A1286 2915 does not power from BUTTON but works!
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello
    Im playing with my honor here.... cant figure out this!!
    Working fine a1286 (2011) macbook 820-2915-A....
    I needed to test a keyboard from another (identical) macbook ..
    The keyboard did not work at all, maybe was bad or incorrect version. no labels at all...so i dont know....
    then, reinstalled everything back to the good macbook , but now does not power on from power button, only from a short to GND at R5016... rest is normal...
    I spent day working on this and this is ridiculous,
    measured continuity from pin5 keyboard connector and was interrupted in his way to the other side: R5710 pin2
    so made a jumper and thought would be ok....but
    Still not powering on , but 3.33v present at R5710 both sides!!
    what is wrong?
    the same laptop powers on well with another motherboard, so it is not a keyboard issue.
    What else can I try? some pictures as reference and schematics provided.
    thanks in advance
    Marcelo J
  • mon2
    • Dec 2019
    • 14498
    Re: A1286 2915 does not power from BUTTON but works!
    1) confirm that R5710 is a 1k resistor.
    2) remove the keyboard. Short the logic board Power Button pads @ R5016. Does this work to turn the logic board ON / OFF ?
    3) Then do the same short @ R5710, Pin # 1.
    4) Then do the same short @ R5710, Pin # 2 (with keyboard still out).
    The +3v3 on SMC_ONOFF_L is due to the 10k pull-up @ R5070.
    If the above manual bypass methods work then suspecting a connector / contact issue @ pin # 5 of J5713.
    If you have enough hands, consider to probe pin # 2 of R5710 while pressing down on the keyboard on/off button to confirm it indeed goes low during a press.
    Cleaned the keyboard cable contacts with alcohol ?
    • piernov
      • Jan 2016
      • 4437
      • France
      If machine turns on when shorting pin 5 of keyboard connector to ground but not when pressing power button on the keyboard, then keyboard connector or keyboard flex is bad.
      • marce002
        • May 2018
        • 316
        • Argentine
        yes it is
        yes it powers up
        yes it powers up too
        it goes down yes!! after my jumper (see red line in my above picture)... that is the strange thing here. also the same keyboard connector works with another mother so it is a mother issue
        yes did it before.. no results.
        Marcelo J
        • marce002
          • May 2018
          • 316
          • Argentine
          nop because same keyboard/connector/button works perfect with another motherboard.
          Marcelo J
          • mon2
            • Dec 2019
            • 14498
            1) locate the ground pad on the keyboard flex cable.
            2) power down and work with the keyboard only.
            3) meter in resistance mode (200 ohms). Red meter lead on pin #5 if keyboard cable, black on the ground pad of the keyboard cable. Press the on/off button. Do you see pin #5 short to the ground pad of the cable?
            4) repeat with the keyboard attached to the logic board. Are the results the same?
            • marce002
              • May 2018
              • 316
              • Argentine
              with keyb connected:
              3* no battery no plugged in, keyboard connected , black on pin 29 GND, and red in pin 5 goes from 300/200kohm down to aprox 100kohm .. restarting this measurement goes to 200k again and down to around 130k....weird
              button pressed messed up things , when pressed down to 8kohm , when unpressed goes up to 2 or 3 Mohms.... very noisy numbers, not constant not fixed values, always moving but great difference in res pressed and unpressed...
              with NO keyb connected:
              OL when not pressed and 0,4Kohm when pressed... constant values almost
              Marcelo J
              • mon2
                • Dec 2019
                • 14498
                Are you 100% sure this keyboard is for use with this logic board?
                The pull down is not strong enough with this keyboard to perform the on/off function. The resistance is just too high. If you are really in a pinch and have to use this keyboard, you can try to apply another resistor to ground on this pad. The effect we want is that when you press the on/off button, the resistance from this keyboard in parallel with the external resistor will allow for the function. It is only an idea but should work. The proper solution is to find a better keyboard or a new one. The above idea will require some trial and error.
