Vizio M3D470KA 3d 47” tv no color
  • jkb242
    • Mar 2012
    • 175
    This set works fine in every way except there is no color. Off air and HDMI sources all work but no color. The model number is M3D470KA obviously no schematic. The goal for this set is an HD monitor ONLY. I have never encountered this issue in all the sets i have worked on but in general, believe the loss of color is associated with the HDMI controller chip. I don't believe in just changing parts so I would very much appreciate comments about troubleshooting this issue. In older analog sets I would be looking at the color burst oscillator but not sure this is where to begin investigating a chroma issue.
    Thanks so very much.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8331
    Re: Vizio M3D470KA 3d 47” tv no color
    What about the osd menu? Are the on air channels via the coax in color?
    • jkb242
      • Mar 2012
      • 175
      Thanks for your reply, they are not.
      • jkb242
        • Mar 2012
        • 175
        Sorry I did not answer your question regarding the onscreen menus. Yes, since these are generally bitmaps with overlays, they show up in color.
        It seems to be with video decoding from inputs HDMI and off air.
        Thanks!
        • ivtec
          • Dec 2008
          • 1967
          I think replacing motherboard is one of the only solutions to this problem.
          • jkb242
            • Mar 2012
            • 175
            No way am i going to buy a main board, its not worth that. This can only be a chip or supply missing to the chip which is no big deal. I do micro soldering and have the skills just hoping someone else here is familiar with where the chroma is recovered. I think its in the HDMI CHIP but was hoping for familiarity with HDCP AND chroma recovery. Thanks
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8331
              If the on air channels are also black and white, then its not the HDMI IC.
              • jkb242
                • Mar 2012
                • 175
                Thats is my suspicion as well and thanks for confirming my suspicion.
                • ivtec
                  • Dec 2008
                  • 1967
                  doesn't this tv has component video?
                  https://www.ebay.com/itm/33254650570...gAAOSwWZtgylmt
                  • jkb242
                    • Mar 2012
                    • 175
                    Thanks for the link to this replace board. Indeed less than i’ve seen but I’m confident i can replace the HDMI surface mount. It does have component video as well as composite but for preferred using an HDMI single connection opposed to the 5 connection required with component including audio of course.
                    Thats an interesting approach and thanks for that suggestion but without even a block diagram of the video chain for this set, not to mention a schematic, I’m not familiar with where the chroma processing would occur if outside the HDMI processor/switch. I’m thinking this would be right at the input to the LCD driver matrix but would appreciate any input you could share.
                    Thanks again!
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      You don't have a block diagram or schematic, we don't even have photos.
                      • ivtec
                        • Dec 2008
                        • 1967
                        Thanks for the link to this replace board. Indeed less than i've seen but I'm confident i can replace the HDMI surface mount. It does have component video as well as composite but for preferred using an HDMI single connection opposed to the 5 connection required with component including audio of course.
                        Thats an interesting approach and thanks for that suggestion but without even a block diagram of the video chain for this set, not to mention a schematic, I'm not familiar with where the chroma processing would occur if outside the HDMI processor/switch. I'm thinking this would be right at the input to the LCD driver matrix but would appreciate any input you could share.
                        Thanks again!
                        https://www.service-manual.net/?down...service-manual
                        • jkb242
                          • Mar 2012
                          • 175
                          Thanks for the link to the schematics. I have purchased from folks like this before and received worthless unreadable prints. Fool me twice…. But thanks for the suggestion.
                          • jkb242
                            • Mar 2012
                            • 175
                            Would a photo help? What photo would be helpful?
                            Thanks.
                            • jkb242
                              • Mar 2012
                              • 175
                              So you are sating the recovered video from the tuner has a separate chroma path to the LCD video driver? Wouldn't that mean the HDMI chip is bypassed for video demodulated from the tuner? That would be interesting to troubleshoot but since there is a good video signal being delivered to the LCD driver, then it would seem there is a separate chroma injection as well. The transmitted RF signal is all digital which captures chroma information as well. Unless the signal is converted to analog, as in the former analog NTSC format, where a burst oscillator is used to reinsert and demod the transmitted chroma signal. Correct? If there is an analog conversion in HD sets to recover video, I would be appreciate knowing this.
                              Thanks!
                              • Mectronik
                                Vizio m601d-a3 backlight issue
                                by Mectronik
                                Hello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
                                11-05-2023, 10:20 PM
                              • EazyBone
                                Vizio P759-G1, Tcon issue?
                                by EazyBone
                                Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                                Any help appreciated
                                https://youtu.be/tPeV2Q7TXIQ?feature=shared
                                03-22-2024, 03:25 PM
                              • remmurdmd
                                Vizio E65-E1 strange image issue
                                by remmurdmd
                                Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
                                10-02-2022, 09:12 PM
                              • derrickcaputo
                                Issue with 42 Vizio TV
                                by derrickcaputo
                                I have a 42" Vizio TV. I hooked my tablet to the HDMI inputs. Everything was fine until the screen went black and now the only input that works on the TV is coax. No hdmi, no component, no rca. I tried hooking up a laptop to the Hdmi port and the computer
                                detected the TV model but no image.
                                Is there anyone having the same issue? Did you find any solution?
                                08-20-2024, 12:21 AM
                              • bscottjohnston
                                Interesting E60-E3 (Vizio) issue
                                by bscottjohnston
                                Good morning BadCappers,
                                I picked up a Vizio E60-E3 yesterday. The donator claimed that it never powered on and that he checked Voltages at the power supply. I checked a handful of Voltages and then laughed when I realized I was trying to turn it on via the menu button on the back of the TV when its upside down on my TV repair bed (literally my guest bedroom).
                                Okay so I took out the mainboard and decided to flux up the BGA and heat it up. Upon reinstall of the mainboard the TV does indeed power up but all of the screens have a blue hue AND the video displayed fails...
                                08-31-2023, 07:41 AM
