Synology DS418play need to locate a tps65094 replacement
  • ligym60
    • Oct 2016
    • 39
    Hi I recieved a synology disk station yesterday with a no power fault. Witty shorts on multiple power rails. After dividing the power rails. I've narrowed it down to this tps65094 chip having dead shorts on buck converter 2, 3, 4. After lifting the chip from the board all shorts vanish. Testing the chip itself it has shorts on these rails. Mouser has a 52 week lead time and digikey has 0 in stock. Does anyone on here have a distributor that offers them ? Some have stock but only sell a minimum of 2000pcs :/ I would like to purchase 2-4pcs
    Thanks everyone for your continued support.
  • ligym60
    • Oct 2016
    • 39
    Re: Good morning everyone in need to locate a tps65094 replacement
    Here is a edited version of data sheet with highlighted faults if it helps anyone
    • ligym60
      • Oct 2016
      • 39
      No worries
      Found a supplier that will send me 2 of these
      Thanks everyone
      • KYBOSH
        Samsung UN55HU8550F - No picture, No sound
        by KYBOSH
        Previous owner says this unit powers on and sometime has an image and sometimes not. They attempted to replace the main board but with no success.
        TV came with the replacement mainboard as well as the original.
        When the TV turns on there is no image or sound. No response to the remote or toggle button other than the power button. The power supply's relay was clipping here and there. It did that for several seconds even after I removed the mains. I did this even with no other boards connected (only the backlight was connected at the time). Backlight looks fine but...
        01-09-2023, 02:36 PM
      • skwarszczow
        Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
        by skwarszczow
        This is my first post on the forum
        I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
        Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
        Before completing the purchase, we decided to erase...
        03-23-2025, 06:04 PM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
      • blze999
        asus gu603zx ,Help to locate a sot 23 5 marking JWLZT 2EG9N
        by blze999
        I can't seem to find this component anywhere i belive it is a sot 23 5 package but could be wrong. It is an asus gu603zx laptop motherboard ill add photos of what im seing in boardview it doesnt label the part. Thr schematics i have are for asus603he i cant find the 603zx. On the schematics it is a different component 6 pins ill show that as well not sure if that will help in identifying what it does so i can find a replacement. The board was powering on without it to bios but when i try to boot with ssd it goes into protect mode i belive. I located another sot 23 5 where the circuit looked similiar...
        11-21-2025, 10:05 PM
      • momolar
        5 Capslock flashes, no boot / display on HP Elitebook 850 G8
        by momolar
        I have 2 motherboards for HP Elitebook 850 G8.
        Motherboard model: Corvette-6050A3216701-MB-A01
        After trying to remove the BIOS password by reflashing BIOS, the first board fails to boot. I then reflashed the original BIOS / EC back, but no success. I don't know if I damaged the board or if the dumps are bad.
        I bought the second motherboard as a replacement but it seems to have same issue somehow.
        Curiously, when I try to boot without RAM, I get the expected 3,2 error flash code "missing RAM". Everything is normal until...
        10-09-2025, 03:40 PM
