Revox A77 MKIV, No play speeds
  • budwich
    • Jul 2015
    • 3097
    I have had this 10 inch reel to reel since new. It lost its play speeds a while back and has been sitting patiently ever since. FF and FR both work. When play is selected, the tape guide mechanisms "arm" themselves to position but nothing happens after, no take up reel effort or drive reel movement. Likely candidate would be some form of classic "badcap" maybe, hoping. It was only ever lightly used and probably only fully functioned about 20 years ago.
    Any hints / pointers on where to start looking, ie... board / area. Thanks. I have to track down my service manual somewhere in the house... :-)
  • R_J
    • Jun 2012
    • 9594
    Re: Revox A77 MKIV, No play speeds
    In play mode, it is the Capstan that drives the tape, Is the capstan motor working? Check that the motor is not seized, and check C151 motor capacitor.
    • budwich
      • Jul 2015
      • 3097
      ok... thanks. Nothing is turning in the head area which I assume has the capstan / pitch roller "feed". How does that couple into unwind / takeup of the tape at the reel motors?
      I haven't gotten inside yet. I did find my service manual... its quite "intense" with three language spread all over ever page. Will take a bit of navigation to locate things but your "hint" of the c151 will certainly help move me to "start" position in this. Thanks again.
      edit: I just checked the capstan and was able to spin it with my fingers. Didn't feel stuck but had some "flywheel like inertia" which I kind of expect.
      edit2: One other thing, the "end of tape" detector light is not lit so the reel motors operate even without tape... hopefully just a burnt out light bulb although it looks new with no burnt spots.
      • R_J
        • Jun 2012
        • 9594
        I don't think the end of tape light could be the issue, I would think without the lamp the unit should still play but would not shut off at the end of tape. I downloaded the Revox A77 service manual but I am not sure if it is the same as the A77 MKIV
        • budwich
          • Jul 2015
          • 3097
          I only have a hard copy of the SM (came from studer / revox).
          I have been trying to read thru the schematic but I must say they are difficult as I don't understand the designation for the pin / connector to where to jump on a subsequent page. You are right about about the bulb, it should not in itself cause an issue with play back BUT, I pulled the bulb and measure it, it is fine at about 100ohms. Based on this, that likely indicates that the 21V power "rail" is not functioning... WHICH might be causing problems elsewhere, including control / speed selection.
          I have to figure out how to get the case off, the thing is heavy and the SM says to lay it on its face.... not sure that's a great idea. Attached is a picture of the thing, just for reference as an A77 can be a bunch of versions which are not easily marked as far as I can see.
          • R_J
            • Jun 2012
            • 9594
            There is a fuse, F102, (630ma) for the +21v, it is on the tape drive control board. The Capstan speed control circuit is supplied by +21v. So you are likely on the right track.
            • budwich
              • Jul 2015
              • 3097
              I got the case off. I checked the two fuses that I see on the power board. They meter good. I have to figure out / rig something up to circumvent the cabinent interlock system to allow powering up with the case off. It uses what appear to be a couple of metal prongs to push on something inside a female receiver. The insides look ugly in terms of access while powered to measure points and / or removal of boards.... at least at first look.
              edit: just to clarify from the first post, the reel motors are turning in play when there is no tape mounted but the capstan does not turn so there is some form of take up / unwind happening.
              • budwich
                • Jul 2015
                • 3097
                Use some screws in the "shorting plug" to override the case "interlock". Confirmed that I DON"T have 21v dc on yellow red out of the power board.... only about 1v. Retested the fuses in and out of the holders, they are good (low resistance). Have to check thru other points on the card to see what's up. Operational access is somewhat limited. I haven't looked at how to remove the card yet but it does not look like fun.
                edit: transformer output is 24v AC.
                • budwich
                  • Jul 2015
                  • 3097
                  There is an issue with the readings in and around Q102 (sdt9201 NPN). The emitter shows -30.4v and base -29.9v while the collector is 0 (expected as it is tied to ground). Schematic shows a test voltage of -6v at the emitter... not good. checked q102 in circuit diode test appears to be good. Perhaps the capacitor c101 (1000 uf 35v) is an issue... likely based on age and the fact that the unit exhibited the problem from little to no use which is unlikely to take out the transistor.
                  I haven't figure out how to take the board out without a lot of disassembly as there is a few screws in places that have limited access.
                  • petehall347
                    • Jan 2015
                    • 4440
                    • United Kingdom
                    have you a link to the service manual ? i only have mk1 mk2 ones
                    its ok i have it now .
                    maybe the 1k resistor thats from emitter collector is bad ? or the cap as you said .
                    • R_J
                      • Jun 2012
                      • 9594
                      It looks like Q102 is not being turned on to lower the voltage to -6v. Check the resistors in that area, like R107 across Q102, R103, & zener ZP12. I would also work the pot P106 back & forth in case it the problem.