                Test with another keyboard and check the on/off pad using the same method. Once you can get the resistance down, it will work.
                • mon2
                  • Dec 2019
                  • 14498
                  To clarify on your testing...
                  remove the keyboard off the logic board.
                  Using the keyboard (ONLY) - check the resistance on the ON/OFF pad (red meter lead) and ground on the keyboard cable (black meter lead). This test has nothing to do with the logic board - just the keyboard & meter will be used.
                  Then press the ON/OFF button on the keyboard - what are your resistance readings?
                  Concluding so far that your keyboard is defective or not the proper model for this logic board.
                  The defect could be as simple as some liquid inside the membrane / closure of the button(s).
                  • marce002
                    • May 2018
                    • 316
                    • Argentine
                    Thanks i will try to lower the resistor and comme t. The keyboard was ok and original since it is from the first macbook... remember this happened after commecting the bad keyboard to the good system as i have stated in my first post.
                    Also remember that swaping motherboards the system starts ok with that same keyboard and same button.....
                    It make sense to lower the res... i will test that.
                    Marcelo J
                    • marce002
                      • May 2018
                      • 316
                      • Argentine
                      Yes!!! 10k Parallel resistor did the trick. Thanks mom2 ..thanks to all.
                      Marcelo J
                      • mon2
                        • Dec 2019
                        • 14498
                        Well done
                        • netboy69
                          • Aug 2017
                          • 17
                          • England
                          Hi to all, can anyone show the paralel 10k resitor locattion? regards
                          • mon2
                            • Dec 2019
                            • 14498
                            Hi. Check the resistance to ground at R5710 when you press the ON/OFF button. Check pin # 2 and also pin # 1 on this resistor. No power & no battery during these checks.
                            Click image for larger version  Name:	onoff.png Views:	0 Size:	169.0 KB ID:	3318512
                            • netboy69
                              • Aug 2017
                              • 17
                              • England
                              thanks, so a 10k resistor in paralel to that r5710
                              • netboy69
                                • Aug 2017
                                • 17
                                • England
                                Ok so on pin two i have 1.087 when i press power button it comes down to 0.145, on pin one i have 0.626 and when press power button i get 0.539.
                                • mon2
                                  • Dec 2019
                                  • 14498
                                  If I recall correctly, for this thread, the ON/OFF button was unable to strong pull-down this line to ground. There was a resistance built up inside the membrane / tacticle button of the keyboard.
                                  Do confirm the voltage to ground of each side of the required pull-up resistor at R5070. This may be your issue. When the button is NOT pressed, you should have a voltage of ~3v42 on the SMC_ONOFF_L line.
                                  When pressed, this line should be pulled down to a voltage close to 0 volts.​
                                  If the above pull-up resistor is ok then continue to review the details below.
                                  To compensate, the OP applied a mix of resistors in parallel to the button so you will need to apply a resistor with one leg to pin #2 of R5710. Other side of the 10k resistor to ground. In summary, we are attempting to assist the button to hard pull the line to ground.
                                  Test with 10k to ground @ pin # 2 of R5710. The voltage @ pin # 1 on this same resistor is not going down enough to perform the on/off button action.
                                  • netboy69
                                    • Aug 2017
                                    • 17
                                    • England
                                    on the r5070 pin 1 i get 3.4 and when press power button comes down to 0.422, on pin two always 3.4v
                                    • netboy69
                                      • Aug 2017
                                      • 17
                                      • England
                                      if i add the 10k resistor to pin 2 of the r5710 to ground when i press the button i get 0.067 but still wont turn off
                                      • mon2
                                        • Dec 2019
                                        • 14498
                                        These are good measurements. The action on this signal line is active LOW when there is a button press. Are you unable to turn the unit ON/OFF with the keyboard?
                                        Locate the PCB shorting pads as follows. Carefully use tweezers to short either of the following pads and confirm if the logic board works to turn ON / OFF.
                                        One pair of pads will be on one side. The other pair is on the other side.
