Sharp LC-80LE632U 2-5 blink code
  • SdlewisSr
    • Oct 2015
    • 146
    I have a Sharp LC-80LE632U with a 2-5 blink code. I have narrowed it down to the T-Con/Panel. I get the error if both or either ribbon cable is connected between the T-Con and the Panel. If I disconnect both ribbon cables, I get no error and the TV powers up just fine.
    Does anyone know if this is a definite bad Panel or is there a chance that the T-Con could still be at fault?
  • SdlewisSr
    • Oct 2015
    • 146
    Re: Sharp LC-80LE632U 2-5 blink code
    A little more background information. The initial blink code on this TV was (2-2) Power supply error 2 UR+13V error. I also noticed that buzzing sound in the PFC area. After checking the UR+13V filter caps and rectifiers and finding nothing wrong, I refreshed the solder joints on the major components (transformers, FET's, diodes, caps, large inductors). Then I took a look at the PFC and noticed that it was lower than I thought it should be and it fluctuated. When the PFC is off the voltage on the bridge rectifier/filter caps (C7220, C7222, C7223) was normal and did not fluctuate. When the PFC turned on the voltage on the filter caps fluctuated between 310v and 316v. Also the voltage on the bridge rectifier fluctuated between 150v and 220v. Even with this fluctuation the output voltages were stable and where they should be.
    After refreshing the solder joints I put the power supply board back on the TV. Now the 2-2 blink code was gone but the 2-5 showed up.
    Because of the 2-5 blink code, I check the T-Con/Panel. When I disconnected one or the other ribbon cable between the T-Con and Panel I still got the 2-5 blink code. When I disconnected both ribbon cables, the TV powered up as normal. The PFC remained the same. I expected the PFC to be around 380 - 400 volts, but it remained fluctuating near 300v.
    What I am wondering is if the PFC is too low to handle the 12v outputs when the T-Con/Panel tries to power up, and this is why it's giving the 2-5 blink code and not because the Panel is bad.
    Note: Though the PFC voltage does not increase when the TV comes up with the two Panel ribbon cables disconnected, the buzzing increases as the backlight intensity increases.
    Last edited by SdlewisSr; 07-12-2021, 01:07 AM. Reason: I forgot to add images. So here they are.
    • lotas
      • Jan 2016
      • 4759
      • Russia
      Here is a diagram of the power supply, it can help you figure it out.
      • SdlewisSr
        • Oct 2015
        • 146
        Thanks lotas!!! This will be a big help.
        • SdlewisSr
          • Oct 2015
          • 146
          Update: I fixed the low PFC voltage problem. I temporarily replaced the four 750k ohm SMD resistors (R7233, R7234, R7235, and R7236) off of pin 8 (HVSEN) of UCC28061 (IC7201) with four through hole 750k ohm resistors. Now all voltages are good. The PFC voltage is stable at 390v. Also the buzzing is gone.
          However, that did not fix the 2-5 blink code. With the two ribbon cables (or just with one or the other) connected between the panel and T-Con board I get the 2-5 blink code. With both ribbon cables disconnected the TV comes up with no error, backlights and all.
          Thanks again lotas for the board schematic!!!!
          • lotas
            • Jan 2016
            • 4759
            • Russia
            Please, was glad to help
            • SdlewisSr
              • Oct 2015
              • 146
              Update: I checked some of the main voltages on the T-Con board at connectors SC7001 & SC7002 without it connected to the Panel. I also checked the resistance to ground of these same pins with the T-Con disconnected from the Panel and then again with the T-Con connected to the panel. (See attached chart)
              The voltages appeared to be normal. Only the Vcom pin resistance changed a lot. This may be normal.
              I'm now wondering if the 12v regulator (IC7504) on the Power Supply board is failing under load.
              • SdlewisSr
                • Oct 2015
                • 146
                Update: I put a 4.5 ohm load on the PNL12v and ran it at 2.67 amps for a few minutes and it did not fail under this load. The 12v regulator (IC7504) is rated for 3 amps. I'm not sure how many amps the Panel runs at under normal conditions, but I'm no longer suspecting the 12v regulator is failing under load.
                • SdlewisSr
                  • Oct 2015
                  • 146
                  Close out this thread: After reading the Sharp Aquos LC-70LE732U Blinking Pattern 2 -5 thread (https://www.badcaps.net/forum/showthread.php?t=45671) and finding the Sharp Tech Tip # 1541 (https://www.badcaps.net/forum/attach...5&d=1429113014), I am concluding that the Panel is bad. Therefore I am closing out this thread.
                  • R_J
                    • Jun 2012
                    • 9592
                    The panel IS likely bad, but, there are options to try, There may be a shorted mlcc on one of the panel boards, there may be a bad panel driver ic on the side tabs that in some cases can be removed to restore the panel to a watchable tv. I don't know which threads to check but the information is here somewhere,
                    • budwich
                      • Jul 2015
                      • 3097
                      :-( I know you have done a lot.... BUT with the more recent work that you did for "voltage improvements", have you tried getting into the service menu. You might have to reset counters therein.
