[REPAIR] Multimiter sanwa PC510a strange temperature reading
  • ss45
    • Jun 2019
    • 119
    • Brazil
    Hi I have sanwa PC510a multi.
    the temp reading is offset by about -1000 C
    it was fine few months ago and started acting up recently
    so room temp will read ~970 C
    it is not the sensor ( K type) as when I plug to other meter (fluke) it reads just fine
    the sensor is sanwa original
    all other readings like voltage AC&DC, current AC&DC, resistance, diode, and capacitance give normal readings within
    meter's specification.
    I ve tried searching internet for schematic, but no luck so far.
    I guess it has sth to do with the cold junction compensation circuit or sth else, but i am really blind about servicing meter.
    i ve tried cleaning and brushing pcb with alcohol, again no change.
    any help is appreciated.
    thanks
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: [REPAIR] Multimiter sanwa PC510a strange temperature reading
    There is a thermistor inside the meter, probably it is open circuit with a reading like that...
      • 31131
      usually,
      although some chips just have a programamble value in them that assumes 20' ambient.
      • ss45
        • Jun 2019
        • 119
        • Brazil
        @per Hansson
        Yeah it is probable. But the big question is which one
        Heres link to some of the photos
        link
        @stj
        I wonder if only we could reprogram that chip....
        Maybe as the chip becomes older values stored inside it become corrupted. Or in a very unlikely event, stray radiation knocked a bit off of a cell, resulting in error'... Hmmm......
          • 31131
          those meters give "err" on the display if they get corrupted
          • CapLeaker
            AcuRite 5 in 1 temperature sensor replacement repair
            by CapLeaker
            Got a new victim:
            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
            B: stuck at some temperature and maybe updating once in 12 hrs or so.
            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
            04-15-2025, 01:32 PM
          • asdas09
            Temperature to remove chips from motherboard
            by asdas09
            What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
            I have device Sugon 202. I'm used also normal flux and rosin flux.
            09-12-2023, 12:44 AM
          • Dreigas
            ISL95880HRTZ desoldering temperature
            by Dreigas
            I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
            Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
            09-13-2024, 10:59 PM
          • jm1234
            9V relay temperature 40C
            by jm1234
            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
            05-09-2024, 03:03 AM
          • SuperAman
            PS5 HDMI port diode reading?
            by SuperAman
            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
            02-03-2024, 10:16 PM