                      The cap C101 & C103 are likely not causing this problem,
                      Does the service manual I attached seem to match yours? (power supply page 48)
                      • budwich
                        • Jul 2015
                        • 3097
                        sorry, I didn't originally see the attachment. Yes it is the same as my hard copy and pictured unit. Thanks.
                        I have been trying to get at the board more readily. I have to move / remove the brake actuating solenoid as it is blocking access to one of the mount screws of the board.
                        With my limited understanding of things, not understanding how the voltage gets to be so negative (some sort of "chopper", I guess) although if I do the "simple math" on the difference, you get about "27v" on the schematic (21 and 6) while currently I see about "31v" (1 and 30). Of course, that's my "simple". :-)
                        • petehall347
                          • Jan 2015
                          • 4440
                          • United Kingdom
                          do you have the +27v ?
                          edit ....i guess you have but worth checking .
                          • budwich
                            • Jul 2015
                            • 3097
                            yes I check the 27v source, its fine... I was just playing with math numbers for no reason. sorry for the "dribble".
                            I checked the resistors as suggested, they measure as spec'd although r107 was "moving" as it must have some "charge path" somewhere causing the meter to "drift" towards the value as something charges.
                            I also checked the 12v "test point" (top of r103, clamped by the zener), it wasn't good. Was giving me just under 1v. Perhaps that points to a dead ZP12 (d104)?
                            • R_J
                              • Jun 2012
                              • 9594
                              The regulator circuit controls the negative side and not the positive side like a "normal" circuit would. R107's reading could be effected by a charged C101. make sure it's not open.
                              The -6v voltage is with respect to ground (0v) since the circuit is not working and q102 is effectively open, you measure -30v on its emitter, as Q102 gets turned on, the emitter voltage will drop to -6v and this will show as +21v on C101 (+) with respect to ground.
                              It might make it easier to understand the circuit if you think of the [+21v] line as ground, [-6v] line as -30v input and this would regulate a -21v output at [0v].
                              So I would remove R107 and check it out of circuit to make sure it is not open.
                              • budwich
                                • Jul 2015
                                • 3097
                                pulled one leg of r107 to isolate it. It test 1k. Its seems strange that the zener is not hold 12v as it should. Physically, it doesn't look damaged.
                                • R_J
                                  • Jun 2012
                                  • 9594
                                  Diodes can short and still LOOK good. check that the diodes are not shorted
                                  This does not seem right, I can see -30v on the emitter, but if the transistor is good it should not show -30 on the base, It could be that the transistor is in effect open so it will not conduct to provide a path to ground for the regulator circuit.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    I did check the transistor (in circuit... its heat sink mounted and would a bit to get it out), it seemed to diode check correctly for an npn transistor. The voltage difference does seem to suggest some form of "diode junction operation" of ~.5v or so.
                                    The zener diode seems to pass some checks but I can't check the "12v ceiling".
                                    • petehall347
                                      • Jan 2015
                                      • 4440
                                      • United Kingdom
                                      you should test both those diodes . a couple of 9v batteries and current limiter resistor will do to test the zener .
                                      • divingfe
                                        • Jun 2021
                                        • 5
                                        I have a large Pioneer. Its reel motors work independently of the capstan drive, like yours. After a time in storage, I had to replace the [capstan]motor-to-captstan-idler drive belt. It had 'frozen' to the flywheel. Worked like a charm after that!! I always thought of the electronics as being bulletproof, like the heads. Maybe a cap went bad, but check the mechanicals first. One caution; when you get around to cleaning the pinch rollers, be VERY CAREFUL of the cleaning fluid you use. Good old isopropyl may- in the long run- dry out the rollers (!!), but it won't eat them up like some marketed fluids.
                                        The shortest distance between two points is a straight line. The longest distance is a "shortcut". Have a '12 LG50PA5500(Plasma- Great!)!. Looking to get an LG or Sony Bravia 65" OLED 4k. Have the 'usual' Receiver, speakers, DVD, VHS, Beta, and tape recorders, etc, when I get them set up after the extended move.
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
                                        • alltvrepairs
                                          Hisense 55AS6G screen double sided tape required
                                          by alltvrepairs
                                          I need to replace the LEDs of this TV. The screen is glued with double sided tape. This video shows the proceudre required.
                                          I need a source for this type of double sided tape adhesive please.
                                          https://www.youtube.com/watch?v=bN6g...nel=QUADRA-NET
                                          Tks!
                                          07-17-2025, 09:32 AM
                                        • Thermaltake
                                          Panasonic NV-FS200 restoration
                                          by Thermaltake
                                          I got this VCR in compensation and well, It wouldn't be fun If I didn't f*** something up doors that won't close completely was easy fix.
                                          I was thinking that someone who messed with VCR before me didn't screw all the way this screw(see picture), but later I found out that this screw is suppost to be like that smh... and now after I clean head and everything I got this kind of situation on video (see videos)
                                          - on first play I got black and white/color exchange white some noise and picture is flickering
                                          https://imgur.com/ygMXcWI
                                          06-23-2024, 12:13 PM
