Drilling holes laptop bottom
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    I wonder if drilling a few holes in the laptop case, on the bottom below the fan will actually help and decrease the CPU/GPU temps. I have one spare not so new laptop with first gen core i5, but the main issue is that while the cooling systen is clean, it runs rather hot - youtube tends to bring the laptop to about 60-64 degrees, even if power plan with 60% power limit restriction is used and the cpu itself does not go above 1.2-1.4GHz. It has integrated graphics, this is true, but the temps seem a little bit high... Even the SSD runs above 55-60 degrees, while it isnt actually intensively used...
    Disclaimer - All temps are in Celsius...65C = 149F
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Drilling holes laptop bottom
    65°C is cold for a laptop.
    A good amount of recent laptops are designed to run just below thermal throttling under load which is often 95°C to 105°C.
      • 31247
      reminds me of the old apple aluminium mono-shell designs - you could iron your trousers with those!!
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        • Bulgaria
        Well, it has integrated into the processor video and the processor itself is socketed. So, the prime concern in laptops about the possibility of mobo death is kinda of avoided here. But still, above 55-60C with 20-30% CPU load seems a little bit high. And its definitely not the thermal paste. I use Arctic Silver(made in USA haha or so the syringe says..) And have replaced the thermal pads with better. Yet, I would like to see temps like 40C when Idle and not above 55 under light load like youtube and so on.
        And there arent any bottom vents, so the airflow of the fan is not the best. BTW, the laptop is business series HP Probook 6540b... From the time, when HP still manufactured decent stuff
        • lti
          • May 2011
          • 2557
          I briefly thought about that on my old Toshiba Satellite L750. It also has no direct air intake for the fan, but it would throttle when fully assembled. It would "only" reach 80°C when disassembled (with a Core i3, integrated graphics, and some Arctic Silver 5 that's older than the laptop itself).
          • clearchris
            • Dec 2013
            • 687
            I think the thin plastics involved in laptops wouldn't take kindly to drilling holes. Unless it never left a desk, it would disintegrate in a short period of time.
            If it never left a desk it probably wouldn't be too hard to 3d print a new case with better airflow if you had a 3d printer big enough.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              If there is space, you can also put the thin copper heatsinks with adhesive that they use for memory cooling on the heatpipes. I did this for my asus gaming laptop and it took the temps, well, a little bit down
                Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                09-06-2024, 09:30 PM
                Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-06-2024, 08:47 AM
              • RdeveLabs
                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                by RdeveLabs
                To all the members here...
                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                05-05-2025, 04:59 AM
                Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-07-2024, 06:11 AM
