Motherboard to LCD EDP Cable for MSI GE75 10SF
  • Califauna
    • Jul 2020
    • 28
    • Spain
    I am trying to repair an MSI GE75 10SF laptop screen (the HDMI output works but the laptop screen doesn't).
    I bought it without a screen in it second hand and was told it just needed a screen. I bought a 300hz screen for it, LCD model number B173HAN05.1, and a ribbon cable which I thought would connect the LCD to the board. The LCD fits into the frame OK but the LCD end of the ribbon doesn't fit into the connector on the LCD.
    I attach photos of the motherboard end of the cable I bought (mbconnector.jpg), which fits correctly into the motherboard, and the other end of the cable which doesn't fit into the LCD (LCDEnd.jpg). I also attach a photo of the LCD input (Screen input.jpg).
    This is the laptop specs page:
    https://www.msi.com/Laptop/GE75-Raid...176b3e5fS7gKgl
    This is the LCD which I have technical details page:
    https://www.panelook.com/B173HAN05.1...ter_44168.html
    This is the cable I have:
    https://es.aliexpress.com/item/40003...176b3e5fS7gKgl
    The dimensions of the LCD are right, the refresh rate (300 hz) appears to be supported according to the MSI page (though I'm not 100% sure), and the resolutions match.
    Could I get some help with whether I need another LCD at this point, or whether the B173HAN05.1 will work if I find the right cable?
    If I find a way to connect the MB to this LCD will it likely work?
    Thanks for any help.
    • 21968
    Re: Motherboard to LCD EDP Cable for MSI GE75 10SF
    You could try an adapter http://forum.notebookreview.com/thre....834742/page-4 .If you find one on aliexpress make sure to read the reviews,i have no idea if they`re any good or not.
    • Califauna
      • Jul 2020
      • 28
      • Spain
      I think the problem with an adapter might be that there isn't enough space under the bezel. It's tight as it is. I might try though if I can't find a cable (and if anyone can confirm here if that LCD would work if connected using the right cable).
      • mielta
        • Apr 2015
        • 368
        I Think you have wrong LCD
        see here https://www.ebay.de/itm/323819302211...EAAOSw9-hggBwM
        • Califauna
          • Jul 2020
          • 28
          • Spain
          That one's for the GE75 10SFS-067 whereas my laptop model is the GE75 10SF-035, but I'm getting the impression it would be compatible.
          If it is, then comparing with the screen I have already bought, it has the same resolution, number of pins, basic signal type (edp), number of lanes, dimensions, etc, but a couple of differences:
          The monitor I have bought is listed as:
          144hz.
          3.3v(typ.) input voltage. I am guessing typ. means typical.
          eDP1.3.
          That monitor is listed as:
          240hz.
          3.4v (typ.) vs. for mine.
          eDP1.4.
          I have also just been told by MSI support that the original monitor for my model is a LQ173M1JW05, which according to one taobao page is compatible with the B173HAN05.0, which is also eDP1.4.
          Anyone know if eDP1.3 and eDP1.4 are compatible, and if anything is likely to explode if I connect them?
          • jean luc ferre
            display screen problems after changing motherboard
            by jean luc ferre
            First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
            I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
            Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
            Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
            09-11-2025, 10:28 AM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • Stanley1843
            Motherboard W26361-W84-X-02 - Black Screen
            by Stanley1843
            Hello to everyone.
            My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't...
            05-23-2024, 03:51 PM
          • almarhum
            To fix laptop screen vertical line by working on its EDP cable
            by almarhum
            Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
            As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
            05-07-2024, 02:12 PM
          • Rolin
            Lenovo Legion 5 15IMH05H No Display
            by Rolin
            I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
            A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
            06-21-2025, 11:32 PM
