da0zrtmb6d0 charging issue
  • lordmmx
    K6 Computers
    • Apr 2015
    • 48
    • Slovakia
    Hello guys,
    i got my hands on motherboard da0zrtmb6d0 rev D , that is used inside Acer E5-573g .
    Board works fine except two things:
    First issue is that it does not charge and does not see battery under windows. charging light keeps flashing orange, but battery holds charge, laptop runs from it and also charges which is kinda weird. Thing is, it keeps flashing even when I plug the battery in and don't plug in charger.
    See attached video: https://www.youtube.com/watch?v=HbJQUx4f5RM
    So far we replaced KBC chip ITE , BIOS, also replaced PD8, PQ56, PQ22, PQ58, PQ57 . also PU11 . Problem still exists.
    Second issue, GPU nVidia 920 does not work, it shows in Windows as working device but there is no 3D output and every 3D app just closes instantly, and sometimes it says "application has been blocked from accessing graphics hardware" - i tried different builds of windows , even windows 11, also tried different drivers but no luck at all.
    Any ideas?
    • 22233
    Re: da0zrtmb6d0 charging issue
    Check the battery in switch circuit ,BI_SW SW3.
    • lordmmx
      K6 Computers
      • Apr 2015
      • 48
      • Slovakia
      thanks , charging issue solved.
      now, any ideas about that gpu? Or should i try to gently reflow it?
        • 22233
        What was wrong with the charging section,describe what you fixed, it might help others with the same problem
        • lordmmx
          K6 Computers
          • Apr 2015
          • 48
          • Slovakia
          absolutely nothing. i just pressed and held down the SW3 button twice and it started to work normally. also it looks like battery is on it's last leg. so i recommend getting known good battery to avoid having this issue while fixing the rest
          • Simone Vergani
            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
            by Simone Vergani
            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
            To assist with troubleshooting, I'm attaching two power circuit schematics:
            • Power
            03-05-2025, 02:25 PM
          • drlarsen
            MacBook Air M1 A2337 battery/charging issue
            by drlarsen
            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
            After some hours, the battery status did not improve. Restore via DFU did not help.
            I connected the power adapter to a Kill-a-Watt...
            07-17-2025, 02:35 PM
          • ahmarzo
            la-j081p charging issue
            by ahmarzo
            Have Dell la-j081p laptop with battery issue.
            First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
            And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
            I have changed charging ic and pqb25 ,pqb26 and pqb13.
            When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
            This is the link...
            04-24-2025, 05:16 AM
          • DominikPechac
            MacBook Air A1466 820-00165 Charging Issue
            by DominikPechac
            I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
            A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
            However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
            04-05-2024, 02:20 AM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
