iPhobe XS wont charge after battery replacement
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Replaced a original XS battery yesterday as it was down to 78% battery health and would drain from 100% to flat within a day or so. After replacing the battery we noticed the battery would not charge, ie the phones not coming up with the charging symbol. I tried connecting it to 3U tools and that is unable to detect the phone. I took the phone apart again and this time removed the screw plate covering the connectors and left the display hinged open to make sure nothings shorting but no change. I then found the vol +/- and vibrate ribbon connector on the ribbon side has a few bent pins, could that cause a charging issue? The buttons are not working either when the phones on so that clearly needs to be replaced.
    I disconnected the battery and hooked up my USB C meter and the phone initially draws 5V 0.0090A than jumps up to 0.0135A than dips back down to 0.0090A and continues fluctuating around those areas. I took resistance and diode measurements of the battery connector but unfortunately haven't been able to find reference XS values and I don't have a ZXW license. Values are (measurements taken as battery below connector and ground pins excluded) :
    Pin 1 Bottom left R=3.5 D=0.001
    pin 2 R=3.7 D=0.001
    pin 3 R=3.6 D=0.003
    Pin 4 Top left R=1 D=0.002
    Pin 5 R=1M+ D=0.415
    Pin 6 R=1M+ D=0.415
    I'm thinking Tigris is bad, but wanted to get some advise before I go gunho on the usual suspects. Seeing pins 1-4 seem to have shorts I have not tried a new dock connector, plus I also do not have one to try. I noticed there are multiple versions of tigris and tristar, is there a way to find out which one your board uses without taking the board apart? I do not have a board separator so I would have to order one.
    Short bit of history, about a year ago I replaced the display as the phone was dropped and the display had the typical green line in it. Replaced it with a OEM refurb as I do not trust aftermarket displays. Wondering if this has something to do with the battery dying so fast. The phones only a year and a half old, and it's barely used. That's really quick for a battery to loose so much of it's charge capacity. My 7+ still lasts me 3 days on a single charge.
    • 31260
    Re: iPhobe XS wont charge after battery replacement
    isnt this one of the phones with an eeprom in the battery protection that is checked against the central store of serial numbers?
    in short - it will only work with a battery installed by apple - unless you keep the original protection curcuit or have a programmer.
    • diif
      • Feb 2014
      • 6978
      • England
      If you've got bent pins I'd inspect the other connectors and sockets and lift the foam to double check you've not damaged any components.
      Half right stj, the battery will work it displays a non genuine message and won't give proper stats.
      • mon2
        • Dec 2019
        • 14685
        Sharing a case of bad cap causing this issue.
          • 21986
          Yes, afaik you need to swap the BMS board,activate the battery and program it
          https://www.youtube.com/watch?v=NokIyI_J52I
          • AJ847.63e
            • Aug 2020
            • 171
            • Africa
            Thanks for the advice all. The other connectors seem fine, both board and flex side, as do the caps near the connectors under the foam. Would it be worth putting the original battery back in to see if that charges?
            Otherwise I did take out the taptic engine, charge port and speaker board so i could get to the battery strips so it's certainly possible the flex for the docks not correctly installed. If I tested for continuity between the charge port and the battery connector that should confirm the charge ports ok shouldn't it? Not sure if the dock connects directly to the battery, or if the two go their separate ways and meet in the middle therefore not giving continuity from the dock to the battery connector.
            Definitely does present like a tigris or tristar issue though. My understanding is tigris controls the charging functions where tristar controls USB coms is that correct? It seems that the phone does not power on when connecting to the charger when battery is disconnected either so it looks like both are dead.
            Is there any other diagnostics I can do before splitting the boards? I've ordered a pre heater but probably wont be here for a week or so.
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              Not really. Swapping BMS is only needed to get it to show health and to not get that error message. Otherwise it works just fine without swapping.
              They tend to get faulty dock flexes and sometimes there might be a shorted capacitor that causes it.
              Unsoldering the applecake is the last thing to do here.
              • AJ847.63e
                • Aug 2020
                • 171
                • Africa
                I'm thinking it's the battery fpc connector on the board causing the issue. The far left pin seems a bit pushed in and loose so I've ordered a replacement. Still waiting for the board heater to arrive.
                • razenxd
                  How can I charge that battery pack?
                  by razenxd
                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                  Now, I have noticed a few things.
                  The "dead" battery, while connected to charger and NOT Charging will...
                  12-05-2024, 06:11 AM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
                • Klevjetack
                  Charge a L19D3PDA battery externally from the laptop
                  by Klevjetack
                  Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                  03-05-2024, 07:26 AM
                • dhenion
                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                  by dhenion
                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                  The original board was:
                  ASUS X510UNR REV 3.0 A
                  The replacement board is:
                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                  01-30-2024, 01:45 PM
                • dclass-pro
                  Latitude 3301 not charge battery
                  by dclass-pro
                  Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                  I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                  I noticed 2 things:
                  1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                  2) if I try to turn it on without the battery...
                  05-06-2025, 06:19 AM
