Asus P8Z68-V/Gen3, after saving UEFI settings, shuts down, doesn't restart
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've tried all BIOSes available to download, most recently first release version 0301, using an i3-2100
    For each try, after externally reprogramming its Winbond 25Q64BV (DIP8) with TL866IIplus
    Always same outcome - after Save & Exit, board shuts down and doesn't restart
    If I press onboard Power button, it'll start up then shut down again
    After jumpering CMOS Clear, it'll start to UEFI settings then repeat same behaviour
    It's had a new CR2032 fitted
    Closer examination found a second flash IC, a soldered Pm25LD512 (SOP8 or SOIC8, whichever is smaller), just to left of SATA connectors block (25Q64BV is on right)
    In these days of Management Engine and multi-MB firmware, something 64KB seemed too small to be relevant, but having run out of ideas, I desoldered it to see what would happen
    After power on, board contemplates for a few seconds, flashes a couple of red LEDs, bleeps with a brief glimpse of Asus logo, messages "The data in the EC or EC flash might be corrupted", then shuts down
    Dump of Pm25LD512 is attached - BIOSes tried are the *.ROMs downloaded from Asus
    Could anyone advise/assist please
    • 21679
    Re: Asus P8Z68-V/Gen3, after saving UEFI settings, shuts down, doesn't restart
    Its the EPU firmware.I checked it against one extracted from the asus bios and its exactly the same.Flash it back and carry on troubleshooting .
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Thanks for checking, and for the feedback
      Unfortunately I've run out of ideas, so scrapping the P.O.S. is looking like the most feasible option
      If EPU firmware is in the BIOS, I can't understand why there'd be a second, dedicated, flash IC just for it
      Maybe the Pm25LD512 is acting as a scratch pad and getting rewritten every boot, so replacing it perhaps worth a try
        • 21679
        Do you have a POST card
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Is "EC" for "embedded controller"? (Is it the same thing as "KBC" on a laptop?) (even when an ATX motherboard?)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            Yes, and it's about as helpful as usual - which is to say, not very much
            After powering-on motherboard once it's failed to restart, the POST card shows something like "finding type of keyboard and setting Numlock status" before losing power again
            • shouri
              Dell latitude e5490 auto restart
              by shouri
              Hi guys, can someone help me?
              I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
              Board model is dm70 la-f401p rev:1.0 2017-09-20.
              At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
              After a few days test, is seems ok.
              Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
              12-10-2024, 09:27 PM
            • alltvrepairs
              Samsung S22 plus reboots and heats up occassionally or after use
              by alltvrepairs
              I’ve noticed that my S22 occasionally freezes and shuts down—about once a day. I’ve already done a factory reset, installed only the essential apps, and updated the software. I also tried enabling power-saving mode to limit the CPU to 70%. This reduced the frequency, but the issue still occurs from time to time.
              When it shuts down, the casing becomes hot and stays that way. I then need to restart the phone by holding down Power and Volume Down.
              I’ve run diagnostics and enabled Developer tools to monitor CPU, GPU, and refresh rate. Unfortunately,...
              08-19-2025, 06:00 AM
            • zambiee99
              Asus UX564EH bios needed
              by zambiee99
              Hi, I have an asus UX564EH which at restart it shuts down. It has the last bios update 313, I checked the previous version also 312 but it's the same. If I remove the battery it starts, untill I give a restart. Shut down works, also I have an error in device manager, the uefi needs restart... Does anyone have a good bios for it?
              I post my backup
              model: UX564E, serial: M9N0CX23N669391
              thanks is advance...
              12-04-2024, 02:10 PM
            • GuiTi
              Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
              by GuiTi
              Hey everyone!
              I need help with my Lenovo Chromebook 100e Gen 3.
              Here are the details:
              • Motherboard: LA-L131P
              • MFG Date: 2022/01/07
              • MTM: 82J80001BR
              • MO: MPNXB2103001
              • Factory ID: LI123
              I bought a new Winbond 25Q128FVSG chip.
              The chip currently on the board is the same model but with different ending letters.
              I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
              The Chromebook is Google account locked, and I’ve already tried everything.
              I understand that I need to replace or...
              Yesterday, 08:41 AM
            • Christian0734
              Power Issue with ASUS A705UA.
              by Christian0734
              Hello
              The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
              09-13-2023, 03:04 PM
