Is there a way to modify a IMAX b6 battery tester version 2 to only monitor voltage
    • Jul 2011
    • 6070
    I am still looking for a solution to problem using the BMS balancing protection board that for most part good but have the issue with batteries not having the same exact charging and discharging curves
    Also is there a way to make the battery voltage monitoring system to correctly report the exact battery voltage instead of estimating the voltage between battery cells
    I do not want the IMAX b6 to charge them I just want to able to monitor the battery voltage on each battery cell and use my own BMS balancing protection board that I am going to use on this battery pack
    I also want the IMAX b6 battery tester to still use the computer to show the results
    Is anyone interested in modification that it would take to do this if can be done
    I am willing to send you a IMAX b6 version 2 ( or something similar that is in the price range ) for your effort in this project to keep for your self for the work
    The only request that I have is that you modify the new IMAX b6 battery tester for me to get back from the person that under take this challenge but I also want to see a YouTube video showing how it would work
    I would do this myself but I do not have programming experience with the micro controller that is in this device
    If anyone is interested in this project please PM
    If this is not allowed on this forum I completely understand and if this post needs to be removed please feel free to do this or need to be moved
    • 31260
    Re: Is there a way to modify a IMAX b6 battery tester version 2 to only monitor volta
    if it wont throw an error, you could remove the load balancing resistors and the main switching fet.
      • Jul 2011
      • 6070
      Thanks I will try this tip
      I am going to buy a new one first before I start messing with the one I have right now
        • Jul 2011
        • 6070
        I am having a discussion about this topic on another forum if anyone is interested in the information gained from this topic
        https://forums.parallax.com/discussi...ionally#latest
          • Jul 2011
          • 6070
          Update to your question you were asking it does not throw an error however it locks up the controller because it does not see any amperage
          I do not know if there is a work around for this I have HTR clone unit that I am doing this on
            • 31260
            how many updates per second are you wanting?
              • Jul 2011
              • 6070
              Two per second would work
              I could live with it if it was one per second
                • Jul 2011
                • 6070
                Also there is no easy way to disable the positive side of the power supply it use two diodes on that side of the power supply rail the negative side power rail has the current sensor wire if you remove it -> it goes to 6 amp not what you setup in the controller
                  • Jul 2011
                  • 6070
                  STJ
                  Did you come up with anything
                    • 31260
                    no, not at that speed.
                    well not cheaply anyway.
                    you could by a bunch of multimeters with serial ports but that can add up fast.
                    my initial idea was a serial linked meter like a uni-t ut61e and a bunch of relays, but then your only taking one sample every couple of seconds and you need to multiply that by the number of cells
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      The 4051 circuit on parallax is laughable.
                      The lm324 circuit works but you have a maximum of around 6 or 7 (NOT 8) cells before you run into the lm324's limits, and you still have to deal with error/offsets/power for the op amp (32VDC) and don't use a LM2902(which has only 26V limit). Coupled witih a 4051 you'd only need one adc.
                      The correct, professional way, again, is multiple "meters" but they don't really have to be "complete" meters. Isolation is the problem. If you want to put in relays to use fewer meters, be prepared to make a n² switching fabric network making it almost as laughable as that 4051 circuit.
                        • 31260
                        there are adc's with upto 16 multiplexed inputs,
                        but it will need to have a common ground and use software to split the cell voltages.
                        not a problem, but sam doesnt like it.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          yeah just trying to appease sam's constraint of full dynamic range for each cell. Your solution loses dynamic range.
                          The LM324 solution if you solve the power and offset error issues, should also have full dynamic range per cell. You still need multiplexing.
                          Again a n² crossbar switch is needed if you really want to use just one high resolution measurement device for a battery with n number of series cells.
                            • Jul 2011
                            • 6070
                            Okay
                            How would you go about doing this
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              doing what? the lm324 is detailed on the other forum but you have to solve the power and offset issues. If you have a 32V PSU then you solved the harder issue, offset can be fixed in software. Again n=6S or 7S is the limit of this as-is.
                              the n² crossbar switch is so utterly stupid, for n=8 do you really want 64 relays in your design even if they are small reed relays?
                              actually n/m it's 2(n+1), though (n+1)² is the generic case... still 18 relays is silly and you still need isolation. stj's simpler solution is better even if it loses dynamic range... and isolation isn't needed, likewise the lm324 solution.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8703
                                Hmm... thinking about it more, the easiest relay solution is just one set of relays for + and -, so n+1 hence 2(n+1) and therefore 2(n+1) control lines.
