Can Anyone Identify the Value of This Component ?
  • mmartell
    • Oct 2013
    • 3189
    Filter at L1 appears marked with the letter H anyone know what that means ? From an Amazon Fire stick remote control. The remote was burning through batteries at an alarming rate I may have popped the filter on disassembly don't know. Also missing a small resistor above it with unknown value but first things first ...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Can Anyone Identify the Value of This Component ?
    Lx is normally the suffix for an inductor.
    • mmartell
      • Oct 2013
      • 3189
      Okay what is the value of an inductor marked with the letter H ?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        No idea. I suspect a search of the internet may come up wiith an answer. Have you a suitable meter to measure it's inductance?
        Can you post a clearer close shot of the smd device. I see several smd fuses online with H on the package
        • jkb242
          • Mar 2012
          • 175
          Agreed the picture is way too small.
          • mon2
            • Dec 2019
            • 14489
            Share the markings of the smd ic next to this inductor.
            It appears to be a local buck switching regulator. The ic could help to identify the value for this part.
            • mmartell
              • Oct 2013
              • 3189
              As stated in the first post I do not have the inductor it is missing on my board. The pic is a frame from a youtube video.
              • mmartell
                • Oct 2013
                • 3189
                Yes this is a good idea though I will say I've looked it up and found nothing but if you can please let me know.
                Marking is 4FN5R
                • R_J
                  • Jun 2012
                  • 9578
                  Is it the sot23-5 next to the inductor? My first guess is a Torex XC9140A
                  • jkb242
                    • Mar 2012
                    • 175
                    It’s quit likely not that critical but given the relative indicated size, (determined by wire size used to make the inductor and the designed current anticipated) replacement could be
                    2-3 μh SMT like a TDK SPM3010-LR or a TMS252012ALM depending on the actual dimension of the pads which were not provided.
                    • mmartell
                      • Oct 2013
                      • 3189
                      I've replaced the inductor with one of appropriate size and hopefully value (no marking) harvested from an old iphone board. Now, I am missing a resistor going to the chip enable pin which must be high to be active. The 3v supply is there. I think the resistor is for current limiting ? What value is suggested for the resistor ?
                      • mmartell
                        • Oct 2013
                        • 3189
                        33 ohms ? 100 ohms ? Is the value critical for this circuit ?
                        • thesame
                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                          by thesame
                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                          02-27-2024, 04:31 AM
                        • silver60618
                          Lenovo Legion 7 - Help Identify IC
                          by silver60618
                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                          Any help would be appreciated...
                          07-02-2025, 12:16 PM
                        • chth96
                          How can I identify varistor which have been blew up?
                          by chth96
                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                          So It seems that glass fuse and varistor have been blew up.
                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                          Is there any way to identify varistor type in my sega saturn PSU?
                          Any reply would be appreciated.
                          EDIT:
                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                          11-26-2023, 08:52 AM
                        • freakorio
                          Need Help To Identify Component on Ymain LJ41-05120A
                          by freakorio
                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                          05-21-2024, 02:32 AM
                        • baiceanu_stefan
                          nm-f251 Schematic, boardview or help identify componente
                          by baiceanu_stefan
                          Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                          04-24-2024, 12:49 AM
