Light bulb flicker
  • sew333
    • Apr 2017
    • 81
    • Poland
    Light bulb flicker
    Hello. I have an question about my bulb in room. Weather is normal,no storm etc. Today first time it flickered for 1 second. It happened when i close door in my room ( no more air )
    Bulb looking like that:
    Is this problem with electric in my house or it was bulb? It flickered ( black ) for 1 second and its fine. Should i worry? All deviced and pc working ok.
    My mother turned oven 2 hours ago,maybe something because of that?Bulb flickered 5 minutes ago.
  • petehall347
    • Jan 2015
    • 4429
    • United Kingdom
    Re: Light bulb flicker
    might be bad bulb or wiring .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      It appears to be a compact fluorescent bulb. They shouldn't flicker out as they have electronic ballasts but if it's temporarily overloading, the circuit might blink out for a second to cool, but more likely it may be a power wiring issue.
      however I'm curious...
      for those people living outside of the USA, how much are CFL bulbs compared to incandescent and LED? I suspect that incandescent bulbs are now made illegal due to energy waste, but how much do they cost compared to LED?
      Like in the USA, CFL bulbs are pretty much worthless now, people are opting for LEDs which have gotten significantly cheaper. And even those "filament" LED bulbs that mimic incandescent bulbs are much more sought after than regular LEDs, making them more expensive due to supply/demand...
      But how how is pricing in other countries for CFL/LED/"filament" LEDs? It might be worth to just replace the old CFL bulb?
        • Jul 2011
        • 6057
        Me too I curious as well about these questions
        • sew333
          • Apr 2017
          • 81
          • Poland
          So i have compact fluorescent bulb ? It flicker because of power wiring issue i have in house? How to check that? It flickered once today.Now its fine again.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            connect another bulb in parallel and see if they both flicker at the same time or not...?
            • diif
              • Feb 2014
              • 6978
              • England
              If my memory serves me correctly this is your third thread with electrical flakeyness.
              Why have you not got a professional in yet?
              I had a light that used to flicker downstairs. It turned out it wasn't the light but the main feed into the house ageing and becoming brittle. I was lucky to not have a fire.
                • 31138
                led and ccfl are the same price or close.
                i personally prefer ccfl because it's less directional.
                and lets be blunt - the light output from both is coming from excited phosphorus so no real difference in that.
                i think they last a lot longer too.
                the issue with the flicker could be a failing light switch as they are close to the door,
                i had to replace one of mine a while ago - they do wear out.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  That kind of BS is getting more common in the U.S., I bet!
                  Same with a loose neutral, which may be more of a problem with N.A. wiring than in Europe, Africa, most of Asia and Australia.
                  Also, incandescents are still not illegal in the U.S.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                    • Jul 2011
                    • 6057
                    That might be true however I can still get them at Home Depot but yes they are hard to find my understanding is once the supply that is here is USA runs out that is it l going to buy some more if I can find them so I have a supply for testing equipment and switching power supply and the like
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      Looks like more keep getting manufactured. Just not in U.S.A., because Sylvania sold out to China, like Hoover!
                      Arc A770 16 GB
                      • sew333
                        Light bulb flicker when turning on after long time off.
                        by sew333
                        Hello. I have question. I dont know if i have faulty wiring,bad installation or its bulb. When i have lights off long time and turn on lightning ( bulb halogen ) , there is a for 2-3 second bulb dimm/flicker and its normal. Happens only when lightning is off long time and i turn on.
                        When i turn off lights and turn on again its fine. That flicker/dimm happens only when lights are off long time.
                        That happens for example if i have lights off 2-3 hours and turn on.
                        Thx
                        02-16-2021, 01:39 PM
                      • ezenia
                        LUMIMAN Smart Bulb IC ID?
                        by ezenia
                        I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                        In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                        04-28-2025, 05:56 PM
                        Lithonia Lighting versus Light of America Compact Fluorescent product quality
                        by sam_sam_sam
                        I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                        I also have back when Light of America had these light bulbs available for yard lights
                        The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                        While the Lithonia lighting fixture has all most certain bulb failure
                        So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                        I have only had this light fixture for not more than a year if it...
                        07-02-2023, 03:45 PM
                      • fixit007
                        Samsung flicker - BN44-00932T board or else?
                        by fixit007
                        I picked up this TV that the prior owner said - just died.
                        Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                        Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                        Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                        05-04-2024, 06:14 PM
                      • sew333
                        Can halogen bulb flicker?
                        by sew333
                        Hi. Yesterday i was in bathroom. And halogen bulb flicker for 1 second. Is this possible and why it flicker? Thx
                        Bulb looking something like that:
                        06-09-2022, 09:25 AM