                                For using a SPDT tiered approach at least you'd need only log2(n+1) wires to control them, however still need about the same number of relays... so unless you had two 1 of n+1 decoders handy, the SPDT is a lot less control wires.
                                  • Jul 2011
                                  • 6070
                                  If you have a SkyRc IMAX b6 version 2 and you decide to recap the the controller board be very careful doing this because the board is very shite design the traces come off very easily
                                  There is a 10uf@25 volts under the screen that test 4.1 ESR value results a new one 0.38
                                  And yes I had to unsolder the screen so I could get to it
                                  I am not sure exactly what this capacitor does but the traces are very small and come off the board very easily I had to repair a trace was right next to the capacitor that I replaced
                                  From the circuit diagram it seems to be for the 5 volt regulator from what I can see
                                  According to SkyRc volt meter it is 15.5 volts it might do 4 amp continuously I doubt that it would 6 amps continuously which is what is supposedly in this switching power supply ???????
                                  The switching power supply board has a 10uf@50 volts capacitor ESR value was around 1.something and a new one 0.40 ESR reading
                                  The power supply has a heat sink that is on one side of the power supply most of the way
                                  The reason I went to recap this unit was because I was having issues with it connecting to my computer and not controlling the battery charger
                                  After I have replaced the capacitor under the screen it now connects to computer very easily
                                    • Jul 2011
                                    • 6070
                                    I have been thinking about this issue
                                    If you were to two poll / two positions relays you would only need to have 6 of them you would have a lot of wire to be concerned about making sure that your polarity is correct and that you do have have more than one battery cell at any given time to a volt meter have a micro controller do the controlling the relay every two to four seconds I think this might be possible I have to find the right type of relay for this project
                                    This is for a 6 battery cell pack
                                    I am just thinking about this out loud
                                    Something like this type of relay
                                    https://www.digikey.com/en/products/...A2-5NU/5502071
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      actually dont need n+1, n is sufficient actually. But still 6S => need 6 relays for + and 6 relays for -. Whether you use a DPST to reduce the number of relays doesn't matter much, it will halve them, but you still need to carefully control 6 relays and not turn on more than one at a time.
                                      You can use a tiered DPDT relay tree too if wanted, and for 6 cells you only need ceil(log2(6))=3 control wires controlling 6 DPDT relays. A 7th relay will get you 8 cells monitored, and most importantly you still need to isolate your measurement device.
                                        • Jul 2011
                                        • 6070
                                        What I going to do is have each battery cell on it own relay and use a 4 1/2 meter to measure the voltage
                                        I going to connect both the positive and negative sides on each battery one at a time to the meter then disconnect that battery cell and go to the next battery cell and so on
                                        The time that the relay is ON will have to done when I have all the parts and have it hooked up
                                        But how I going to test this device is using regular AA battery that you can buy at the grocery store so if something goes horrible wrong I would have a big bad fire and a lot of hissing going on
                                        If I have forgot something please point it out to me I am all ears
                                        I would like to thank all of you that have contributed to this discussion on this topic and project
                                        This where this discussion began with the “ KSGER Battery BMS charge battery board review”
                                        I have not been able to get this issue out of my head trying to figure why this BMS balancing protection board does not want to work as you would expect it to
                                        I want to answer the question weather or not it a bad deign or you have to perfectly match the battery cells for it to work correctly I have answer this question once and for all
                                        Because ideally I would like to have a very compact soldering iron station that was the hole reason for buying this setup in the first place
                                        I know you might think that I might have impulsive compulsive disorder and you are correct that I can have a bad case of it when questions are not answered WHY it will not work correctly
                                        https://www.badcaps.net/forum/showth...t=Ksger&page=4
                                        But it not for the reason about the battery operated soldering iron station it also I have bought some BMS balancing protection boards to test for a project idea and put it on hold because I did not like the results of the BMS balancing protection board that I bought
                                        I just bought to change it from 40 volts to 32 volts BMS protection board does not have the balancing feature on but it would not be very inconvenient if it does not balance the battery voltage because it very hard to find a battery charger for 32 volts in the first place unless used two 16 volt BMS balancing protection boards but unfortunately I only have one and I do not know if I can find another from Battery Hookup or not I have to look
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • ferah831208
                                          Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                          by ferah831208
                                          Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                          03-18-2025, 01:18 AM
                                        • huzo
                                          HP ELITE X2 1013 G3 weird battery issue
                                          by huzo
                                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                          01-31-2025, 12:09 AM
