recap help AcBel PSU
  • pavithra_uk
    • Nov 2010
    • 45
    I found used PSU AcBel PC6001 ~250W from IBM thinkcenter Core2Duo system. Almost every output rail caps were bulged except 12V rail single cap. caps were Ltec
    12V - 1200uF 16V
    5V - 1000uF 10V before coil 1000uF 10V after coil
    3.3V - 1000uF 10V before coil 1000uF 10V after coil
    5Vsb - 1000uF 10V before coil, 470uF 16V after coil
    Since I have no access to buying new branded caps, I'm going to replace caps with used caps I pulled from dead PSUs and Motherboards.
    I need cap experts ideas about it.
    This PSU will be use for light load. Mini-Itx J1800. total power consumption not more than 50W.
    I have following capacitors that fits: (Order by age.)
    Teapo 1000uF 10V, 3300uF 16V & 10V - most recent
    Ost RLP 1000uF 10V, RLS 2200uF 10V, RLX 2200uF 16V, RLX 3300uF 16V
    Nippon chemi con KZG 1500, 2200, 3300 6.3v, KY 1000uF 16v, 25V
    Rubycon MBZ 2200uF 6.3V
    what you think? should I take teapo or better brand ?
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    Re: recap help AcBel PSU
    Find new caps. What you will take from old mobos and PSU-s is at best at it's EOL.
    Teapo and OST are mediocre. While they are not the worst, when they are new, I won't put 10-15 years old caps in a device, when I repair it.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Don't use the ultra low ESR caps: Rubycon MBZ and Chemi-Con KZG, OST RLP.
      Otherwise you should be ok for some testing, basically use the caps with the highest ESR you can find from the ones you listed.
      • pavithra_uk
        • Nov 2010
        • 45
        Why higher ESR ? any reason for using high ESR caps for smps?
        I tested those caps for ESR randomly. with component tester
        KZG 3300uF have 0.01Ohms
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Well, a more proper way to put it is to use capacitors that are as close as possible to the originals in spec.
          A PSU is basically tuned to the ESR of the capacitors, so if you change them too much it will start to oscillate.
          • pavithra_uk
            • Nov 2010
            • 45
            Thanks for the information.
            So.. Teapos are the solution. they are relatively newer, have 0.03 ESR came with PSU.
            what you think about capacity? stock 12V rail was 1, 1200uF 16V. I can put 1500,2200 or even 3300 there.
              • 31316
              if it's 1 cap that can work,
              but if it's 2 caps with an inductor between them then probably not.
              • pavithra_uk
                • Nov 2010
                • 45
                12V rail have only 1 cap (1200uF 16V)
                All others including 5Vsb have 2 caps with series inductor.
                Stock caps are Ltec LYZ 8x20mm 1000uF 10V ESR rated for 0.040-Ohms
                1200uF 16V 10x23mm ESR 0.021-Ohms
                Teapo SC 3300uF 16V 10x35mm ESR rated for 0.026-ohms
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5111
                  • New Zealand
                  Nothing so wrong with using recycled capacitors IF you remember you don't know how much longer they're going to last. You might have to replace them again in 6 months- if you're okay with that.
                  Brand new is the best.
                  Don't use old components for repairs on someone else's devices unless you have no choice.
                  -David VanHorn
                  • pavithra_uk
                    • Nov 2010
                    • 45
                    This PSU is for my use. so I can periodically check status of capacitors.
