Flir Boson Development Board Damaged USB
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on a Flir Boson Development board, model number 250-0593-02-r210. USB port was ripped off, tearing several traces on the board. I reattached it, and bridged the torn traces. It now shows 5V on pin one of the connector and up through the cap at C7 but no significant readings on any of the other pins and the device is not recognized in device manager as a USB interface. None of the traces on pins 5-10 of the connector were torn and it looks good under microscope. There were two pads there were torn completely off (highlighted in red on port-ripped-off.jpg) but I assume these were just for structural reinforcement. Thoughts?
    • 31131
    Re: Flir Boson Development Board Damaged USB
    check for continuity between the cable and board to see if the socket still makes contact with the plug.
    • R_J
      • Jun 2012
      • 9578
      If the plug checks ok, check that TVS2 & TVS3 are not shorting the data lines to ground.
      • mgrharry
        • Sep 2016
        • 211
        • usa
        There is continuity between socket & plug. For TVS2 and 3 I will remove and test them. Will data lines function without them?
          • 31131
          yes
          • mgrharry
            • Sep 2016
            • 211
            • usa
            For TVS2 multimeter reads .790 forward and .751 in reverse direction. So it seems to be bad. However, when it is removed, I still get no device recognition. It does seem likes that the problem is somewhere around pin two, as I believe it was originally bridged to pin 1 with a blob of solder when it was first reattached so 5v may have run down that line and damaged the diode.
            • XxMicroSoldering
              ASUS Rog Strix G17-712LV Laptop Liquid damaged
              by XxMicroSoldering
              Hello Guys
              I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
              10-17-2024, 10:45 AM
            • Tomylee
              Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
              by Tomylee
              Hi everyone,
              I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
              It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
              I'm looking for help with the following:
              The exact identification or part number of the T5 component
              05-28-2025, 12:42 PM
            • dbuergi
              Help to identify components / find schematics on a Flir Scout TKX board
              by dbuergi
              i got a Flir scout where a connector was ripped off and i will have to make new pads. One big problem i have right now is that 2 small smd components are missing near the pads and i was only able to find a comparable pic of this part of the board.
              So right now i need to know what i need exactly for a replacement and the values. I contacted Flir by mail but they don't give out schematics and told me that i can use the guarantee if i have it (funny guys).
              Anybody has an idea what i can do?
              09-09-2024, 03:11 AM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • tofik
              LG 50PA6500 Plasma TV damaged after a power spike
              by tofik
              Hello, I have an LG 50PA6500 Plasma TV, purchased new in 2012.
              Unfortunately plasma is not working at all after a power spike.
              Qucikly tested the PSU and voltages seems to be okay, when eveything is disconntected from the PSU I got:
              VS = 200-206 / actual = 205 V,
              VA = 55 / actual = 54.9 V,
              M5V = 5.2 / actual = 5.19 V,
              17 = 17.24 V,
              5.2 = 5.19 V,
              STDBY = 5.19 V,
              ERROR_DET = 4.8 V - does it mean PSU is damaged? the rest of the voltages seems to be fine.
              what's your opinion about the PSU?
              Also I just...
              12-20-2022, 03:08 PM
