 47
    • Serbia
    My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
    The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
    As you can see from the pics, the offser is the same (just multiplied for other rages):
    -4.9 uA
    -0.49 mA
    -0.49 A
    I don't know what exactlly caused the fault.
    The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked and coroded one of the spring contacts, and one of the solder joints for the battery wire on the PCB a bit. The battery was an expencive Varta with year 2025 exparation date, of course.
    There have also been a few incidents over the years, of course. Like when I was checking the if the metal chandelier was grounded (using the resistance range), and the multimeter was showing weird readings and beeping. It turned out that the the chandelier has live with mains voltage. But the resistance range works fine.
    Now, when I was trying to repair the meter a few months ago, I changed the Op-Amp TLC27M7. It had one of the higher input offset voltage versions (I don't remember which one exactlly), but I have changed it wit the 500uV offset version (the best one).
    https://cdn.badcaps-static.com/pdfs/...b897ef51de.pdf
    It did nothing.
    The other chip is: https://cdn.badcaps-static.com/pdfs/...94ef199bcf.pdf
    I did not change that.
    Then I was cleaning the rotary switch contacts on the PCB and the switch itself, and it did show a change. I have cleaned it many times, and one time even managed to get it to show 0.02 or something, but by the time I have assembled the meter again, the fault returned. Then I tried cleaning it a few more times, without success. So, I have no idea...
    Here I found the info on trimer pots: https://www.eevblog.com/forum/testge...-extech-ex330/
    But none of them are for the current range.
    I have tried to contact Extech to ask them for help. I used a business email, but they did not reply.
    https://i.postimg.cc/28v10hnz/1.jpg
    https://i.postimg.cc/V6d6nCYP/2.jpg
    https://i.postimg.cc/d0QDQfp1/3.jpg
    https://i.postimg.cc/52V6Tym8/4.jpg
    https://i.postimg.cc/cLBrSW-D2/5.jpg
    https://i.postimg.cc/CKv5RNp4/6.jpg
  • PanicMechanic
    • May 2017
    • 47
    • Serbia
    Re: Extech EX330 multimeter current range offset fault
    OK, it is fixed.
    I don't know what did it.
    I reslodered all through-hole solder joints. Cleaned the PCB. Not tightened the 3 PCB screews all the way (before I had always tightened them all the way).
    And it shows 00.00 now.
    • jinosean
      • Jul 2021
      • 4
      • Viet nam
      Can you give me the picture behind switch multimeter? Behind switch Off Vac Vdc Hz...
      • jinosean
        • Jul 2021
        • 4
        • Viet nam
        Is it like this my picture?
        • jinosean
          • Jul 2021
          • 4
          • Viet nam
          please help me to solve this problem
            • 31218
            is the problem that you dont know where the contacts go ?
            • PanicMechanic
              • May 2017
              • 47
              • Serbia
              Here you are:
              https://drive.google.com/file/d/1Wk9...ew?usp=sharing
              https://drive.google.com/file/d/1WlL...ew?usp=sharing
              It seems that you are missing 2 contacts.
              Or possibly you have a lower specification model that does not have those contacts, maybe?
              • jinosean
                • Jul 2021
                • 4
                • Viet nam
                Originally posted by PanicMechanic
                Here you are:
                ok, thankyou, I think i am missing 2 contacts
                • Rictech
                  Panasonic SA-MAX770PU SMPSU board fault....
                  by Rictech
                  Hello everyone. 😀
                  As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                  Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                  Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                  This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                  There are no devices that have exploded or otherwise show signs...
                  08-26-2024, 01:05 AM
                • jjne
                  Bad DC offset on Onkyo TX NR414 - doesn't appear to be in the analogue section
                  by jjne
                  I have a TX NR414, well I have two actually which are both exhibiting the same issue.
                  The one I've had since 2012 developed DC offset of around a volt under load on the front right speaker output. Not enough to trip the protection but enough to be noticeable in terms of sound quality. I checked the preamp board and couldnt see anything obvious. The offset is too high really to be a drift issue right?
                  I put the amplifier away for a while. I managed to pick up another example with a dead HDMI board very cheaply (common on these - mine was replaced by Onkyo several years...
                  07-28-2025, 07:51 AM
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  ESR meter came to the rescue again today with a PLC I/O card fault
                  by sam_sam_sam
                  I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                  I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                  One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                  12-18-2023, 08:17 PM
                • Agent24
                  What kind of fault causes this image error?
                  by Agent24
                  I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                  The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                  What's the most likely cause of this problem, does anyone know?...
                  09-22-2025, 11:42 PM
