Baird TI4909DLEDDS - cant exit Burn in mode
  • URL
    • Mar 2019
    • 10
    Guys
    Short story - I have the above Tv with T.MS3463S.U851 mainboard and samsung panel. When powered on, it sits in factory burn in mode, cycling through full screen colours.
    Long story - got the set over a year ago, and it had duff LEDS, so replaced the strips. When it was powered back on, it went into the factory burn in mode. Could not find out how to exit (and Menu 1147 did not work) I bought a used main PCB off the bay and all was good.
    Foolishly, I did not take a copy of the eeprom.
    So - now a few caps in the PSU have failed, so the set wont start. Replaced the bad caps and now the set is back in burn in mode!
    Question - does anyone know how to get the set into the factory menu (Menu 1147 not working) and initialise the board?
    Plan B is to buy another used mainboard and this time do the smart thing and read the eeprom before fitting...
    This set must be oh so sensitive for eeprom corruptions...
    Thanks in advance for your help.
    David
  • lotas
    • Jan 2016
    • 4782
    • Russia
    Re: Baird TI4909DLEDDS - cant exit Burn in mode
    Check if the LVDS cable is well inserted into the T-CON and MAIN, if the contact is poor, the panel may go into diagnostic mode.
    • neilc6
      • Nov 2015
      • 1550
      Try exit on the remote or power button on the TV itself.
      • URL
        • Mar 2019
        • 10
        Thanks Neil and Lotas
        I have tried both to no avail.
        There must be a sequence to get into factory mode....just need to keep Googling I expect for combinations for every user of the mainboard and hopefully find it....
        David
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8339
          Hmm... for some reason I have it in my mind that you have to let the TV set finish the burn in mode and cant be exited.
          • URL
            • Mar 2019
            • 10
            Thats an option... I had never thought of that!
            I wonder if its like, 24hours or so.... will no doubt be a lengthy wait. I did notice it "chimed" after a period of time... wonder if that then indicates that an exit is possible....
            I will give it a go.
            Given my experience with the set, it really feels like the mainboard is somewhat fragile to power quality and unexpected outages.
            David
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              on the tv has it a source or input button if so hold for 5 seconds if not try holding standby for 5 seconds
              • neilc6
                • Nov 2015
                • 1550
                I had a RCA or Haier stuck in aging mode and I had to buy a main board, read the eeprom, reflashed the bad one, and resold the board.
                • URL
                  • Mar 2019
                  • 10
                  Funny you say that - I ordered a mainboard off the bay for exactly that tactic!
                  Will post the bin when I do it to help future folks...
                  David
                  • URL
                    • Mar 2019
                    • 10
                    David
                    Board arrived.... cant get a clean read off the eeprom (fails verify each time).... so back on the search for a bin.... or live dangerously with the replacement board until the next time!
                    David
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Are you removing it from the board to read it?
                      • URL
                        • Mar 2019
                        • 10
                        No - was trying to read in-situ... If I read the "duff" board, it reads and verifies in-situ without error - that verifies the proggy and board interference... I hope!.
                        I did notice too that the two boards have different eeprom chips... and did ensure the proggy was set to the manufacturer's part number before read/write. They are both 24x64 chips.
                        David
                        • lotas
                          • Jan 2016
                          • 4782
                          • Russia
                          This board has SPI flash 25Q64
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            There can be interference from other components sometimes when reading the chip in situ.
                            Maybe post photos so we can see the differences.
                            • URL
                              • Mar 2019
                              • 10
                              Agreed, yes, my typo with 24.... the proggy sees them as two different manufacturers hence device numbers differ.
                              I will see if I get two mins to desolder the chip and try again.
                              • SidneyCanadas
                                93C46 and 93C56 EEPROM
                                by SidneyCanadas
                                I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                06-14-2023, 01:16 PM
                              • Woodsworth
                                PS3 CECHC03 60GB YLOD Troubleshooting
                                by Woodsworth
                                I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                START
                                Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                03-19-2024, 07:58 AM
                              • ttmi100x
                                HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                by ttmi100x
                                Greetings everyone,
                                I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                Upon closer inspection...
                                07-31-2024, 06:36 PM
                              • howardc64
                                Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                by howardc64
                                Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                • Backlight on, no image
                                • Disconnect right buffer board (view from front), left side display comes on
                                • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                • Buffer board is pretty simple
                                Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                07-11-2025, 04:04 PM
                              • dmccul2698
                                Pioneer DEX-P99rs "No EEProm " diagnostic code.
                                by dmccul2698
                                Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                                1). Understand the schematic and check the connections between the EEProm and DSP
                                2). Check the functionality of the EEProm
                                I don't know if this is the unit's problem but it's a place to start.
                                I have little to no electronic experience...
                                04-08-2024, 05:32 PM
