Old 07-12-2021, 05:15 AM   #1
Djgh
City & State: Maryland
My Country: US
Default Samsung UN70NU6070 TV Issue - HELP!
Evening,
I started experiencing color/brightness issues with my 70Ē Samsung tv after a year or so from date of purchase. It doesnít seem as bright and the colors are a little off. Is this a backlight issue or something else? Iím pretty hands on, so I donít mind tackling the issue if I can pinpoint what it is.
Any help would be appreciated.
Model #: UN70NU6070
Video comparison:
https://youtu.be/6dNhwNy_lus
File Type: jpg 0C814BE7-8E55-4CE4-85A2-AF322C830CAC.jpg (177.8 KB, 81 views)
Last edited by SMDFlea; 07-12-2021 at 06:36 AM.. Reason: Added UN70NU6070 to thread title
Djgh is offline   Reply With Quote
Old 07-12-2021, 09:03 AM   #2
alfatv
City & State: Guelph
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Re: Samsung UN70NU6070 TV Issue - HELP!
Yes, it could be backlight. Did you you run it at 100%?
In the meantime you can change color temperature setting in user menu and tune white balance in service menu. Reduce backlight to minimum possible setting.
For best results run the test with fully white screen.
If white is good, you can play with tint setting for colors, but better set it in the middle.
alfatv is offline   Reply With Quote
Old 07-12-2021, 09:43 AM   #3
Djgh
My Country: US
Appreciate it the advice. Iíve played with all the settings, performed a picture and power reset, and even spoke with a Samsung representative. None of those were helpful. I may end up replacing the backlight due to it being inexpensive but was still hoping someone could pinpoint the exact issue.
Old 07-12-2021, 09:07 PM   #4
R_J
City & State: ☻
My Country: Canada
It is unlikely to be the backlight, I would first check the source, possible bad hdmi cable? The next thing I would check (reseat) is the LVDS cable between the main board and t-con.
R_J is offline   Reply With Quote
Old 07-13-2021, 12:38 AM   #5
ducky29
City & State: -
My Country: Europe
Change the picture settings to vivid or standard. See if that makes any difference.
ducky29 is offline   Reply With Quote
Old 07-13-2021, 05:39 AM   #6
Djgh
My Country: US
Ordered a new tcon board so letís see what happens.
Lol thanks for your Input.
Old 07-13-2021, 07:25 AM   #7
mmartell
City & State: Windsor ON
My Country: Canada
Probably a gamma issue on the tcon. Think you're on the right track.
mmartell is offline   Reply With Quote
Old 07-13-2021, 12:14 PM   #8
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
+1
It does look as though the black level is washed out.
dick_barton is offline   Reply With Quote
Old 07-14-2021, 11:02 PM   #9
alfatv
My Country: Canada
Can you go this site and post pictures of gradients white red green blue?
https://www.eizo.be/monitor-test/
Old 07-16-2021, 06:05 PM   #10
Djgh
My Country: US
Replaced the tcon board. Itís definitely better but not perfect, then again Iím comparing it to the picture on my iPhone. Itís still a little saturated (maybe thatís the word)
Old 07-16-2021, 07:56 PM   #11
Djgh
My Country: US
People’s faces look like they have a bad tan
Old 07-17-2021, 10:14 AM   #12
R_J
City & State: ☻
My Country: Canada
Do you have pictures of both t-con boards? it is possible they could be for different models. You can't always go by the BNxx-xxxxxx number you need to use the number on the white sticker. I suspect there is an eeprom on the board and it bight be programmed for a different panel or main board
Old 07-19-2021, 06:36 AM   #13
Djgh
My Country: US
Not anymore. Old board is long gone but I purchased the new board based off the sticker on the back.
Old 07-24-2021, 12:18 PM   #14
Djgh
My Country: US
Another thing I noticed is that when I first turn the tv on, the colors appear to be perfect but slowly goes back to its original color issue
Old 07-24-2021, 08:19 PM   #15
frannyjunk
Could be the backlights. The phosporous on some of the LEDs may be failing causing a shift towards blue/purple (or pink before it gets to blue/purple).
frannyjunk is offline   Reply With Quote
Old 07-26-2021, 08:10 AM   #16
Djgh
My Country: US
The led strips could cause the color discrepancy? Am I wrong to assume the leds only assisted in fixing dark spots on the screen.
Old 07-27-2021, 03:46 PM   #17
ducky29
City & State: -
My Country: Europe
Yes they do but I have never found a samsung with that fault. Mostly vestels and LG. The picture will get blueish but I don't think this is the case.
Old 07-27-2021, 04:01 PM   #18
petehall347
City & State: worcester
My Country: United Kingdom
turn the red up and see what happens
Old 07-28-2021, 05:47 AM   #19
Davi.p
Davi.p's Avatar
City & State: Milan
My Country: Italy
Much probably bad backlight, must check power supply output tensions for the leds, must be in the range, if not it can ruin the led phosphors by too much tension. If those are ok so are bad leds.
Davi.p is offline   Reply With Quote
Old 07-28-2021, 06:40 AM   #20
angelos
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
+1
I totally agree with that.
angelos is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2022
