This can't be right...
  • izools
    • Jun 2021
    • 8
    • England
    So I'm here repairing an old IBM 5151 monitor, and I've ordered replacements for all the electrolytic capacitors.
    I've found like for like replacements for each one except weird one which, according to the circuit diagram sits at a centre tap of the flyback and the collector of the horizontal output transistor?
    It's C505.
    Non polarized, 18uF, 25v. Apparently.
    So the replacement caps arrive, I've had to obtain a 22uF 25v NP cap as there weren't any 18uF 25v available, not sure what the consequences of this might be.
    But check out the attached.
    The replacement caps are tiny, I ordered two different 22uF 25v NP caps and one is pictured beside the original 18uF 25v NP cap.
    Something's afoot. That size difference is alarming.
    I feel I've missed or misinterpreted something.
    Would really appreciate some input here...
    • 31288
    Re: This can't be right...
    the cap is probably for horizontal yoke drive,
    the difference in uf could effect the image width.
    it's common to replace them with film caps these days.
    • izools
      • Jun 2021
      • 8
      • England
      But how would you explain the physical size difference?
      That's what I'm alarmed by, the old cap is a lower capacity same voltage as the replacement capacitor so why is it 20x the size?
      I really feel we are missing something here...
      None of the other replacement capacitors have shrunk in dimensions by anywhere near that magnitude, the others are maybe 10-20% smaller, not 2,000+% smaller.
      • izools
        • Jun 2021
        • 8
        • England
        Yeah, I've zoomed out on the SAMS for this monitor and you can see that C505 is positioned between the flyback and the horizontal deflection coil.
        You can also see that it's referenced to the HV output of the flyback, it's not galvanically isolated.
        I really feel like we are missing some kind of special characteristic that this capacitor exhibits... Either that or the voltage rating on the old cap is just plain wrong on the label?
        Probably not given the collector of that tranny is rated 14.63v on the diagram... But then why is C504 rated 400v?
        You see what I'm scratching my head over?
        I'm not confident on this, never worked on something like this before...
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Take a look at these threads:
          https://www.eevblog.com/forum/beginn...apacitor-size/
          https://www.eevblog.com/forum/beginn...s-im-confused/
          https://www.eevblog.com/forum/chat/r...his-large-cap/
          In short I would just leave that capacitor as-is.
          Because I am not sure you will find any modern replacement.
          The Nichicon UHA series recommended in one of the threads does not seem to be available any longer.
          • R_J
            • Jun 2012
            • 9624
            The small cap will not handle the current, it will last about 1 minute and blow. Leave the original in place. If it was bad (as in open) you would have no horizontal deflection. You could use a 18µf polyester film capacitor.
            • izools
              • Jun 2021
              • 8
              • England
              Marvellous, thanks guys, will reinstall the old one!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                Anyone measure the ESR if these caps? The big ones and the small ones?
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Yes here, he describes the graphs meaning on the previous page.
                  But he got different values after reforming so I'm linking that as it is the correct one:
                  https://www.eevblog.com/forum/beginn...629/#msg487629
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8711
                    How do the compare between the different brand/models? Seems to be only measuring fleabay nichicons?
                    I'd suspect the big ones should have much lower ESR than the tiny ones whether they're fake or not, but wonder if anyone measured.
                    • izools
                      • Jun 2021
                      • 8
                      • England
                      Well I've replaced every electrolytic in the monitor except for the Horizontal drive big boi.
                      Unfortunately I still get the same symptoms - raster collapsing after two minutes of being powered on from cold (less if warm):
                      https://youtu.be/jPryi-k_XXY
                      I think it might be time for me to buy an oscilloscope...
                        • 31288
                        get some freezer spray or a heat source.
                        raster collapsing into a horizontal line??
                        • izools
                          • Jun 2021
                          • 8
                          • England
                          The raster seems to shrink from both directions at once, and when power is disconnected a brief vertical line blinks on the screen (which would only happen if HV were still present?).
                          I've never worked on anthing like this before, I'm not sure what freezer spray or a heat source would show me?
                          There's a really good SAMS for this monitor thankfully, showing me what voltages and resistances I should expect to see at key probe points and what signal patterns an ossiloscope should show me at certain points too so I guess I'll go down that rabbit hole...
                            • 31288
                            the fault only happens when something warms up - you find the part by heating and cooling it.
                            a vertical line wouldnt normally be possible because the horizontal drive forms part of the high-voltage generator.
                            i would suspect - in this order,
                            bad soldering related to the tda1170,
                            bad tda1170.
                            incidentally, if you need one then check cricklewood electronics.
                            https://www.cricklewoodelectronics.c...keep_https=yes
                            • R_J
                              • Jun 2012
                              • 9624
                              Is this the original problem with the monitor BEFORE you replaced the capacitors?
                              That fault looks like it is with the power supply, What is the voltage on TR24 collector?
                              Upload the service manual/Schematic
                              Post #4
                              The cap has to handle high voltage spikes at the horz. frequency so it is rated 400v
                              • izools
                                • Jun 2021
                                • 8
                                • England
                                Wow, I am really grateful for how helpful you're being. Thank you.
                                Yes, fault was present before recapping. The recapping was just a stab in the dark. The picture is at least sharper now following the recap so it wasn't in vein.
                                Will check those transistors as suggested.
                                SAMS for the monitor is here:
                                https://tinyurl.com/3npws544
                                • Hitto
                                  • Apr 2019
                                  • 95
                                  • Italy
                                  This capacitor has to sustain 5-8A of current and a sawtooth AC voltage which will blow any electrolytic capacitor not specifically made for this purpose.
                                  These specific capacitors are very rare since they were produced exactly for CRT monitors. And, of course, they are out of production.
                                  The current is so high than even a generic polyester capacitor will have difficulties handling the required current.
                                  You should parallel three 6,8uF polyester capacitors and they should be adequate as a replacement.
                                  The voltage should be 50V, not less. There are spikes in this current so even better if 100V.
                                  No worries if the resulting capacitor will be higher in capacitance: I've tested replacements of this exact capacitors (which is present in most CRT monitors) and a larger capacity won't affect the width of the picture.
                                  I suggest Panasonic ECQ capacitors or something of good quality. There is not only a lot of current but also high frequency (15.8KHz)
                                  Also take a look here, did a lot of tests in the past:
                                  https://www.badcaps.net/forum/showthread.php?t=81004
                                  Also check for solder joints in the yoke (4/5 Pin) connector.
                                  • reformatt
                                    Macbook Air M2 A2681 Kernel panics after screen replacement
                                    by reformatt
                                    Just had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
                                    It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...
                                    07-31-2025, 08:37 PM
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
                                  • ezenia
                                    PS4 controller left stick potentiometer replacement issue
                                    by ezenia
                                    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                    09-30-2023, 02:19 PM
                                  • boosti45
                                    Macbook pro logic board replacement parts quesion
                                    by boosti45
                                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                                    08-21-2024, 05:23 AM
                                  • r2digital
                                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                    by r2digital
                                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                    04-18-2024, 03:50 PM