                      • SdlewisSr
                        • Oct 2015
                        • 146
                        Thanks R_J for the idea! Do you think a shorted mlcc on one of the driver boards would have shown up when I checked the resistance to ground with the T-Con disconnected from the Panel and then again with the T-Con connected to the panel (see attached chart)?
                        • SdlewisSr
                          • Oct 2015
                          • 146
                          Hi budwich. With either or both ribbon cable connected between the T-Con and the Panel, it does not power up and I get the 2-5 blink code. When I disconnect both ribbon cables the TV powers up with backlights, but of course there is nothing going to the Panel.
                          • budwich
                            • Jul 2015
                            • 3097
                            yes BUT, there is a "force sequence" when there is a fault code. Does that work? Note: those links that you posted are some what dated in terms of what people have found to work and not work with sets. Having said that, iirc, the 80 is a bit different from other sets in having the panel disconnected.... where as others allow to have part of the panel disconnected and still somewhat function.
                            • SdlewisSr
                              • Oct 2015
                              • 146
                              Thanks! I look into how to do that and try it.
                              • budwich
                                • Jul 2015
                                • 3097
                                I hate to see an 80 incher in the garbage. Your measurements listing in post 12 seem to suggest a possibly issue with the vcom circuit. You might see if you can visually or otherwise trace the circuit therein at the panel. IF you are lucky, you might find a compromised SMD component... most have found shorted caps in these areas that can be replaced with some careful soldering. IF you post a close up picture of the panel connection area at the connector and highlight where vcom is, others might have more ideas.
                                Further about disconnecting the tcon from the panel... that is somewhat a "gross test" which basically takes out large portions of the panel circuitry / control system. IF you look along the bottom of the panel, there are long thin driver boards which the tcon connects to. There is likely a pair of boards on one side of the panel and another pair on the other side (ie. one for each tcon to panel ribbon cable). The pair of driver boards have an "unclampable / clampable" "U" ribbon cable interconnecting them. With all other cables left connected, disconnect one of the "u" cables (ie. in essence, isolating 1/4 of the panel... the outer 1/4). See if the set responds differently to being powered up. Repeat the same test, on the other side. Any difference? Note: only one "U" disconnected at a time. IF you are lucky, you may see some screen happening. Go from the results.
                                • SdlewisSr
                                  • Oct 2015
                                  • 146
                                  Thanks budwich for the suggestions!!!!
                                  I look forward to checking these out.
                                  • RDC55
                                    • Dec 2017
                                    • 180
                                    You mention the resistance changed, but how about the voltage between panel connected and disconnected? Maybe I missed it but if one is loading that could lead you down a logical path, particularly if that voltage loads with either TCON output ribbon cable connected.
                                    • SdlewisSr
                                      • Oct 2015
                                      • 146
                                      With both cables connected, from the time I plug it in until I get the 2-5 blink code and it shuts down, I have 12v coming to the board at P4804, but no voltages on Pins 11,12 (VDA/AVDD, Pins 33,34 (VDD/Logic), Pin 60 (Vcom), Pin 78 (VGH), and Pin 79 (VGOFF/VGL) at connectors SC7001 & SC7002 .
                                      • SdlewisSr
                                        • Oct 2015
                                        • 146
                                        When I hold the [Vol+] and [Chan-] while plugging in the TV, I do not get the 2-5 blink code, and the TV does not shut down, but the backlights do not come on. The 12v coming to the board at P4804 remains on, but no voltages on Pins 11,12 (VDA/AVDD), Pin 60 (Vcom), Pin 78 (VGH), and Pin 79 (VGOFF/VGL) at connectors SC7001 & SC7002. However, I do have a small voltage of .658v on Pins 33,34 (VDD/Logic).
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • moltensolderlabs
                                          Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
                                          by moltensolderlabs
                                          Hi everyone. [Sorry for the long, detailed post in advance].
                                          I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
                                          10-09-2020, 12:01 PM
                                        • joblo37pam
                                          Sharp LC-80LE844U Blinks 2 slow, 5 fast
                                          by joblo37pam
                                          It's been a while since I've checked in here or needed input on narrowing down what to replace on a TV repair, but I've got one on my bench now that has me wondering. The lack of part (board) availability means I may need to do some component-level diagnostics, and a second opinion is always good when it comes to that.
                                          The issue - Sharp LC-80LE844U does not display. Power light comes on for a while, then you can hear a relay click off and the light blinks twice slow, then five times fast. Service manual points to 'Panel Power Supply Error' with this code, but isn't much more help...
                                          10-26-2023, 02:17 PM
                                        • ninja_zx11
                                          Sharp LC-70LE650U vertical black and red bars
                                          by ninja_zx11
                                          70" LED TV is Sharp LC-70LE650U.
                                          Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                                          07-07-2023, 11:27 PM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
